{"name":"Visual Paradigm Blog","description":"","url":"https:\/\/blog.visual-paradigm.com\/id","home":"https:\/\/blog.visual-paradigm.com\/id","gmt_offset":"8","timezone_string":"","namespaces":["oembed\/1.0","contentviews\/v1","custom-permalinks\/v1","featured-image-from-url\/v2","msls\/v1","yoast\/v1","redirection\/v1","regenerate-thumbnails\/v1","wp\/v2","wp-site-health\/v1","wp-block-editor\/v1"],"authentication":{"application-passwords":{"endpoints":{"authorization":"https:\/\/blog.visual-paradigm.com\/id\/wp-admin\/authorize-application.php"}}},"routes":{"\/":{"namespace":"","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/"}]}},"\/batch\/v1":{"namespace":"","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"validation":{"type":"string","enum":["require-all-validate","normal"],"default":"normal","required":false},"requests":{"type":"array","maxItems":25,"items":{"type":"object","properties":{"method":{"type":"string","enum":["POST","PUT","PATCH","DELETE"],"default":"POST"},"path":{"type":"string","required":true},"body":{"type":"object","properties":[],"additionalProperties":true},"headers":{"type":"object","properties":[],"additionalProperties":{"type":["string","array"],"items":{"type":"string"}}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/batch\/v1"}]}},"\/oembed\/1.0":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"oembed\/1.0","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/oembed\/1.0"}]}},"\/oembed\/1.0\/embed":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"URL dari sumber dimana data oEmbed akan diperoleh.","type":"string","format":"uri","required":true},"format":{"default":"json","required":false},"maxwidth":{"default":600,"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/oembed\/1.0\/embed"}]}},"\/oembed\/1.0\/proxy":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"URL dari sumber dimana data oEmbed akan diperoleh.","type":"string","format":"uri","required":true},"format":{"description":"Format oEmbed yang akan digunakan.","type":"string","default":"json","enum":["json","xml"],"required":false},"maxwidth":{"description":"Lebar maksimal frame sematan dalam satuan piksel.","type":"integer","default":600,"required":false},"maxheight":{"description":"Ketinggian maksimal frame sematan dalam satuan piksel.","type":"integer","required":false},"discover":{"description":"Penentuan jika akan melakukan permintaan penemuan oEmbed untuk penyedia yang tidak diizinkan. ","type":"boolean","default":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/oembed\/1.0\/proxy"}]}},"\/contentviews\/v1":{"namespace":"contentviews\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"contentviews\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/contentviews\/v1"}]}},"\/contentviews\/v1\/block_template_pattern":{"namespace":"contentviews\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/contentviews\/v1\/block_template_pattern"}]}},"\/contentviews\/v1\/update_block_template_pattern":{"namespace":"contentviews\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/contentviews\/v1\/update_block_template_pattern"}]}},"\/custom-permalinks\/v1":{"namespace":"custom-permalinks\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"custom-permalinks\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/custom-permalinks\/v1"}]}},"\/custom-permalinks\/v1\/get-permalink\/(?P<id>\\d+)":{"namespace":"custom-permalinks\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"required":false}}}]},"\/featured-image-from-url\/v2":{"namespace":"featured-image-from-url\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"featured-image-from-url\/v2","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/featured-image-from-url\/v2"}]}},"\/featured-image-from-url\/v2\/metadata_counter_api":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/featured-image-from-url\/v2\/metadata_counter_api"}]}},"\/featured-image-from-url\/v2\/enable_fake_api":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/featured-image-from-url\/v2\/enable_fake_api"}]}},"\/featured-image-from-url\/v2\/disable_fake_api":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/featured-image-from-url\/v2\/disable_fake_api"}]}},"\/featured-image-from-url\/v2\/data_clean_api":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/featured-image-from-url\/v2\/data_clean_api"}]}},"\/featured-image-from-url\/v2\/run_delete_all_api":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/featured-image-from-url\/v2\/run_delete_all_api"}]}},"\/featured-image-from-url\/v2\/disable_default_api":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/featured-image-from-url\/v2\/disable_default_api"}]}},"\/featured-image-from-url\/v2\/none_default_api":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/featured-image-from-url\/v2\/none_default_api"}]}},"\/featured-image-from-url\/v2\/pre_deactivate":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/featured-image-from-url\/v2\/pre_deactivate"}]}},"\/featured-image-from-url\/v2\/feedback":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/featured-image-from-url\/v2\/feedback"}]}},"\/featured-image-from-url\/v2\/deactivate_itself":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/featured-image-from-url\/v2\/deactivate_itself"}]}},"\/featured-image-from-url\/v2\/rest_url_api":{"namespace":"featured-image-from-url\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET","POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/featured-image-from-url\/v2\/rest_url_api"}]}},"\/featured-image-from-url\/v2\/metain":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"post_id":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/featured-image-from-url\/v2\/metain"}]}},"\/featured-image-from-url\/v2\/metaout":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"post_id":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/featured-image-from-url\/v2\/metaout"}]}},"\/featured-image-from-url\/v2\/create_thumbnails_list":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/featured-image-from-url\/v2\/create_thumbnails_list"}]}},"\/featured-image-from-url\/v2\/sign_up":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/featured-image-from-url\/v2\/sign_up"}]}},"\/featured-image-from-url\/v2\/connected":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/featured-image-from-url\/v2\/connected"}]}},"\/featured-image-from-url\/v2\/reset_credentials":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/featured-image-from-url\/v2\/reset_credentials"}]}},"\/featured-image-from-url\/v2\/list_all_su":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/featured-image-from-url\/v2\/list_all_su"}]}},"\/featured-image-from-url\/v2\/list_all_fifu":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/featured-image-from-url\/v2\/list_all_fifu"}]}},"\/featured-image-from-url\/v2\/list_all_media_library":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/featured-image-from-url\/v2\/list_all_media_library"}]}},"\/featured-image-from-url\/v2\/list_daily_count":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/featured-image-from-url\/v2\/list_daily_count"}]}},"\/featured-image-from-url\/v2\/delete":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/featured-image-from-url\/v2\/delete"}]}},"\/featured-image-from-url\/v2\/cancel":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/featured-image-from-url\/v2\/cancel"}]}},"\/featured-image-from-url\/v2\/payment_info":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/featured-image-from-url\/v2\/payment_info"}]}},"\/featured-image-from-url\/v2\/cloud_upload_auto":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/featured-image-from-url\/v2\/cloud_upload_auto"}]}},"\/featured-image-from-url\/v2\/cloud_delete_auto":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/featured-image-from-url\/v2\/cloud_delete_auto"}]}},"\/featured-image-from-url\/v2\/cloud_hotlink":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/featured-image-from-url\/v2\/cloud_hotlink"}]}},"\/featured-image-from-url\/v2\/debug-slug\/(?P<slug>[a-z0-9-_]+)":{"namespace":"featured-image-from-url\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"required":true}}}]},"\/featured-image-from-url\/v2\/debug-postmeta\/(?P<post_id>\\d+)":{"namespace":"featured-image-from-url\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"post_id":{"required":true}}}]},"\/featured-image-from-url\/v2\/debug-posts\/(?P<id>\\d+)":{"namespace":"featured-image-from-url\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"required":true}}}]},"\/featured-image-from-url\/v2\/debug-metain":{"namespace":"featured-image-from-url\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/featured-image-from-url\/v2\/debug-metain"}]}},"\/featured-image-from-url\/v2\/debug-metaout":{"namespace":"featured-image-from-url\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/featured-image-from-url\/v2\/debug-metaout"}]}},"\/msls\/v1":{"namespace":"msls\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"msls\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/msls\/v1"}]}},"\/msls\/v1\/duplicate-post":{"namespace":"msls\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"post_id":{"required":true},"target_locale":{"required":true},"_elementor_data":{"required":false},"_yoast_wpseo_title":{"required":false},"_yoast_wpseo_metadesc":{"required":false},"update_existing":{"default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/msls\/v1\/duplicate-post"}]}},"\/msls\/v1\/posts-without-translation\/(?P<target_locale>[a-zA-Z0-9_-]+)":{"namespace":"msls\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"target_locale":{"required":true},"post_type":{"default":"post","required":false}}}]},"\/msls\/v1\/posts-missing-translations":{"namespace":"msls\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"default":"publish","required":false},"post_type":{"default":"all","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/msls\/v1\/posts-missing-translations"}]}},"\/msls\/v1\/fix-taxonomies":{"namespace":"msls\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"source_post_id":{"required":true},"source_blog_id":{"required":true},"target_post_id":{"required":true},"target_blog_id":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/msls\/v1\/fix-taxonomies"}]}},"\/msls\/v1\/fix-all-taxonomies":{"namespace":"msls\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"dry_run":{"default":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/msls\/v1\/fix-all-taxonomies"}]}},"\/msls\/v1\/fix-post-parents":{"namespace":"msls\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"dry_run":{"default":true,"required":false},"source_blog_id":{"default":1,"required":false},"verbose":{"default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/msls\/v1\/fix-post-parents"}]}},"\/msls\/v1\/fix-post-dates":{"namespace":"msls\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"dry_run":{"default":true,"required":false},"source_blog_id":{"default":1,"required":false},"limit":{"default":0,"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/msls\/v1\/fix-post-dates"}]}},"\/msls\/v1\/outdated-translations":{"namespace":"msls\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"post_type":{"default":"all","required":false},"status":{"default":"publish","required":false},"languages":{"default":"","required":false},"source_blog_id":{"default":1,"required":false},"limit":{"default":0,"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/msls\/v1\/outdated-translations"}]}},"\/msls\/v1\/blog-language-map":{"namespace":"msls\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/msls\/v1\/blog-language-map"}]}},"\/yoast\/v1":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"yoast\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/yoast\/v1"}]}},"\/yoast\/v1\/file_size":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"type":"string","description":"The url to retrieve","required":true}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/yoast\/v1\/file_size"}]}},"\/yoast\/v1\/statistics":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/yoast\/v1\/statistics"}]}},"\/yoast\/v1\/new-content-type-visibility\/dismiss-post-type":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"postTypeName":{"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/yoast\/v1\/new-content-type-visibility\/dismiss-post-type"}]}},"\/yoast\/v1\/new-content-type-visibility\/dismiss-taxonomy":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"taxonomyName":{"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/yoast\/v1\/new-content-type-visibility\/dismiss-taxonomy"}]}},"\/yoast\/v1\/readability_scores":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"contentType":{"type":"string","required":true},"taxonomy":{"type":"string","default":"","required":false},"term":{"type":"integer","default":null,"required":false},"troubleshooting":{"type":"bool","default":null,"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/yoast\/v1\/readability_scores"}]}},"\/yoast\/v1\/seo_scores":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"contentType":{"type":"string","required":true},"taxonomy":{"type":"string","default":"","required":false},"term":{"type":"integer","default":null,"required":false},"troubleshooting":{"type":"bool","default":null,"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/yoast\/v1\/seo_scores"}]}},"\/yoast\/v1\/introductions\/(?P<introduction_id>[\\w-]+)\/seen":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"introduction_id":{"type":"string","required":true},"is_seen":{"type":"bool","default":true,"required":false}}}]},"\/yoast\/v1\/wistia_embed_permission":{"namespace":"yoast\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":{"value":{"type":"bool","default":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/yoast\/v1\/wistia_embed_permission"}]}},"\/yoast\/v1\/alerts\/dismiss":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"key":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/yoast\/v1\/alerts\/dismiss"}]}},"\/yoast\/v1\/configuration\/site_representation":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"company_or_person":{"type":"string","enum":["company","person"],"required":true},"company_name":{"type":"string","required":false},"company_logo":{"type":"string","required":false},"company_logo_id":{"type":"integer","required":false},"person_logo":{"type":"string","required":false},"person_logo_id":{"type":"integer","required":false},"company_or_person_user_id":{"type":"integer","required":false},"description":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/yoast\/v1\/configuration\/site_representation"}]}},"\/yoast\/v1\/configuration\/social_profiles":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"facebook_site":{"type":"string","required":false},"twitter_site":{"type":"string","required":false},"other_social_urls":{"type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/yoast\/v1\/configuration\/social_profiles"}]}},"\/yoast\/v1\/configuration\/check_capability":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"user_id":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/yoast\/v1\/configuration\/check_capability"}]}},"\/yoast\/v1\/configuration\/enable_tracking":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"tracking":{"type":"boolean","required":true}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/yoast\/v1\/configuration\/enable_tracking"}]}},"\/yoast\/v1\/configuration\/save_configuration_state":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"finishedSteps":{"type":"array","required":true}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/yoast\/v1\/configuration\/save_configuration_state"}]}},"\/yoast\/v1\/configuration\/get_configuration_state":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/yoast\/v1\/configuration\/get_configuration_state"}]}},"\/yoast\/v1\/import\/(?P<plugin>[\\w-]+)\/(?P<type>[\\w-]+)":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}]},"\/yoast\/v1\/get_head":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/yoast\/v1\/get_head"}]}},"\/yoast\/v1\/indexing\/posts":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/yoast\/v1\/indexing\/posts"}]}},"\/yoast\/v1\/indexing\/terms":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/yoast\/v1\/indexing\/terms"}]}},"\/yoast\/v1\/indexing\/post-type-archives":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/yoast\/v1\/indexing\/post-type-archives"}]}},"\/yoast\/v1\/indexing\/general":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/yoast\/v1\/indexing\/general"}]}},"\/yoast\/v1\/indexing\/prepare":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/yoast\/v1\/indexing\/prepare"}]}},"\/yoast\/v1\/indexing\/indexables-complete":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/yoast\/v1\/indexing\/indexables-complete"}]}},"\/yoast\/v1\/indexing\/complete":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/yoast\/v1\/indexing\/complete"}]}},"\/yoast\/v1\/link-indexing\/posts":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/yoast\/v1\/link-indexing\/posts"}]}},"\/yoast\/v1\/link-indexing\/terms":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/yoast\/v1\/link-indexing\/terms"}]}},"\/yoast\/v1\/integrations\/set_active":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"active":{"type":"boolean","required":true},"integration":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/yoast\/v1\/integrations\/set_active"}]}},"\/yoast\/v1\/meta\/search":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/yoast\/v1\/meta\/search"}]}},"\/yoast\/v1\/semrush\/authenticate":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"code":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/yoast\/v1\/semrush\/authenticate"}]}},"\/yoast\/v1\/semrush\/country_code":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"country_code":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/yoast\/v1\/semrush\/country_code"}]}},"\/yoast\/v1\/semrush\/related_keyphrases":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"keyphrase":{"required":true},"country_code":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/yoast\/v1\/semrush\/related_keyphrases"}]}},"\/yoast\/v1\/workouts":{"namespace":"yoast\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/yoast\/v1\/workouts"}]}},"\/redirection\/v1":{"namespace":"redirection\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"redirection\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/redirection\/v1"}]}},"\/redirection\/v1\/redirect":{"namespace":"redirection\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"filterBy":{"description":"Field to filter by","type":"enum","enum":["url","group"],"required":false},"filter":{"description":"Value to filter by","type":"string","required":false},"orderby":{"description":"Field to order results by","type":"enum","enum":["url","last_count","last_access","position","id"],"required":false},"direction":{"description":"Direction of ordered results","type":"enum","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"filterBy":{"description":"Field to filter by","type":"enum","enum":["url","group"],"required":false},"filter":{"description":"Value to filter by","type":"string","required":false},"orderby":{"description":"Field to order results by","type":"enum","enum":["url","last_count","last_access","position","id"],"required":false},"direction":{"description":"Direction of ordered results","type":"enum","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/redirection\/v1\/redirect"}]}},"\/redirection\/v1\/redirect\/(?P<id>[\\d]+)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/redirection\/v1\/bulk\/redirect\/(?P<bulk>delete|enable|disable|reset)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"filterBy":{"description":"Field to filter by","type":"enum","enum":["url","group"],"required":false},"filter":{"description":"Value to filter by","type":"string","required":false},"orderby":{"description":"Field to order results by","type":"enum","enum":["url","last_count","last_access","position","id"],"required":false},"direction":{"description":"Direction of ordered results","type":"enum","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false},"items":{"description":"Comma separated list of item IDs to perform action on","type":"string|integer","required":true}}}]},"\/redirection\/v1\/group":{"namespace":"redirection\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"filterBy":{"description":"Field to filter by","type":"enum","enum":["name","module"],"required":false},"filter":{"description":"Value to filter by","type":"string","required":false},"orderby":{"description":"Field to order results by","type":"enum","enum":["name","id"],"required":false},"direction":{"description":"Direction of ordered results","type":"enum","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"filterBy":{"description":"Field to filter by","type":"enum","enum":["name","module"],"required":false},"filter":{"description":"Value to filter by","type":"string","required":false},"orderby":{"description":"Field to order results by","type":"enum","enum":["name","id"],"required":false},"direction":{"description":"Direction of ordered results","type":"enum","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false},"moduleId":{"description":"Module ID","type":"integer","minimum":0,"maximum":3,"required":true},"name":{"description":"Group name","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/redirection\/v1\/group"}]}},"\/redirection\/v1\/group\/(?P<id>[\\d]+)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"moduleId":{"description":"Module ID","type":"integer","minimum":0,"maximum":3,"required":true},"name":{"description":"Group name","type":"string","required":true}}}]},"\/redirection\/v1\/bulk\/group\/(?P<bulk>delete|enable|disable)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"filterBy":{"description":"Field to filter by","type":"enum","enum":["name","module"],"required":false},"filter":{"description":"Value to filter by","type":"string","required":false},"orderby":{"description":"Field to order results by","type":"enum","enum":["name","id"],"required":false},"direction":{"description":"Direction of ordered results","type":"enum","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false},"items":{"description":"Comma separated list of item IDs to perform action on","type":"string|integer","required":true}}}]},"\/redirection\/v1\/log":{"namespace":"redirection\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"filterBy":{"description":"Field to filter by","type":"enum","enum":["url","ip","url-exact"],"required":false},"filter":{"description":"Value to filter by","type":"string","required":false},"orderby":{"description":"Field to order results by","type":"enum","enum":["url","ip"],"required":false},"direction":{"description":"Direction of ordered results","type":"enum","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"filterBy":{"description":"Field to filter by","type":"enum","enum":["url","ip","url-exact"],"required":false},"filter":{"description":"Value to filter by","type":"string","required":false},"orderby":{"description":"Field to order results by","type":"enum","enum":["url","ip"],"required":false},"direction":{"description":"Direction of ordered results","type":"enum","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/redirection\/v1\/log"}]}},"\/redirection\/v1\/bulk\/log\/(?P<bulk>delete)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"filterBy":{"description":"Field to filter by","type":"enum","enum":["url","ip","url-exact"],"required":false},"filter":{"description":"Value to filter by","type":"string","required":false},"orderby":{"description":"Field to order results by","type":"enum","enum":["url","ip","url-exact"],"required":false},"direction":{"description":"Direction of ordered results","type":"enum","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false},"items":{"description":"Comma separated list of item IDs to perform action on","type":"string|integer","required":true}}}]},"\/redirection\/v1\/404":{"namespace":"redirection\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"filterBy":{"description":"Field to filter by","type":"enum","enum":["ip","url","url-exact"],"required":false},"filter":{"description":"Value to filter by","type":"string","required":false},"orderby":{"description":"Field to order results by","type":"enum","enum":["ip","url","url-exact"],"required":false},"direction":{"description":"Direction of ordered results","type":"enum","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"filterBy":{"description":"Field to filter by","type":"enum","enum":["ip","url","url-exact"],"required":false},"filter":{"description":"Value to filter by","type":"string","required":false},"orderby":{"description":"Field to order results by","type":"enum","enum":["ip","url","url-exact"],"required":false},"direction":{"description":"Direction of ordered results","type":"enum","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/redirection\/v1\/404"}]}},"\/redirection\/v1\/bulk\/404\/(?P<bulk>delete)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"filterBy":{"description":"Field to filter by","type":"enum","enum":["ip","url","url-exact"],"required":false},"filter":{"description":"Value to filter by","type":"string","required":false},"orderby":{"description":"Field to order results by","type":"enum","enum":["ip","url","url-exact"],"required":false},"direction":{"description":"Direction of ordered results","type":"enum","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false},"items":{"description":"Comma separated list of item IDs to perform action on","type":"string|integer","required":true}}}]},"\/redirection\/v1\/setting":{"namespace":"redirection\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/redirection\/v1\/setting"}]}},"\/redirection\/v1\/plugin":{"namespace":"redirection\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/redirection\/v1\/plugin"}]}},"\/redirection\/v1\/plugin\/delete":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/redirection\/v1\/plugin\/delete"}]}},"\/redirection\/v1\/import\/file\/(?P<group_id>\\d+)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/redirection\/v1\/import\/plugin":{"namespace":"redirection\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/redirection\/v1\/import\/plugin"}]}},"\/redirection\/v1\/import\/plugin\/(?P<plugin>.*?)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/redirection\/v1\/export\/(?P<module>1|2|3|all)\/(?P<format>csv|apache|nginx|json)":{"namespace":"redirection\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/regenerate-thumbnails\/v1":{"namespace":"regenerate-thumbnails\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"regenerate-thumbnails\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/regenerate-thumbnails\/v1"}]}},"\/regenerate-thumbnails\/v1\/regenerate\/(?P<id>[\\d]+)":{"namespace":"regenerate-thumbnails\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"only_regenerate_missing_thumbnails":{"description":"Whether to only regenerate missing thumbnails. It's faster with this enabled.","type":"boolean","default":true,"required":false},"delete_unregistered_thumbnail_files":{"description":"Whether to delete any old, now unregistered thumbnail files.","type":"boolean","default":false,"required":false},"update_usages_in_posts":{"description":"Whether to update the image tags in any posts that make use of this attachment.","type":"boolean","default":true,"required":false},"update_usages_in_posts_post_type":{"description":"The types of posts to update. Defaults to all public post types.","type":"array","default":[],"required":false},"update_usages_in_posts_post_ids":{"description":"Specific post IDs to update rather than any posts that use this attachment.","type":"array","default":[],"required":false},"update_usages_in_posts_posts_per_loop":{"description":"Posts to process per loop. This is to control memory usage and you likely don't need to adjust this.","type":"integer","default":10,"required":false}}}]},"\/regenerate-thumbnails\/v1\/attachmentinfo\/(?P<id>[\\d]+)":{"namespace":"regenerate-thumbnails\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/regenerate-thumbnails\/v1\/featuredimages":{"namespace":"regenerate-thumbnails\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"Laman koleksi saat ini.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Jumlah maksimal item yang akan dimunculkan dalam kumpulan hasil.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/regenerate-thumbnails\/v1\/featuredimages"}]}},"\/wp\/v2":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp\/v2","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/wp\/v2"}]}},"\/wp\/v2\/posts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Laman koleksi saat ini.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Jumlah maksimal item yang akan dimunculkan dalam kumpulan hasil.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Batas hasil yang sesuai dengan sebuah untaian.","type":"string","required":false},"after":{"description":"Batasi tanggapan untuk pos-pos yang diterbitkan setelah tanggal tertentu sesuai ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Batasi tanggapan untuk artikel yang diubah setelah tanggal tertentu sesuai ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Batasi hasil untuk pos-pos dengan penulis tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Pastikan hasil mengecualikan pos-pos dengan penulis tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Batasi tanggapan untuk pos yang diterbitkan sebelum tanggal tertentu sesuai ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Batasi tanggapan untuk artikel yang diubah sebelum tanggal tertentu sesuai ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Pastikan kumpulan hasil mengecualikan ID tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Batasi kumpulan hasil untuk ID tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Cara menginterpretasikan input pencarian.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Imbangi hasil dengan jumlah item tertentu.","type":"integer","required":false},"order":{"description":"Urutkan atribut penyortiran naik atau menurun.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortir koleksi berdasarkan atribut artikel.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array pada nama kolom yang akan dicari.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Batasi hasil ke pos-pos yang memiliki status satu atau lebih.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"tax_relation":{"description":"Batasi hasil yang ditetapkan berdasarkan hubungan antara beberapa taksonomi.","type":"string","enum":["AND","OR"],"required":false},"categories":{"description":"Batasi hasil yang ditetapkan ke item dengan term spesifik yang ditetapkan dalam taksonomi categories.","type":["object","array"],"oneOf":[{"title":"Daftar ID Term","description":"Cocokkan term dengan ID yang terdaftar.","type":"array","items":{"type":"integer"}},{"title":"Kueri Taksonomi ID Term","description":"Jalankan sebuah kueri term tingkat lanjut.","type":"object","properties":{"terms":{"description":"ID Term","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Apakah akan memasukkan term turunan dalam term yang membatasi kumpulan hasil.","type":"boolean","default":false},"operator":{"description":"Apakah item harus diberikan akses ke semua atau salah satu term yang ditentukan.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"categories_exclude":{"description":"Batasi set hasil hanya untuk item yang memiliki istilah tertentu yang diterapkan di dalam taksonomi categories.","type":["object","array"],"oneOf":[{"title":"Daftar ID Term","description":"Cocokkan term dengan ID yang terdaftar.","type":"array","items":{"type":"integer"}},{"title":"Kueri Taksonomi ID Term","description":"Jalankan sebuah kueri term tingkat lanjut.","type":"object","properties":{"terms":{"description":"ID Term","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Apakah akan memasukkan term turunan dalam term yang membatasi kumpulan hasil.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"tags":{"description":"Batasi hasil yang ditetapkan ke item dengan term spesifik yang ditetapkan dalam taksonomi tags.","type":["object","array"],"oneOf":[{"title":"Daftar ID Term","description":"Cocokkan term dengan ID yang terdaftar.","type":"array","items":{"type":"integer"}},{"title":"Kueri Taksonomi ID Term","description":"Jalankan sebuah kueri term tingkat lanjut.","type":"object","properties":{"terms":{"description":"ID Term","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Apakah item harus diberikan akses ke semua atau salah satu term yang ditentukan.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"tags_exclude":{"description":"Batasi set hasil hanya untuk item yang memiliki istilah tertentu yang diterapkan di dalam taksonomi tags.","type":["object","array"],"oneOf":[{"title":"Daftar ID Term","description":"Cocokkan term dengan ID yang terdaftar.","type":"array","items":{"type":"integer"}},{"title":"Kueri Taksonomi ID Term","description":"Jalankan sebuah kueri term tingkat lanjut.","type":"object","properties":{"terms":{"description":"ID Term","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"sticky":{"description":"Batasi hasil hanya untuk item-item yang melekat.","type":"boolean","required":false},"format":{"description":"Batasi hasil pada item dengan satu atau lebih format yang ditetapkan.","type":"array","uniqueItems":true,"items":{"enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Tanggal saat pos dipublikasikan, dalam zona waktu situs.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Tanggal saat pos dipublikasikan, dalam GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Pengidentifikasi alfanumerik untuk pos sesuai dengan jenisnya.","type":"string","required":false},"status":{"description":"Status bernama untuk pos.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Kata sandi untuk melindungi akses atas konten dan ringkasan.","type":"string","required":false},"title":{"description":"Judul untuk pos.","type":"object","properties":{"raw":{"description":"Judul untuk pos, sebagaimana tersimpan dalam basis data.","type":"string","context":["edit"]},"rendered":{"description":"Judul HTML pos, diubah menjadi tampilan.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Konten untuk pos.","type":"object","properties":{"raw":{"description":"Konten pos, sesuai yang ada di basis data.","type":"string","context":["edit"]},"rendered":{"description":"Konten HTML untuk pos, diubah menjadi tampilan.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi dari format blok konten yang digunakan oleh pos.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Apakah konten dilindungi dengan kata sandi.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"ID penulis pos.","type":"integer","required":false},"excerpt":{"description":"Ringkasan untuk pos.","type":"object","properties":{"raw":{"description":"Ringkasan untuk pos, sesuai yang ada di basis data.","type":"string","context":["edit"]},"rendered":{"description":"Ringkasan HTML untuk pos, diubah menjadi tampilan.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Apakah ringkasan tersebut dilindungi dengan kata sandi.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"ID media unggulan untuk pos.","type":"integer","required":false},"comment_status":{"description":"Apakah komentar dibuka di pos atau tidak.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Apakah pos dapat ping atau tidak.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"Format pos.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Ruas-ruas meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"Apakah pos harus diperlakukan sebagai pos lekat atau tidak.","type":"boolean","required":false},"template":{"description":"Berkas tema yang dipakai untuk menampilkan pos.","type":"string","required":false},"categories":{"description":"Term diberikan untuk pos dalam taksonomi category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Term diberikan untuk pos dalam taksonomi post_tag.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/wp\/v2\/posts"}]}},"\/wp\/v2\/posts\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Pengidentifikasi unik untuk pos.","type":"integer","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Ganti panjang kutipan bawaan.","type":"integer","required":false},"password":{"description":"Kata sandi untuk pos jika pos tersebut dilindungi kata sandi.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Pengidentifikasi unik untuk pos.","type":"integer","required":false},"date":{"description":"Tanggal saat pos dipublikasikan, dalam zona waktu situs.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Tanggal saat pos dipublikasikan, dalam GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Pengidentifikasi alfanumerik untuk pos sesuai dengan jenisnya.","type":"string","required":false},"status":{"description":"Status bernama untuk pos.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Kata sandi untuk melindungi akses atas konten dan ringkasan.","type":"string","required":false},"title":{"description":"Judul untuk pos.","type":"object","properties":{"raw":{"description":"Judul untuk pos, sebagaimana tersimpan dalam basis data.","type":"string","context":["edit"]},"rendered":{"description":"Judul HTML pos, diubah menjadi tampilan.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Konten untuk pos.","type":"object","properties":{"raw":{"description":"Konten pos, sesuai yang ada di basis data.","type":"string","context":["edit"]},"rendered":{"description":"Konten HTML untuk pos, diubah menjadi tampilan.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi dari format blok konten yang digunakan oleh pos.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Apakah konten dilindungi dengan kata sandi.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"ID penulis pos.","type":"integer","required":false},"excerpt":{"description":"Ringkasan untuk pos.","type":"object","properties":{"raw":{"description":"Ringkasan untuk pos, sesuai yang ada di basis data.","type":"string","context":["edit"]},"rendered":{"description":"Ringkasan HTML untuk pos, diubah menjadi tampilan.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Apakah ringkasan tersebut dilindungi dengan kata sandi.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"ID media unggulan untuk pos.","type":"integer","required":false},"comment_status":{"description":"Apakah komentar dibuka di pos atau tidak.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Apakah pos dapat ping atau tidak.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"Format pos.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Ruas-ruas meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"Apakah pos harus diperlakukan sebagai pos lekat atau tidak.","type":"boolean","required":false},"template":{"description":"Berkas tema yang dipakai untuk menampilkan pos.","type":"string","required":false},"categories":{"description":"Term diberikan untuk pos dalam taksonomi category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Term diberikan untuk pos dalam taksonomi post_tag.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Pengidentifikasi unik untuk pos.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Apakah lewati Tempat Sampah dan paksakan penghapusan.","required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID induk revisi.","type":"integer","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Laman koleksi saat ini.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Jumlah maksimal item yang akan dimunculkan dalam kumpulan hasil.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Batas hasil yang sesuai dengan sebuah untaian.","type":"string","required":false},"exclude":{"description":"Pastikan kumpulan hasil mengecualikan ID tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Batasi kumpulan hasil untuk ID tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Imbangi hasil dengan jumlah item tertentu.","type":"integer","required":false},"order":{"description":"Urutkan atribut penyortiran naik atau menurun.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortir koleksi berdasarkan atribut objek.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID induk revisi.","type":"integer","required":false},"id":{"description":"Pengidentifikasi unik untuk revisi.","type":"integer","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"ID induk revisi.","type":"integer","required":false},"id":{"description":"Pengidentifikasi unik untuk revisi.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as revisions do not support trashing.","required":false}}}]},"\/wp\/v2\/posts\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID untuk induk penyimpanan otomatis.","type":"integer","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"ID untuk induk penyimpanan otomatis.","type":"integer","required":false},"date":{"description":"Tanggal saat pos dipublikasikan, dalam zona waktu situs.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Tanggal saat pos dipublikasikan, dalam GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Pengidentifikasi alfanumerik untuk pos sesuai dengan jenisnya.","type":"string","required":false},"status":{"description":"Status bernama untuk pos.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Kata sandi untuk melindungi akses atas konten dan ringkasan.","type":"string","required":false},"title":{"description":"Judul untuk pos.","type":"object","properties":{"raw":{"description":"Judul untuk pos, sebagaimana tersimpan dalam basis data.","type":"string","context":["edit"]},"rendered":{"description":"Judul HTML pos, diubah menjadi tampilan.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Konten untuk pos.","type":"object","properties":{"raw":{"description":"Konten pos, sesuai yang ada di basis data.","type":"string","context":["edit"]},"rendered":{"description":"Konten HTML untuk pos, diubah menjadi tampilan.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi dari format blok konten yang digunakan oleh pos.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Apakah konten dilindungi dengan kata sandi.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"ID penulis pos.","type":"integer","required":false},"excerpt":{"description":"Ringkasan untuk pos.","type":"object","properties":{"raw":{"description":"Ringkasan untuk pos, sesuai yang ada di basis data.","type":"string","context":["edit"]},"rendered":{"description":"Ringkasan HTML untuk pos, diubah menjadi tampilan.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Apakah ringkasan tersebut dilindungi dengan kata sandi.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"ID media unggulan untuk pos.","type":"integer","required":false},"comment_status":{"description":"Apakah komentar dibuka di pos atau tidak.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Apakah pos dapat ping atau tidak.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"Format pos.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Ruas-ruas meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"Apakah pos harus diperlakukan sebagai pos lekat atau tidak.","type":"boolean","required":false},"template":{"description":"Berkas tema yang dipakai untuk menampilkan pos.","type":"string","required":false},"categories":{"description":"Term diberikan untuk pos dalam taksonomi category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Term diberikan untuk pos dalam taksonomi post_tag.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID untuk induk penyimpanan otomatis.","type":"integer","required":false},"id":{"description":"ID penyimpanan otomatis.","type":"integer","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/pages":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Laman koleksi saat ini.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Jumlah maksimal item yang akan dimunculkan dalam kumpulan hasil.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Batas hasil yang sesuai dengan sebuah untaian.","type":"string","required":false},"after":{"description":"Batasi tanggapan untuk pos-pos yang diterbitkan setelah tanggal tertentu sesuai ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Batasi tanggapan untuk artikel yang diubah setelah tanggal tertentu sesuai ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Batasi hasil untuk pos-pos dengan penulis tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Pastikan hasil mengecualikan pos-pos dengan penulis tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Batasi tanggapan untuk pos yang diterbitkan sebelum tanggal tertentu sesuai ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Batasi tanggapan untuk artikel yang diubah sebelum tanggal tertentu sesuai ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Pastikan kumpulan hasil mengecualikan ID tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Batasi kumpulan hasil untuk ID tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Batasi hasil untuk pos-pos dengan nilai menu_order tertentu.","type":"integer","required":false},"search_semantics":{"description":"Cara menginterpretasikan input pencarian.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Imbangi hasil dengan jumlah item tertentu.","type":"integer","required":false},"order":{"description":"Urutkan atribut penyortiran naik atau menurun.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortir koleksi berdasarkan atribut artikel.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"parent":{"description":"Batasi hasil hanya untuk yang memiliki ID induk tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Batasi set hasil hanya untuk semua item selain item-item dengan ID induk tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Array pada nama kolom yang akan dicari.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Batasi hasil ke pos-pos yang memiliki status satu atau lebih.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Tanggal saat pos dipublikasikan, dalam zona waktu situs.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Tanggal saat pos dipublikasikan, dalam GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Pengidentifikasi alfanumerik untuk pos sesuai dengan jenisnya.","type":"string","required":false},"status":{"description":"Status bernama untuk pos.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Kata sandi untuk melindungi akses atas konten dan ringkasan.","type":"string","required":false},"parent":{"description":"ID induk pos.","type":"integer","required":false},"title":{"description":"Judul untuk pos.","type":"object","properties":{"raw":{"description":"Judul untuk pos, sebagaimana tersimpan dalam basis data.","type":"string","context":["edit"]},"rendered":{"description":"Judul HTML pos, diubah menjadi tampilan.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Konten untuk pos.","type":"object","properties":{"raw":{"description":"Konten pos, sesuai yang ada di basis data.","type":"string","context":["edit"]},"rendered":{"description":"Konten HTML untuk pos, diubah menjadi tampilan.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi dari format blok konten yang digunakan oleh pos.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Apakah konten dilindungi dengan kata sandi.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"ID penulis pos.","type":"integer","required":false},"excerpt":{"description":"Ringkasan untuk pos.","type":"object","properties":{"raw":{"description":"Ringkasan untuk pos, sesuai yang ada di basis data.","type":"string","context":["edit"]},"rendered":{"description":"Ringkasan HTML untuk pos, diubah menjadi tampilan.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Apakah ringkasan tersebut dilindungi dengan kata sandi.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"ID media unggulan untuk pos.","type":"integer","required":false},"comment_status":{"description":"Apakah komentar dibuka di pos atau tidak.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Apakah pos dapat ping atau tidak.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"Urutan artikel dalam kaitannya dengan artikel lain.","type":"integer","required":false},"meta":{"description":"Ruas-ruas meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Berkas tema yang dipakai untuk menampilkan pos.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/wp\/v2\/pages"}]}},"\/wp\/v2\/pages\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Pengidentifikasi unik untuk pos.","type":"integer","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Ganti panjang kutipan bawaan.","type":"integer","required":false},"password":{"description":"Kata sandi untuk pos jika pos tersebut dilindungi kata sandi.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Pengidentifikasi unik untuk pos.","type":"integer","required":false},"date":{"description":"Tanggal saat pos dipublikasikan, dalam zona waktu situs.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Tanggal saat pos dipublikasikan, dalam GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Pengidentifikasi alfanumerik untuk pos sesuai dengan jenisnya.","type":"string","required":false},"status":{"description":"Status bernama untuk pos.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Kata sandi untuk melindungi akses atas konten dan ringkasan.","type":"string","required":false},"parent":{"description":"ID induk pos.","type":"integer","required":false},"title":{"description":"Judul untuk pos.","type":"object","properties":{"raw":{"description":"Judul untuk pos, sebagaimana tersimpan dalam basis data.","type":"string","context":["edit"]},"rendered":{"description":"Judul HTML pos, diubah menjadi tampilan.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Konten untuk pos.","type":"object","properties":{"raw":{"description":"Konten pos, sesuai yang ada di basis data.","type":"string","context":["edit"]},"rendered":{"description":"Konten HTML untuk pos, diubah menjadi tampilan.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi dari format blok konten yang digunakan oleh pos.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Apakah konten dilindungi dengan kata sandi.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"ID penulis pos.","type":"integer","required":false},"excerpt":{"description":"Ringkasan untuk pos.","type":"object","properties":{"raw":{"description":"Ringkasan untuk pos, sesuai yang ada di basis data.","type":"string","context":["edit"]},"rendered":{"description":"Ringkasan HTML untuk pos, diubah menjadi tampilan.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Apakah ringkasan tersebut dilindungi dengan kata sandi.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"ID media unggulan untuk pos.","type":"integer","required":false},"comment_status":{"description":"Apakah komentar dibuka di pos atau tidak.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Apakah pos dapat ping atau tidak.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"Urutan artikel dalam kaitannya dengan artikel lain.","type":"integer","required":false},"meta":{"description":"Ruas-ruas meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Berkas tema yang dipakai untuk menampilkan pos.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Pengidentifikasi unik untuk pos.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Apakah lewati Tempat Sampah dan paksakan penghapusan.","required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID induk revisi.","type":"integer","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Laman koleksi saat ini.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Jumlah maksimal item yang akan dimunculkan dalam kumpulan hasil.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Batas hasil yang sesuai dengan sebuah untaian.","type":"string","required":false},"exclude":{"description":"Pastikan kumpulan hasil mengecualikan ID tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Batasi kumpulan hasil untuk ID tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Imbangi hasil dengan jumlah item tertentu.","type":"integer","required":false},"order":{"description":"Urutkan atribut penyortiran naik atau menurun.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortir koleksi berdasarkan atribut objek.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID induk revisi.","type":"integer","required":false},"id":{"description":"Pengidentifikasi unik untuk revisi.","type":"integer","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"ID induk revisi.","type":"integer","required":false},"id":{"description":"Pengidentifikasi unik untuk revisi.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as revisions do not support trashing.","required":false}}}]},"\/wp\/v2\/pages\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID untuk induk penyimpanan otomatis.","type":"integer","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"ID induk pos.","type":"integer","required":false},"date":{"description":"Tanggal saat pos dipublikasikan, dalam zona waktu situs.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Tanggal saat pos dipublikasikan, dalam GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Pengidentifikasi alfanumerik untuk pos sesuai dengan jenisnya.","type":"string","required":false},"status":{"description":"Status bernama untuk pos.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Kata sandi untuk melindungi akses atas konten dan ringkasan.","type":"string","required":false},"title":{"description":"Judul untuk pos.","type":"object","properties":{"raw":{"description":"Judul untuk pos, sebagaimana tersimpan dalam basis data.","type":"string","context":["edit"]},"rendered":{"description":"Judul HTML pos, diubah menjadi tampilan.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Konten untuk pos.","type":"object","properties":{"raw":{"description":"Konten pos, sesuai yang ada di basis data.","type":"string","context":["edit"]},"rendered":{"description":"Konten HTML untuk pos, diubah menjadi tampilan.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi dari format blok konten yang digunakan oleh pos.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Apakah konten dilindungi dengan kata sandi.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"ID penulis pos.","type":"integer","required":false},"excerpt":{"description":"Ringkasan untuk pos.","type":"object","properties":{"raw":{"description":"Ringkasan untuk pos, sesuai yang ada di basis data.","type":"string","context":["edit"]},"rendered":{"description":"Ringkasan HTML untuk pos, diubah menjadi tampilan.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Apakah ringkasan tersebut dilindungi dengan kata sandi.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"ID media unggulan untuk pos.","type":"integer","required":false},"comment_status":{"description":"Apakah komentar dibuka di pos atau tidak.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Apakah pos dapat ping atau tidak.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"Urutan artikel dalam kaitannya dengan artikel lain.","type":"integer","required":false},"meta":{"description":"Ruas-ruas meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Berkas tema yang dipakai untuk menampilkan pos.","type":"string","required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID untuk induk penyimpanan otomatis.","type":"integer","required":false},"id":{"description":"ID penyimpanan otomatis.","type":"integer","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/media":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Laman koleksi saat ini.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Jumlah maksimal item yang akan dimunculkan dalam kumpulan hasil.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Batas hasil yang sesuai dengan sebuah untaian.","type":"string","required":false},"after":{"description":"Batasi tanggapan untuk pos-pos yang diterbitkan setelah tanggal tertentu sesuai ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Batasi tanggapan untuk artikel yang diubah setelah tanggal tertentu sesuai ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Batasi hasil untuk pos-pos dengan penulis tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Pastikan hasil mengecualikan pos-pos dengan penulis tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Batasi tanggapan untuk pos yang diterbitkan sebelum tanggal tertentu sesuai ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Batasi tanggapan untuk artikel yang diubah sebelum tanggal tertentu sesuai ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Pastikan kumpulan hasil mengecualikan ID tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Batasi kumpulan hasil untuk ID tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Cara menginterpretasikan input pencarian.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Imbangi hasil dengan jumlah item tertentu.","type":"integer","required":false},"order":{"description":"Urutkan atribut penyortiran naik atau menurun.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortir koleksi berdasarkan atribut artikel.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"parent":{"description":"Batasi hasil hanya untuk yang memiliki ID induk tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Batasi set hasil hanya untuk semua item selain item-item dengan ID induk tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Array pada nama kolom yang akan dicari.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"inherit","description":"Batasi hasil ke pos-pos yang memiliki status satu atau lebih.","type":"array","items":{"enum":["inherit","private","trash"],"type":"string"},"required":false},"media_type":{"default":null,"description":"Batasi hasil untuk lampiran dengan tipe media tertentu.","type":"string","enum":["image","video","audio","application","font"],"required":false},"mime_type":{"default":null,"description":"Batasi hasil untuk lampiran dengan tipe MIME tertentu.","type":"string","required":false}}},{"methods":["POST"],"args":{"date":{"description":"Tanggal saat pos dipublikasikan, dalam zona waktu situs.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Tanggal saat pos dipublikasikan, dalam GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Pengidentifikasi alfanumerik untuk pos sesuai dengan jenisnya.","type":"string","required":false},"status":{"description":"Status bernama untuk pos.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"title":{"description":"Judul untuk pos.","type":"object","properties":{"raw":{"description":"Judul untuk pos, sebagaimana tersimpan dalam basis data.","type":"string","context":["edit"]},"rendered":{"description":"Judul HTML pos, diubah menjadi tampilan.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"ID penulis pos.","type":"integer","required":false},"featured_media":{"description":"ID media unggulan untuk pos.","type":"integer","required":false},"comment_status":{"description":"Apakah komentar dibuka di pos atau tidak.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Apakah pos dapat ping atau tidak.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Ruas-ruas meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Berkas tema yang dipakai untuk menampilkan pos.","type":"string","required":false},"alt_text":{"description":"Teks alternatif untuk ditampilkan ketika lampiran tidak ditampilkan.","type":"string","required":false},"caption":{"description":"Penjelas lampiran.","type":"object","properties":{"raw":{"description":"Penjelas untuk lampiran, yang tersimpan dalam basis data.","type":"string","context":["edit"]},"rendered":{"description":"Penjelas HTML untuk lampiran, ditransformasikan untuk penampilan.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Deskripsi lampiran.","type":"object","properties":{"raw":{"description":"Deskripsi lampiran, sesuai yang ada di basis data.","type":"string","context":["edit"]},"rendered":{"description":"Deskripsi HTML lampiran, diubah menjadi tampilan.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"ID dari pos dengan lampiran yang terkait.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/wp\/v2\/media"}]}},"\/wp\/v2\/media\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Pengidentifikasi unik untuk pos.","type":"integer","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Pengidentifikasi unik untuk pos.","type":"integer","required":false},"date":{"description":"Tanggal saat pos dipublikasikan, dalam zona waktu situs.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Tanggal saat pos dipublikasikan, dalam GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Pengidentifikasi alfanumerik untuk pos sesuai dengan jenisnya.","type":"string","required":false},"status":{"description":"Status bernama untuk pos.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"title":{"description":"Judul untuk pos.","type":"object","properties":{"raw":{"description":"Judul untuk pos, sebagaimana tersimpan dalam basis data.","type":"string","context":["edit"]},"rendered":{"description":"Judul HTML pos, diubah menjadi tampilan.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"ID penulis pos.","type":"integer","required":false},"featured_media":{"description":"ID media unggulan untuk pos.","type":"integer","required":false},"comment_status":{"description":"Apakah komentar dibuka di pos atau tidak.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Apakah pos dapat ping atau tidak.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Ruas-ruas meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Berkas tema yang dipakai untuk menampilkan pos.","type":"string","required":false},"alt_text":{"description":"Teks alternatif untuk ditampilkan ketika lampiran tidak ditampilkan.","type":"string","required":false},"caption":{"description":"Penjelas lampiran.","type":"object","properties":{"raw":{"description":"Penjelas untuk lampiran, yang tersimpan dalam basis data.","type":"string","context":["edit"]},"rendered":{"description":"Penjelas HTML untuk lampiran, ditransformasikan untuk penampilan.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Deskripsi lampiran.","type":"object","properties":{"raw":{"description":"Deskripsi lampiran, sesuai yang ada di basis data.","type":"string","context":["edit"]},"rendered":{"description":"Deskripsi HTML lampiran, diubah menjadi tampilan.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"ID dari pos dengan lampiran yang terkait.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Pengidentifikasi unik untuk pos.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Apakah lewati Tempat Sampah dan paksakan penghapusan.","required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/post-process":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Pengidentifikasi unik untuk lampiran.","type":"integer","required":false},"action":{"type":"string","enum":["create-image-subsizes"],"required":true}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/edit":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"src":{"description":"URL dari berkas gambar yang diedit.","type":"string","format":"uri","required":true},"modifiers":{"description":"Array pengeditan gambar.","type":"array","minItems":1,"items":{"description":"Edit gambar","type":"object","required":["type","args"],"oneOf":[{"title":"Rotasi","properties":{"type":{"description":"Jenis rotasi.","type":"string","enum":["rotate"]},"args":{"description":"Argumen rotasi.","type":"object","required":["angle"],"properties":{"angle":{"description":"Sudut untuk memutar searah jarum jam dalam derajat.","type":"number"}}}}},{"title":"Potong","properties":{"type":{"description":"Tipe potong.","type":"string","enum":["crop"]},"args":{"description":"Argumen potong.","type":"object","required":["left","top","width","height"],"properties":{"left":{"description":"Posisi horisontal dari kiri untuk memulai pemangkasan dalam persentase dari lebar gambar.","type":"number"},"top":{"description":"Posisi vertikal dari atas untuk memulai pemangkasan dalam persentase dari tinggi gambar.","type":"number"},"width":{"description":"Lebar pemotongan dalam persentase dari lebar gambar.","type":"number"},"height":{"description":"Tinggi pemotongan dalam persentase dari tinggi gambar.","type":"number"}}}}}]},"required":false},"rotation":{"description":"Jumlah untuk memutar gambar searah jarum jam dalam derajat. USANG: Gunakan `modifiers ` sebagai gantinya.","type":"integer","minimum":0,"exclusiveMinimum":true,"maximum":360,"exclusiveMaximum":true,"required":false},"x":{"description":"Dalam persentase dari gambar, posisi x untuk memulai pemotongan. USANG: Gunakan `modifiers ` sebagai gantinya.","type":"number","minimum":0,"maximum":100,"required":false},"y":{"description":"Dalam persentase dari gambar, posisi y untuk memulai pemotongan. USANG: Gunakan `modifiers ` sebagai gantinya.","type":"number","minimum":0,"maximum":100,"required":false},"width":{"description":"Dalam persentase dari gambar, lebar untuk memotong gambar. USANG: Gunakan `modifiers` sebagai gantinya.","type":"number","minimum":0,"maximum":100,"required":false},"height":{"description":"Dalam persentase dari gambar, tinggi untuk memotong gambar. USANG: Gunakan `modifiers` sebagai gantinya.","type":"number","minimum":0,"maximum":100,"required":false}}}]},"\/wp\/v2\/menu-items":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Laman koleksi saat ini.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Jumlah maksimal item yang akan dimunculkan dalam kumpulan hasil.","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"Batas hasil yang sesuai dengan sebuah untaian.","type":"string","required":false},"after":{"description":"Batasi tanggapan untuk pos-pos yang diterbitkan setelah tanggal tertentu sesuai ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Batasi tanggapan untuk artikel yang diubah setelah tanggal tertentu sesuai ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Batasi tanggapan untuk pos yang diterbitkan sebelum tanggal tertentu sesuai ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Batasi tanggapan untuk artikel yang diubah sebelum tanggal tertentu sesuai ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Pastikan kumpulan hasil mengecualikan ID tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Batasi kumpulan hasil untuk ID tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Cara menginterpretasikan input pencarian.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Imbangi hasil dengan jumlah item tertentu.","type":"integer","required":false},"order":{"description":"Urutkan atribut penyortiran naik atau menurun.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortir koleksi berdasarkan atribut objek.","type":"string","default":"menu_order","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Array pada nama kolom yang akan dicari.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Batasi hasil ke pos-pos yang memiliki status satu atau lebih.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"tax_relation":{"description":"Batasi hasil yang ditetapkan berdasarkan hubungan antara beberapa taksonomi.","type":"string","enum":["AND","OR"],"required":false},"menus":{"description":"Batasi hasil yang ditetapkan ke item dengan term spesifik yang ditetapkan dalam taksonomi menus.","type":["object","array"],"oneOf":[{"title":"Daftar ID Term","description":"Cocokkan term dengan ID yang terdaftar.","type":"array","items":{"type":"integer"}},{"title":"Kueri Taksonomi ID Term","description":"Jalankan sebuah kueri term tingkat lanjut.","type":"object","properties":{"terms":{"description":"ID Term","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Apakah item harus diberikan akses ke semua atau salah satu term yang ditentukan.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"menus_exclude":{"description":"Batasi set hasil hanya untuk item yang memiliki istilah tertentu yang diterapkan di dalam taksonomi menus.","type":["object","array"],"oneOf":[{"title":"Daftar ID Term","description":"Cocokkan term dengan ID yang terdaftar.","type":"array","items":{"type":"integer"}},{"title":"Kueri Taksonomi ID Term","description":"Jalankan sebuah kueri term tingkat lanjut.","type":"object","properties":{"terms":{"description":"ID Term","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"menu_order":{"description":"Batasi hasil untuk pos-pos dengan nilai menu_order tertentu.","type":"integer","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"title":{"description":"Judul untuk objek tersebut.","type":["string","object"],"properties":{"raw":{"description":"Judul untuk objek, sebagaimana tersimpan dalam basis data.","type":"string","context":["edit"]},"rendered":{"description":"Judul HTML untuk objek, ditransformasikan untuk tampilan.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"default":"custom","description":"Kelompok objek yang awalnya direpresentasikan, seperti \"tipe_artikel\" atau \"taksonomi\".","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"default":"publish","description":"Status bernama untuk objek.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"parent":{"default":0,"description":"ID untuk induk objek.","type":"integer","minimum":0,"required":false},"attr_title":{"description":"Teks untuk atribut judul pada elemen tautan untuk item menu berikut. ","type":"string","required":false},"classes":{"description":"Nama kelas untuk elemen tautan pada item menu berikut.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"Deskripsi item menu.","type":"string","required":false},"menu_order":{"default":1,"description":"ID BD nav_menu_item yang merupakan item menu induk berikut, jika ada; jika tidak, nilainya 0. ","type":"integer","minimum":1,"required":false},"object":{"description":"Jenis objek yang awalnya direpresentasikan, seperti \"kategori\", \"artikel\", atau \"lampiran\".","type":"string","required":false},"object_id":{"default":0,"description":"ID database dari objek asli yang tampil di menu, contohnya ID artikel atau term_id untuk kategori.","type":"integer","minimum":0,"required":false},"target":{"description":"Atribut target dari elemen tautan untuk item menu berikut.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"URL yang ditunjuk item menu berikut.","type":"string","format":"uri","required":false},"xfn":{"description":"Hubungan XFN yang ditunjukkan dalam tautan item menu berikut.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Istilah yang ditentukan untuk objek di dalam taksonomi nav_menu.","type":"integer","required":false},"meta":{"description":"Ruas-ruas meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/wp\/v2\/menu-items"}]}},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Pengidentifikasi unik untuk pos.","type":"integer","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Pengidentifikasi unik untuk pos.","type":"integer","required":false},"title":{"description":"Judul untuk objek tersebut.","type":["string","object"],"properties":{"raw":{"description":"Judul untuk objek, sebagaimana tersimpan dalam basis data.","type":"string","context":["edit"]},"rendered":{"description":"Judul HTML untuk objek, ditransformasikan untuk tampilan.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"Kelompok objek yang awalnya direpresentasikan, seperti \"tipe_artikel\" atau \"taksonomi\".","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"Status bernama untuk objek.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"parent":{"description":"ID untuk induk objek.","type":"integer","minimum":0,"required":false},"attr_title":{"description":"Teks untuk atribut judul pada elemen tautan untuk item menu berikut. ","type":"string","required":false},"classes":{"description":"Nama kelas untuk elemen tautan pada item menu berikut.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"Deskripsi item menu.","type":"string","required":false},"menu_order":{"description":"ID BD nav_menu_item yang merupakan item menu induk berikut, jika ada; jika tidak, nilainya 0. ","type":"integer","minimum":1,"required":false},"object":{"description":"Jenis objek yang awalnya direpresentasikan, seperti \"kategori\", \"artikel\", atau \"lampiran\".","type":"string","required":false},"object_id":{"description":"ID database dari objek asli yang tampil di menu, contohnya ID artikel atau term_id untuk kategori.","type":"integer","minimum":0,"required":false},"target":{"description":"Atribut target dari elemen tautan untuk item menu berikut.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"URL yang ditunjuk item menu berikut.","type":"string","format":"uri","required":false},"xfn":{"description":"Hubungan XFN yang ditunjukkan dalam tautan item menu berikut.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Istilah yang ditentukan untuk objek di dalam taksonomi nav_menu.","type":"integer","required":false},"meta":{"description":"Ruas-ruas meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""}},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Pengidentifikasi unik untuk pos.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Apakah lewati Tempat Sampah dan paksakan penghapusan.","required":false}}}]},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID untuk induk penyimpanan otomatis.","type":"integer","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"ID untuk induk objek.","type":"integer","minimum":0,"required":false},"title":{"description":"Judul untuk objek tersebut.","type":["string","object"],"properties":{"raw":{"description":"Judul untuk objek, sebagaimana tersimpan dalam basis data.","type":"string","context":["edit"]},"rendered":{"description":"Judul HTML untuk objek, ditransformasikan untuk tampilan.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"Kelompok objek yang awalnya direpresentasikan, seperti \"tipe_artikel\" atau \"taksonomi\".","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"Status bernama untuk objek.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"attr_title":{"description":"Teks untuk atribut judul pada elemen tautan untuk item menu berikut. ","type":"string","required":false},"classes":{"description":"Nama kelas untuk elemen tautan pada item menu berikut.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"Deskripsi item menu.","type":"string","required":false},"menu_order":{"description":"ID BD nav_menu_item yang merupakan item menu induk berikut, jika ada; jika tidak, nilainya 0. ","type":"integer","minimum":1,"required":false},"object":{"description":"Jenis objek yang awalnya direpresentasikan, seperti \"kategori\", \"artikel\", atau \"lampiran\".","type":"string","required":false},"object_id":{"description":"ID database dari objek asli yang tampil di menu, contohnya ID artikel atau term_id untuk kategori.","type":"integer","minimum":0,"required":false},"target":{"description":"Atribut target dari elemen tautan untuk item menu berikut.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"URL yang ditunjuk item menu berikut.","type":"string","format":"uri","required":false},"xfn":{"description":"Hubungan XFN yang ditunjukkan dalam tautan item menu berikut.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Istilah yang ditentukan untuk objek di dalam taksonomi nav_menu.","type":"integer","required":false},"meta":{"description":"Ruas-ruas meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""}},"required":false}}}]},"\/wp\/v2\/menu-items\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID untuk induk penyimpanan otomatis.","type":"integer","required":false},"id":{"description":"ID penyimpanan otomatis.","type":"integer","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/blocks":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Laman koleksi saat ini.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Jumlah maksimal item yang akan dimunculkan dalam kumpulan hasil.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Batas hasil yang sesuai dengan sebuah untaian.","type":"string","required":false},"after":{"description":"Batasi tanggapan untuk pos-pos yang diterbitkan setelah tanggal tertentu sesuai ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Batasi tanggapan untuk artikel yang diubah setelah tanggal tertentu sesuai ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Batasi tanggapan untuk pos yang diterbitkan sebelum tanggal tertentu sesuai ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Batasi tanggapan untuk artikel yang diubah sebelum tanggal tertentu sesuai ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Pastikan kumpulan hasil mengecualikan ID tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Batasi kumpulan hasil untuk ID tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Cara menginterpretasikan input pencarian.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Imbangi hasil dengan jumlah item tertentu.","type":"integer","required":false},"order":{"description":"Urutkan atribut penyortiran naik atau menurun.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortir koleksi berdasarkan atribut artikel.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array pada nama kolom yang akan dicari.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Batasi hasil ke pos-pos yang memiliki status satu atau lebih.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"tax_relation":{"description":"Batasi hasil yang ditetapkan berdasarkan hubungan antara beberapa taksonomi.","type":"string","enum":["AND","OR"],"required":false},"wp_pattern_category":{"description":"Batasi hasil yang ditetapkan ke item dengan term spesifik yang ditetapkan dalam taksonomi wp_pattern_category.","type":["object","array"],"oneOf":[{"title":"Daftar ID Term","description":"Cocokkan term dengan ID yang terdaftar.","type":"array","items":{"type":"integer"}},{"title":"Kueri Taksonomi ID Term","description":"Jalankan sebuah kueri term tingkat lanjut.","type":"object","properties":{"terms":{"description":"ID Term","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Apakah item harus diberikan akses ke semua atau salah satu term yang ditentukan.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"wp_pattern_category_exclude":{"description":"Batasi set hasil hanya untuk item yang memiliki istilah tertentu yang diterapkan di dalam taksonomi wp_pattern_category.","type":["object","array"],"oneOf":[{"title":"Daftar ID Term","description":"Cocokkan term dengan ID yang terdaftar.","type":"array","items":{"type":"integer"}},{"title":"Kueri Taksonomi ID Term","description":"Jalankan sebuah kueri term tingkat lanjut.","type":"object","properties":{"terms":{"description":"ID Term","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Tanggal saat pos dipublikasikan, dalam zona waktu situs.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Tanggal saat pos dipublikasikan, dalam GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Pengidentifikasi alfanumerik untuk pos sesuai dengan jenisnya.","type":"string","required":false},"status":{"description":"Status bernama untuk pos.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Kata sandi untuk melindungi akses atas konten dan ringkasan.","type":"string","required":false},"title":{"description":"Judul untuk pos.","type":"object","properties":{"raw":{"description":"Judul untuk pos, sebagaimana tersimpan dalam basis data.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"Konten untuk pos.","type":"object","properties":{"raw":{"description":"Konten pos, sesuai yang ada di basis data.","type":"string","context":["view","edit"]},"block_version":{"description":"Versi dari format blok konten yang digunakan oleh pos.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Apakah konten dilindungi dengan kata sandi.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"Ringkasan untuk pos.","type":"object","properties":{"raw":{"description":"Ringkasan untuk pos, sesuai yang ada di basis data.","type":"string","context":["edit"]},"rendered":{"description":"Ringkasan HTML untuk pos, diubah menjadi tampilan.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Apakah ringkasan tersebut dilindungi dengan kata sandi.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Ruas-ruas meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Berkas tema yang dipakai untuk menampilkan pos.","type":"string","required":false},"wp_pattern_category":{"description":"Term diberikan untuk pos dalam taksonomi wp_pattern_category.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/wp\/v2\/blocks"}]}},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Pengidentifikasi unik untuk pos.","type":"integer","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Ganti panjang kutipan bawaan.","type":"integer","required":false},"password":{"description":"Kata sandi untuk pos jika pos tersebut dilindungi kata sandi.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Pengidentifikasi unik untuk pos.","type":"integer","required":false},"date":{"description":"Tanggal saat pos dipublikasikan, dalam zona waktu situs.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Tanggal saat pos dipublikasikan, dalam GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Pengidentifikasi alfanumerik untuk pos sesuai dengan jenisnya.","type":"string","required":false},"status":{"description":"Status bernama untuk pos.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Kata sandi untuk melindungi akses atas konten dan ringkasan.","type":"string","required":false},"title":{"description":"Judul untuk pos.","type":"object","properties":{"raw":{"description":"Judul untuk pos, sebagaimana tersimpan dalam basis data.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"Konten untuk pos.","type":"object","properties":{"raw":{"description":"Konten pos, sesuai yang ada di basis data.","type":"string","context":["view","edit"]},"block_version":{"description":"Versi dari format blok konten yang digunakan oleh pos.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Apakah konten dilindungi dengan kata sandi.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"Ringkasan untuk pos.","type":"object","properties":{"raw":{"description":"Ringkasan untuk pos, sesuai yang ada di basis data.","type":"string","context":["edit"]},"rendered":{"description":"Ringkasan HTML untuk pos, diubah menjadi tampilan.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Apakah ringkasan tersebut dilindungi dengan kata sandi.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Ruas-ruas meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Berkas tema yang dipakai untuk menampilkan pos.","type":"string","required":false},"wp_pattern_category":{"description":"Term diberikan untuk pos dalam taksonomi wp_pattern_category.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Pengidentifikasi unik untuk pos.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Apakah lewati Tempat Sampah dan paksakan penghapusan.","required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID induk revisi.","type":"integer","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Laman koleksi saat ini.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Jumlah maksimal item yang akan dimunculkan dalam kumpulan hasil.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Batas hasil yang sesuai dengan sebuah untaian.","type":"string","required":false},"exclude":{"description":"Pastikan kumpulan hasil mengecualikan ID tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Batasi kumpulan hasil untuk ID tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Imbangi hasil dengan jumlah item tertentu.","type":"integer","required":false},"order":{"description":"Urutkan atribut penyortiran naik atau menurun.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortir koleksi berdasarkan atribut objek.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID induk revisi.","type":"integer","required":false},"id":{"description":"Pengidentifikasi unik untuk revisi.","type":"integer","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"ID induk revisi.","type":"integer","required":false},"id":{"description":"Pengidentifikasi unik untuk revisi.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as revisions do not support trashing.","required":false}}}]},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID untuk induk penyimpanan otomatis.","type":"integer","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"ID untuk induk penyimpanan otomatis.","type":"integer","required":false},"date":{"description":"Tanggal saat pos dipublikasikan, dalam zona waktu situs.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Tanggal saat pos dipublikasikan, dalam GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Pengidentifikasi alfanumerik untuk pos sesuai dengan jenisnya.","type":"string","required":false},"status":{"description":"Status bernama untuk pos.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Kata sandi untuk melindungi akses atas konten dan ringkasan.","type":"string","required":false},"title":{"description":"Judul untuk pos.","type":"object","properties":{"raw":{"description":"Judul untuk pos, sebagaimana tersimpan dalam basis data.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"Konten untuk pos.","type":"object","properties":{"raw":{"description":"Konten pos, sesuai yang ada di basis data.","type":"string","context":["view","edit"]},"block_version":{"description":"Versi dari format blok konten yang digunakan oleh pos.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Apakah konten dilindungi dengan kata sandi.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"Ringkasan untuk pos.","type":"object","properties":{"raw":{"description":"Ringkasan untuk pos, sesuai yang ada di basis data.","type":"string","context":["edit"]},"rendered":{"description":"Ringkasan HTML untuk pos, diubah menjadi tampilan.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Apakah ringkasan tersebut dilindungi dengan kata sandi.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Ruas-ruas meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Berkas tema yang dipakai untuk menampilkan pos.","type":"string","required":false},"wp_pattern_category":{"description":"Term diberikan untuk pos dalam taksonomi wp_pattern_category.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID untuk induk penyimpanan otomatis.","type":"integer","required":false},"id":{"description":"ID penyimpanan otomatis.","type":"integer","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID templat","type":"string","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Laman koleksi saat ini.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Jumlah maksimal item yang akan dimunculkan dalam kumpulan hasil.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Batas hasil yang sesuai dengan sebuah untaian.","type":"string","required":false},"exclude":{"description":"Pastikan kumpulan hasil mengecualikan ID tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Batasi kumpulan hasil untuk ID tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Imbangi hasil dengan jumlah item tertentu.","type":"integer","required":false},"order":{"description":"Urutkan atribut penyortiran naik atau menurun.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortir koleksi berdasarkan atribut objek.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID templat","type":"string","required":false},"id":{"description":"Pengidentifikasi unik untuk revisi.","type":"integer","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"ID templat","type":"string","required":false},"id":{"description":"Pengidentifikasi unik untuk revisi.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as revisions do not support trashing.","required":false}}}]},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"ID templat","type":"string","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"id":{"description":"ID templat","type":"string","required":false},"slug":{"description":"Slug unik yang mengidentifikasi jenis templat.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identifier tema untuk templat.","type":"string","required":false},"type":{"description":"Jenis templat.","type":"string","required":false},"content":{"description":"Isi templat.","type":["object","string"],"properties":{"raw":{"description":"Konten untuk template, sesuai dengan basis data.","type":"string","context":["view","edit"]},"block_version":{"description":"Versi format blok konten digunakan oleh template.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Judul templat.","type":["object","string"],"properties":{"raw":{"description":"Judul untuk template, sesuai dengan basis data.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Judul HTML untuk template (akan ditampilkan).","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Deskripsi templat.","type":"string","required":false},"status":{"description":"Status template","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"ID untuk pembuat template.","type":"integer","required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID templat","type":"string","required":false},"id":{"description":"ID penyimpanan otomatis.","type":"integer","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/templates":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"Batasi sampai id artikel yang disebutkan.","type":"integer","required":false},"area":{"description":"Batasi untuk area komponen template yang ditentukan.","type":"string","required":false},"post_type":{"description":"Tipe pos, di mana template akan digunakan.","type":"string","required":false}}},{"methods":["POST"],"args":{"slug":{"description":"Slug unik yang mengidentifikasi jenis templat.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"Identifier tema untuk templat.","type":"string","required":false},"type":{"description":"Jenis templat.","type":"string","required":false},"content":{"default":"","description":"Isi templat.","type":["object","string"],"properties":{"raw":{"description":"Konten untuk template, sesuai dengan basis data.","type":"string","context":["view","edit"]},"block_version":{"description":"Versi format blok konten digunakan oleh template.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"Judul templat.","type":["object","string"],"properties":{"raw":{"description":"Judul untuk template, sesuai dengan basis data.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Judul HTML untuk template (akan ditampilkan).","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"Deskripsi templat.","type":"string","required":false},"status":{"default":"publish","description":"Status template","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"ID untuk pembuat template.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/wp\/v2\/templates"}]}},"\/wp\/v2\/templates\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Slug templat yang akan mendapatkan \"fallback\"","type":"string","required":true},"is_custom":{"description":"Menunjukkan jika templat adalah kustom atau bagian dari hierarki templat","type":"boolean","required":false},"template_prefix":{"description":"Prefiks templat untuk templat yang dibuat. Ini digunakan untuk mengekstrak jenis templat utama, mis. pada 'taksonomi-buku' kami mengekstraksi 'taksonomi'","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/wp\/v2\/templates\/lookup"}]}},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"ID templat","type":"string","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"ID templat","type":"string","required":false},"slug":{"description":"Slug unik yang mengidentifikasi jenis templat.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identifier tema untuk templat.","type":"string","required":false},"type":{"description":"Jenis templat.","type":"string","required":false},"content":{"description":"Isi templat.","type":["object","string"],"properties":{"raw":{"description":"Konten untuk template, sesuai dengan basis data.","type":"string","context":["view","edit"]},"block_version":{"description":"Versi format blok konten digunakan oleh template.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Judul templat.","type":["object","string"],"properties":{"raw":{"description":"Judul untuk template, sesuai dengan basis data.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Judul HTML untuk template (akan ditampilkan).","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Deskripsi templat.","type":"string","required":false},"status":{"description":"Status template","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"ID untuk pembuat template.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"ID templat","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"Apakah lewati Tempat Sampah dan paksakan penghapusan.","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID templat","type":"string","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Laman koleksi saat ini.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Jumlah maksimal item yang akan dimunculkan dalam kumpulan hasil.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Batas hasil yang sesuai dengan sebuah untaian.","type":"string","required":false},"exclude":{"description":"Pastikan kumpulan hasil mengecualikan ID tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Batasi kumpulan hasil untuk ID tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Imbangi hasil dengan jumlah item tertentu.","type":"integer","required":false},"order":{"description":"Urutkan atribut penyortiran naik atau menurun.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortir koleksi berdasarkan atribut objek.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID templat","type":"string","required":false},"id":{"description":"Pengidentifikasi unik untuk revisi.","type":"integer","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"ID templat","type":"string","required":false},"id":{"description":"Pengidentifikasi unik untuk revisi.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as revisions do not support trashing.","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"ID templat","type":"string","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"id":{"description":"ID templat","type":"string","required":false},"slug":{"description":"Slug unik yang mengidentifikasi jenis templat.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identifier tema untuk templat.","type":"string","required":false},"type":{"description":"Jenis templat.","type":"string","required":false},"content":{"description":"Isi templat.","type":["object","string"],"properties":{"raw":{"description":"Konten untuk template, sesuai dengan basis data.","type":"string","context":["view","edit"]},"block_version":{"description":"Versi format blok konten digunakan oleh template.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Judul templat.","type":["object","string"],"properties":{"raw":{"description":"Judul untuk template, sesuai dengan basis data.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Judul HTML untuk template (akan ditampilkan).","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Deskripsi templat.","type":"string","required":false},"status":{"description":"Status template","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"ID untuk pembuat template.","type":"integer","required":false},"area":{"description":"Di mana komponen template akan digunakan (header, footer, dll.)","type":"string","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID templat","type":"string","required":false},"id":{"description":"ID penyimpanan otomatis.","type":"integer","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/template-parts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"Batasi sampai id artikel yang disebutkan.","type":"integer","required":false},"area":{"description":"Batasi untuk area komponen template yang ditentukan.","type":"string","required":false},"post_type":{"description":"Tipe pos, di mana template akan digunakan.","type":"string","required":false}}},{"methods":["POST"],"args":{"slug":{"description":"Slug unik yang mengidentifikasi jenis templat.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"Identifier tema untuk templat.","type":"string","required":false},"type":{"description":"Jenis templat.","type":"string","required":false},"content":{"default":"","description":"Isi templat.","type":["object","string"],"properties":{"raw":{"description":"Konten untuk template, sesuai dengan basis data.","type":"string","context":["view","edit"]},"block_version":{"description":"Versi format blok konten digunakan oleh template.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"Judul templat.","type":["object","string"],"properties":{"raw":{"description":"Judul untuk template, sesuai dengan basis data.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Judul HTML untuk template (akan ditampilkan).","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"Deskripsi templat.","type":"string","required":false},"status":{"default":"publish","description":"Status template","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"ID untuk pembuat template.","type":"integer","required":false},"area":{"description":"Di mana komponen template akan digunakan (header, footer, dll.)","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/wp\/v2\/template-parts"}]}},"\/wp\/v2\/template-parts\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Slug templat yang akan mendapatkan \"fallback\"","type":"string","required":true},"is_custom":{"description":"Menunjukkan jika templat adalah kustom atau bagian dari hierarki templat","type":"boolean","required":false},"template_prefix":{"description":"Prefiks templat untuk templat yang dibuat. Ini digunakan untuk mengekstrak jenis templat utama, mis. pada 'taksonomi-buku' kami mengekstraksi 'taksonomi'","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/wp\/v2\/template-parts\/lookup"}]}},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"ID templat","type":"string","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"ID templat","type":"string","required":false},"slug":{"description":"Slug unik yang mengidentifikasi jenis templat.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identifier tema untuk templat.","type":"string","required":false},"type":{"description":"Jenis templat.","type":"string","required":false},"content":{"description":"Isi templat.","type":["object","string"],"properties":{"raw":{"description":"Konten untuk template, sesuai dengan basis data.","type":"string","context":["view","edit"]},"block_version":{"description":"Versi format blok konten digunakan oleh template.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Judul templat.","type":["object","string"],"properties":{"raw":{"description":"Judul untuk template, sesuai dengan basis data.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Judul HTML untuk template (akan ditampilkan).","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Deskripsi templat.","type":"string","required":false},"status":{"description":"Status template","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"ID untuk pembuat template.","type":"integer","required":false},"area":{"description":"Di mana komponen template akan digunakan (header, footer, dll.)","type":"string","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"ID templat","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"Apakah lewati Tempat Sampah dan paksakan penghapusan.","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID induk revisi.","type":"integer","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Laman koleksi saat ini.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Jumlah maksimal item yang akan dimunculkan dalam kumpulan hasil.","type":"integer","minimum":1,"maximum":100,"required":false},"offset":{"description":"Imbangi hasil dengan jumlah item tertentu.","type":"integer","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID untuk induk revisi gaya global.","type":"integer","required":false},"id":{"description":"Pengenal unik untuk revisi gaya global.","type":"integer","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[\\\/\\s%\\w\\.\\(\\)\\[\\]\\@_\\-]+)\/variations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"Pengidentifikasi tema","type":"string","required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"Pengidentifikasi tema","type":"string","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<id>[\\\/\\w-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"id":{"description":"ID templat","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":false},"args":{"styles":{"description":"Gaya global.","type":["object"],"required":false},"settings":{"description":"Pengaturan global.","type":["object"],"required":false},"title":{"description":"Judul variasi pengaturan global.","type":["object","string"],"properties":{"raw":{"description":"Judul variasi pengaturan global, sesuai yang ada di basis data.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Judul HTML pos, diubah menjadi tampilan.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false}}}]},"\/wp\/v2\/navigation":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Laman koleksi saat ini.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Jumlah maksimal item yang akan dimunculkan dalam kumpulan hasil.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Batas hasil yang sesuai dengan sebuah untaian.","type":"string","required":false},"after":{"description":"Batasi tanggapan untuk pos-pos yang diterbitkan setelah tanggal tertentu sesuai ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Batasi tanggapan untuk artikel yang diubah setelah tanggal tertentu sesuai ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Batasi tanggapan untuk pos yang diterbitkan sebelum tanggal tertentu sesuai ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Batasi tanggapan untuk artikel yang diubah sebelum tanggal tertentu sesuai ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Pastikan kumpulan hasil mengecualikan ID tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Batasi kumpulan hasil untuk ID tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Cara menginterpretasikan input pencarian.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Imbangi hasil dengan jumlah item tertentu.","type":"integer","required":false},"order":{"description":"Urutkan atribut penyortiran naik atau menurun.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortir koleksi berdasarkan atribut artikel.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array pada nama kolom yang akan dicari.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Batasi hasil ke pos-pos yang memiliki status satu atau lebih.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Tanggal saat pos dipublikasikan, dalam zona waktu situs.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Tanggal saat pos dipublikasikan, dalam GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Pengidentifikasi alfanumerik untuk pos sesuai dengan jenisnya.","type":"string","required":false},"status":{"description":"Status bernama untuk pos.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Kata sandi untuk melindungi akses atas konten dan ringkasan.","type":"string","required":false},"title":{"description":"Judul untuk pos.","type":"object","properties":{"raw":{"description":"Judul untuk pos, sebagaimana tersimpan dalam basis data.","type":"string","context":["edit","embed"]},"rendered":{"description":"Judul HTML pos, diubah menjadi tampilan.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Konten untuk pos.","type":"object","properties":{"raw":{"description":"Konten pos, sesuai yang ada di basis data.","type":"string","context":["edit","embed"]},"rendered":{"description":"Konten HTML untuk pos, diubah menjadi tampilan.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Versi dari format blok konten yang digunakan oleh pos.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Apakah konten dilindungi dengan kata sandi.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Ruas-ruas meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Berkas tema yang dipakai untuk menampilkan pos.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/wp\/v2\/navigation"}]}},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Pengidentifikasi unik untuk pos.","type":"integer","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Kata sandi untuk pos jika pos tersebut dilindungi kata sandi.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Pengidentifikasi unik untuk pos.","type":"integer","required":false},"date":{"description":"Tanggal saat pos dipublikasikan, dalam zona waktu situs.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Tanggal saat pos dipublikasikan, dalam GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Pengidentifikasi alfanumerik untuk pos sesuai dengan jenisnya.","type":"string","required":false},"status":{"description":"Status bernama untuk pos.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Kata sandi untuk melindungi akses atas konten dan ringkasan.","type":"string","required":false},"title":{"description":"Judul untuk pos.","type":"object","properties":{"raw":{"description":"Judul untuk pos, sebagaimana tersimpan dalam basis data.","type":"string","context":["edit","embed"]},"rendered":{"description":"Judul HTML pos, diubah menjadi tampilan.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Konten untuk pos.","type":"object","properties":{"raw":{"description":"Konten pos, sesuai yang ada di basis data.","type":"string","context":["edit","embed"]},"rendered":{"description":"Konten HTML untuk pos, diubah menjadi tampilan.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Versi dari format blok konten yang digunakan oleh pos.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Apakah konten dilindungi dengan kata sandi.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Ruas-ruas meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Berkas tema yang dipakai untuk menampilkan pos.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Pengidentifikasi unik untuk pos.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Apakah lewati Tempat Sampah dan paksakan penghapusan.","required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID induk revisi.","type":"integer","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Laman koleksi saat ini.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Jumlah maksimal item yang akan dimunculkan dalam kumpulan hasil.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Batas hasil yang sesuai dengan sebuah untaian.","type":"string","required":false},"exclude":{"description":"Pastikan kumpulan hasil mengecualikan ID tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Batasi kumpulan hasil untuk ID tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Imbangi hasil dengan jumlah item tertentu.","type":"integer","required":false},"order":{"description":"Urutkan atribut penyortiran naik atau menurun.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortir koleksi berdasarkan atribut objek.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID induk revisi.","type":"integer","required":false},"id":{"description":"Pengidentifikasi unik untuk revisi.","type":"integer","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"ID induk revisi.","type":"integer","required":false},"id":{"description":"Pengidentifikasi unik untuk revisi.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Required to be true, as revisions do not support trashing.","required":false}}}]},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID untuk induk penyimpanan otomatis.","type":"integer","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"ID untuk induk penyimpanan otomatis.","type":"integer","required":false},"date":{"description":"Tanggal saat pos dipublikasikan, dalam zona waktu situs.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Tanggal saat pos dipublikasikan, dalam GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Pengidentifikasi alfanumerik untuk pos sesuai dengan jenisnya.","type":"string","required":false},"status":{"description":"Status bernama untuk pos.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Kata sandi untuk melindungi akses atas konten dan ringkasan.","type":"string","required":false},"title":{"description":"Judul untuk pos.","type":"object","properties":{"raw":{"description":"Judul untuk pos, sebagaimana tersimpan dalam basis data.","type":"string","context":["edit","embed"]},"rendered":{"description":"Judul HTML pos, diubah menjadi tampilan.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Konten untuk pos.","type":"object","properties":{"raw":{"description":"Konten pos, sesuai yang ada di basis data.","type":"string","context":["edit","embed"]},"rendered":{"description":"Konten HTML untuk pos, diubah menjadi tampilan.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Versi dari format blok konten yang digunakan oleh pos.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Apakah konten dilindungi dengan kata sandi.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Ruas-ruas meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Berkas tema yang dipakai untuk menampilkan pos.","type":"string","required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID untuk induk penyimpanan otomatis.","type":"integer","required":false},"id":{"description":"ID penyimpanan otomatis.","type":"integer","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/font-families":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Laman koleksi saat ini.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Jumlah maksimal item yang akan dimunculkan dalam kumpulan hasil.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"Pastikan kumpulan hasil mengecualikan ID tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Batasi kumpulan hasil untuk ID tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Cara menginterpretasikan input pencarian.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Imbangi hasil dengan jumlah item tertentu.","type":"integer","required":false},"order":{"description":"Urutkan atribut penyortiran naik atau menurun.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortir koleksi berdasarkan atribut artikel.","type":"string","default":"id","enum":["id","include"],"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"theme_json_version":{"description":"Versi skema theme.json yang digunakan untuk pengaturan tipografi.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"deklarasi font-family dalam format theme.json, dikodekan sebagai string.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/wp\/v2\/font-families"}]}},"\/wp\/v2\/font-families\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Pengidentifikasi unik untuk pos.","type":"integer","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Pengidentifikasi unik untuk pos.","type":"integer","required":false},"theme_json_version":{"description":"Versi skema theme.json yang digunakan untuk pengaturan tipografi.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"deklarasi font-family dalam format theme.json, dikodekan sebagai string.","type":"string","required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Pengidentifikasi unik untuk pos.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Apakah lewati Tempat Sampah dan paksakan penghapusan.","required":false}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"ID untuk kelompok font induk pada tampilan font.","type":"integer","required":true},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Laman koleksi saat ini.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Jumlah maksimal item yang akan dimunculkan dalam kumpulan hasil.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"Pastikan kumpulan hasil mengecualikan ID tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Batasi kumpulan hasil untuk ID tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Cara menginterpretasikan input pencarian.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Imbangi hasil dengan jumlah item tertentu.","type":"integer","required":false},"order":{"description":"Urutkan atribut penyortiran naik atau menurun.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortir koleksi berdasarkan atribut artikel.","type":"string","default":"id","enum":["id","include"],"required":false}}},{"methods":["POST"],"args":{"font_family_id":{"description":"ID untuk kelompok font induk pada tampilan font.","type":"integer","required":true},"theme_json_version":{"description":"Versi skema theme.json yang digunakan untuk pengaturan tipografi.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_face_settings":{"description":"deklarasi font-face dalam format theme.json, dikodekan sebagai string.","type":"string","required":true}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"ID untuk kelompok font induk pada tampilan font.","type":"integer","required":true},"id":{"description":"Pengidentifikasi unik untuk tampilan font.","type":"integer","required":true},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"font_family_id":{"description":"ID untuk kelompok font induk pada tampilan font.","type":"integer","required":true},"id":{"description":"Pengidentifikasi unik untuk tampilan font.","type":"integer","required":true},"force":{"type":"boolean","default":false,"description":"Apakah lewati Tempat Sampah dan paksakan penghapusan.","required":false}}}]},"\/wp\/v2\/banner":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Laman koleksi saat ini.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Jumlah maksimal item yang akan dimunculkan dalam kumpulan hasil.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Batas hasil yang sesuai dengan sebuah untaian.","type":"string","required":false},"after":{"description":"Batasi tanggapan untuk pos-pos yang diterbitkan setelah tanggal tertentu sesuai ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Batasi tanggapan untuk artikel yang diubah setelah tanggal tertentu sesuai ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Batasi hasil untuk pos-pos dengan penulis tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Pastikan hasil mengecualikan pos-pos dengan penulis tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Batasi tanggapan untuk pos yang diterbitkan sebelum tanggal tertentu sesuai ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Batasi tanggapan untuk artikel yang diubah sebelum tanggal tertentu sesuai ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Pastikan kumpulan hasil mengecualikan ID tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Batasi kumpulan hasil untuk ID tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Cara menginterpretasikan input pencarian.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Imbangi hasil dengan jumlah item tertentu.","type":"integer","required":false},"order":{"description":"Urutkan atribut penyortiran naik atau menurun.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortir koleksi berdasarkan atribut artikel.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array pada nama kolom yang akan dicari.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Batasi hasil ke pos-pos yang memiliki status satu atau lebih.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"tax_relation":{"description":"Batasi hasil yang ditetapkan berdasarkan hubungan antara beberapa taksonomi.","type":"string","enum":["AND","OR"],"required":false},"banner_groups":{"description":"Batasi hasil yang ditetapkan ke item dengan term spesifik yang ditetapkan dalam taksonomi banner_groups.","type":["object","array"],"oneOf":[{"title":"Daftar ID Term","description":"Cocokkan term dengan ID yang terdaftar.","type":"array","items":{"type":"integer"}},{"title":"Kueri Taksonomi ID Term","description":"Jalankan sebuah kueri term tingkat lanjut.","type":"object","properties":{"terms":{"description":"ID Term","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Apakah akan memasukkan term turunan dalam term yang membatasi kumpulan hasil.","type":"boolean","default":false},"operator":{"description":"Apakah item harus diberikan akses ke semua atau salah satu term yang ditentukan.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"banner_groups_exclude":{"description":"Batasi set hasil hanya untuk item yang memiliki istilah tertentu yang diterapkan di dalam taksonomi banner_groups.","type":["object","array"],"oneOf":[{"title":"Daftar ID Term","description":"Cocokkan term dengan ID yang terdaftar.","type":"array","items":{"type":"integer"}},{"title":"Kueri Taksonomi ID Term","description":"Jalankan sebuah kueri term tingkat lanjut.","type":"object","properties":{"terms":{"description":"ID Term","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Apakah akan memasukkan term turunan dalam term yang membatasi kumpulan hasil.","type":"boolean","default":false}},"additionalProperties":false}],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Tanggal saat pos dipublikasikan, dalam zona waktu situs.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Tanggal saat pos dipublikasikan, dalam GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Pengidentifikasi alfanumerik untuk pos sesuai dengan jenisnya.","type":"string","required":false},"status":{"description":"Status bernama untuk pos.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Kata sandi untuk melindungi akses atas konten dan ringkasan.","type":"string","required":false},"title":{"description":"Judul untuk pos.","type":"object","properties":{"raw":{"description":"Judul untuk pos, sebagaimana tersimpan dalam basis data.","type":"string","context":["edit"]},"rendered":{"description":"Judul HTML pos, diubah menjadi tampilan.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Konten untuk pos.","type":"object","properties":{"raw":{"description":"Konten pos, sesuai yang ada di basis data.","type":"string","context":["edit"]},"rendered":{"description":"Konten HTML untuk pos, diubah menjadi tampilan.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi dari format blok konten yang digunakan oleh pos.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Apakah konten dilindungi dengan kata sandi.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"ID penulis pos.","type":"integer","required":false},"excerpt":{"description":"Ringkasan untuk pos.","type":"object","properties":{"raw":{"description":"Ringkasan untuk pos, sesuai yang ada di basis data.","type":"string","context":["edit"]},"rendered":{"description":"Ringkasan HTML untuk pos, diubah menjadi tampilan.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Apakah ringkasan tersebut dilindungi dengan kata sandi.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"ID media unggulan untuk pos.","type":"integer","required":false},"comment_status":{"description":"Apakah komentar dibuka di pos atau tidak.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Apakah pos dapat ping atau tidak.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Ruas-ruas meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Berkas tema yang dipakai untuk menampilkan pos.","type":"string","required":false},"banner_groups":{"description":"Term diberikan untuk pos dalam taksonomi banner_groups.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/wp\/v2\/banner"}]}},"\/wp\/v2\/banner\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Pengidentifikasi unik untuk pos.","type":"integer","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Ganti panjang kutipan bawaan.","type":"integer","required":false},"password":{"description":"Kata sandi untuk pos jika pos tersebut dilindungi kata sandi.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Pengidentifikasi unik untuk pos.","type":"integer","required":false},"date":{"description":"Tanggal saat pos dipublikasikan, dalam zona waktu situs.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Tanggal saat pos dipublikasikan, dalam GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Pengidentifikasi alfanumerik untuk pos sesuai dengan jenisnya.","type":"string","required":false},"status":{"description":"Status bernama untuk pos.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Kata sandi untuk melindungi akses atas konten dan ringkasan.","type":"string","required":false},"title":{"description":"Judul untuk pos.","type":"object","properties":{"raw":{"description":"Judul untuk pos, sebagaimana tersimpan dalam basis data.","type":"string","context":["edit"]},"rendered":{"description":"Judul HTML pos, diubah menjadi tampilan.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Konten untuk pos.","type":"object","properties":{"raw":{"description":"Konten pos, sesuai yang ada di basis data.","type":"string","context":["edit"]},"rendered":{"description":"Konten HTML untuk pos, diubah menjadi tampilan.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi dari format blok konten yang digunakan oleh pos.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Apakah konten dilindungi dengan kata sandi.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"ID penulis pos.","type":"integer","required":false},"excerpt":{"description":"Ringkasan untuk pos.","type":"object","properties":{"raw":{"description":"Ringkasan untuk pos, sesuai yang ada di basis data.","type":"string","context":["edit"]},"rendered":{"description":"Ringkasan HTML untuk pos, diubah menjadi tampilan.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Apakah ringkasan tersebut dilindungi dengan kata sandi.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"ID media unggulan untuk pos.","type":"integer","required":false},"comment_status":{"description":"Apakah komentar dibuka di pos atau tidak.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Apakah pos dapat ping atau tidak.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Ruas-ruas meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Berkas tema yang dipakai untuk menampilkan pos.","type":"string","required":false},"banner_groups":{"description":"Term diberikan untuk pos dalam taksonomi banner_groups.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Pengidentifikasi unik untuk pos.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Apakah lewati Tempat Sampah dan paksakan penghapusan.","required":false}}}]},"\/wp\/v2\/banner\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID untuk induk penyimpanan otomatis.","type":"integer","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"ID untuk induk penyimpanan otomatis.","type":"integer","required":false},"date":{"description":"Tanggal saat pos dipublikasikan, dalam zona waktu situs.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Tanggal saat pos dipublikasikan, dalam GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Pengidentifikasi alfanumerik untuk pos sesuai dengan jenisnya.","type":"string","required":false},"status":{"description":"Status bernama untuk pos.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Kata sandi untuk melindungi akses atas konten dan ringkasan.","type":"string","required":false},"title":{"description":"Judul untuk pos.","type":"object","properties":{"raw":{"description":"Judul untuk pos, sebagaimana tersimpan dalam basis data.","type":"string","context":["edit"]},"rendered":{"description":"Judul HTML pos, diubah menjadi tampilan.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Konten untuk pos.","type":"object","properties":{"raw":{"description":"Konten pos, sesuai yang ada di basis data.","type":"string","context":["edit"]},"rendered":{"description":"Konten HTML untuk pos, diubah menjadi tampilan.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi dari format blok konten yang digunakan oleh pos.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Apakah konten dilindungi dengan kata sandi.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"ID penulis pos.","type":"integer","required":false},"excerpt":{"description":"Ringkasan untuk pos.","type":"object","properties":{"raw":{"description":"Ringkasan untuk pos, sesuai yang ada di basis data.","type":"string","context":["edit"]},"rendered":{"description":"Ringkasan HTML untuk pos, diubah menjadi tampilan.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Apakah ringkasan tersebut dilindungi dengan kata sandi.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"ID media unggulan untuk pos.","type":"integer","required":false},"comment_status":{"description":"Apakah komentar dibuka di pos atau tidak.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Apakah pos dapat ping atau tidak.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Ruas-ruas meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Berkas tema yang dipakai untuk menampilkan pos.","type":"string","required":false},"banner_groups":{"description":"Term diberikan untuk pos dalam taksonomi banner_groups.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/banner\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID untuk induk penyimpanan otomatis.","type":"integer","required":false},"id":{"description":"ID penyimpanan otomatis.","type":"integer","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/ld_docs":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Laman koleksi saat ini.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Jumlah maksimal item yang akan dimunculkan dalam kumpulan hasil.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Batas hasil yang sesuai dengan sebuah untaian.","type":"string","required":false},"after":{"description":"Batasi tanggapan untuk pos-pos yang diterbitkan setelah tanggal tertentu sesuai ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Batasi tanggapan untuk artikel yang diubah setelah tanggal tertentu sesuai ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Batasi hasil untuk pos-pos dengan penulis tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Pastikan hasil mengecualikan pos-pos dengan penulis tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Batasi tanggapan untuk pos yang diterbitkan sebelum tanggal tertentu sesuai ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Batasi tanggapan untuk artikel yang diubah sebelum tanggal tertentu sesuai ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Pastikan kumpulan hasil mengecualikan ID tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Batasi kumpulan hasil untuk ID tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Batasi hasil untuk pos-pos dengan nilai menu_order tertentu.","type":"integer","required":false},"search_semantics":{"description":"Cara menginterpretasikan input pencarian.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Imbangi hasil dengan jumlah item tertentu.","type":"integer","required":false},"order":{"description":"Urutkan atribut penyortiran naik atau menurun.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortir koleksi berdasarkan atribut artikel.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"parent":{"description":"Batasi hasil hanya untuk yang memiliki ID induk tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Batasi set hasil hanya untuk semua item selain item-item dengan ID induk tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Array pada nama kolom yang akan dicari.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limit result set to posts with one or more specific slugs.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Batasi hasil ke pos-pos yang memiliki status satu atau lebih.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"tax_relation":{"description":"Batasi hasil yang ditetapkan berdasarkan hubungan antara beberapa taksonomi.","type":"string","enum":["AND","OR"],"required":false},"ld_collection":{"description":"Batasi hasil yang ditetapkan ke item dengan term spesifik yang ditetapkan dalam taksonomi ld_collection.","type":["object","array"],"oneOf":[{"title":"Daftar ID Term","description":"Cocokkan term dengan ID yang terdaftar.","type":"array","items":{"type":"integer"}},{"title":"Kueri Taksonomi ID Term","description":"Jalankan sebuah kueri term tingkat lanjut.","type":"object","properties":{"terms":{"description":"ID Term","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Apakah akan memasukkan term turunan dalam term yang membatasi kumpulan hasil.","type":"boolean","default":false},"operator":{"description":"Apakah item harus diberikan akses ke semua atau salah satu term yang ditentukan.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"ld_collection_exclude":{"description":"Batasi set hasil hanya untuk item yang memiliki istilah tertentu yang diterapkan di dalam taksonomi ld_collection.","type":["object","array"],"oneOf":[{"title":"Daftar ID Term","description":"Cocokkan term dengan ID yang terdaftar.","type":"array","items":{"type":"integer"}},{"title":"Kueri Taksonomi ID Term","description":"Jalankan sebuah kueri term tingkat lanjut.","type":"object","properties":{"terms":{"description":"ID Term","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Apakah akan memasukkan term turunan dalam term yang membatasi kumpulan hasil.","type":"boolean","default":false}},"additionalProperties":false}],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Tanggal saat pos dipublikasikan, dalam zona waktu situs.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Tanggal saat pos dipublikasikan, dalam GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Pengidentifikasi alfanumerik untuk pos sesuai dengan jenisnya.","type":"string","required":false},"status":{"description":"Status bernama untuk pos.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Kata sandi untuk melindungi akses atas konten dan ringkasan.","type":"string","required":false},"parent":{"description":"ID induk pos.","type":"integer","required":false},"title":{"description":"Judul untuk pos.","type":"object","properties":{"raw":{"description":"Judul untuk pos, sebagaimana tersimpan dalam basis data.","type":"string","context":["edit"]},"rendered":{"description":"Judul HTML pos, diubah menjadi tampilan.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Konten untuk pos.","type":"object","properties":{"raw":{"description":"Konten pos, sesuai yang ada di basis data.","type":"string","context":["edit"]},"rendered":{"description":"Konten HTML untuk pos, diubah menjadi tampilan.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi dari format blok konten yang digunakan oleh pos.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Apakah konten dilindungi dengan kata sandi.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"ID penulis pos.","type":"integer","required":false},"excerpt":{"description":"Ringkasan untuk pos.","type":"object","properties":{"raw":{"description":"Ringkasan untuk pos, sesuai yang ada di basis data.","type":"string","context":["edit"]},"rendered":{"description":"Ringkasan HTML untuk pos, diubah menjadi tampilan.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Apakah ringkasan tersebut dilindungi dengan kata sandi.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"ID media unggulan untuk pos.","type":"integer","required":false},"menu_order":{"description":"Urutan artikel dalam kaitannya dengan artikel lain.","type":"integer","required":false},"meta":{"description":"Ruas-ruas meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Berkas tema yang dipakai untuk menampilkan pos.","type":"string","required":false},"ld_collection":{"description":"Term diberikan untuk pos dalam taksonomi ld_collection.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/wp\/v2\/ld_docs"}]}},"\/wp\/v2\/ld_docs\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Pengidentifikasi unik untuk pos.","type":"integer","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Ganti panjang kutipan bawaan.","type":"integer","required":false},"password":{"description":"Kata sandi untuk pos jika pos tersebut dilindungi kata sandi.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Pengidentifikasi unik untuk pos.","type":"integer","required":false},"date":{"description":"Tanggal saat pos dipublikasikan, dalam zona waktu situs.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Tanggal saat pos dipublikasikan, dalam GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Pengidentifikasi alfanumerik untuk pos sesuai dengan jenisnya.","type":"string","required":false},"status":{"description":"Status bernama untuk pos.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Kata sandi untuk melindungi akses atas konten dan ringkasan.","type":"string","required":false},"parent":{"description":"ID induk pos.","type":"integer","required":false},"title":{"description":"Judul untuk pos.","type":"object","properties":{"raw":{"description":"Judul untuk pos, sebagaimana tersimpan dalam basis data.","type":"string","context":["edit"]},"rendered":{"description":"Judul HTML pos, diubah menjadi tampilan.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Konten untuk pos.","type":"object","properties":{"raw":{"description":"Konten pos, sesuai yang ada di basis data.","type":"string","context":["edit"]},"rendered":{"description":"Konten HTML untuk pos, diubah menjadi tampilan.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi dari format blok konten yang digunakan oleh pos.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Apakah konten dilindungi dengan kata sandi.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"ID penulis pos.","type":"integer","required":false},"excerpt":{"description":"Ringkasan untuk pos.","type":"object","properties":{"raw":{"description":"Ringkasan untuk pos, sesuai yang ada di basis data.","type":"string","context":["edit"]},"rendered":{"description":"Ringkasan HTML untuk pos, diubah menjadi tampilan.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Apakah ringkasan tersebut dilindungi dengan kata sandi.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"ID media unggulan untuk pos.","type":"integer","required":false},"menu_order":{"description":"Urutan artikel dalam kaitannya dengan artikel lain.","type":"integer","required":false},"meta":{"description":"Ruas-ruas meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Berkas tema yang dipakai untuk menampilkan pos.","type":"string","required":false},"ld_collection":{"description":"Term diberikan untuk pos dalam taksonomi ld_collection.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Pengidentifikasi unik untuk pos.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Apakah lewati Tempat Sampah dan paksakan penghapusan.","required":false}}}]},"\/wp\/v2\/ld_docs\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID untuk induk penyimpanan otomatis.","type":"integer","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"ID induk pos.","type":"integer","required":false},"date":{"description":"Tanggal saat pos dipublikasikan, dalam zona waktu situs.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Tanggal saat pos dipublikasikan, dalam GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Pengidentifikasi alfanumerik untuk pos sesuai dengan jenisnya.","type":"string","required":false},"status":{"description":"Status bernama untuk pos.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Kata sandi untuk melindungi akses atas konten dan ringkasan.","type":"string","required":false},"title":{"description":"Judul untuk pos.","type":"object","properties":{"raw":{"description":"Judul untuk pos, sebagaimana tersimpan dalam basis data.","type":"string","context":["edit"]},"rendered":{"description":"Judul HTML pos, diubah menjadi tampilan.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Konten untuk pos.","type":"object","properties":{"raw":{"description":"Konten pos, sesuai yang ada di basis data.","type":"string","context":["edit"]},"rendered":{"description":"Konten HTML untuk pos, diubah menjadi tampilan.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi dari format blok konten yang digunakan oleh pos.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Apakah konten dilindungi dengan kata sandi.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"ID penulis pos.","type":"integer","required":false},"excerpt":{"description":"Ringkasan untuk pos.","type":"object","properties":{"raw":{"description":"Ringkasan untuk pos, sesuai yang ada di basis data.","type":"string","context":["edit"]},"rendered":{"description":"Ringkasan HTML untuk pos, diubah menjadi tampilan.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Apakah ringkasan tersebut dilindungi dengan kata sandi.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"ID media unggulan untuk pos.","type":"integer","required":false},"menu_order":{"description":"Urutan artikel dalam kaitannya dengan artikel lain.","type":"integer","required":false},"meta":{"description":"Ruas-ruas meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Berkas tema yang dipakai untuk menampilkan pos.","type":"string","required":false},"ld_collection":{"description":"Term diberikan untuk pos dalam taksonomi ld_collection.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/ld_docs\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"ID untuk induk penyimpanan otomatis.","type":"integer","required":false},"id":{"description":"ID penyimpanan otomatis.","type":"integer","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/wp\/v2\/types"}]}},"\/wp\/v2\/types\/(?P<type>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"description":"Sebuah identitas alfanumerik untuk tipe pos.","type":"string","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/statuses":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/wp\/v2\/statuses"}]}},"\/wp\/v2\/statuses\/(?P<status>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"Sebuah identitas alfanumerik untuk status.","type":"string","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/taxonomies":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"type":{"description":"Batasi hasil hanya untuk taksonomi yang terkait dengan tipe pos tertentu.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/wp\/v2\/taxonomies"}]}},"\/wp\/v2\/taxonomies\/(?P<taxonomy>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"taxonomy":{"description":"Sebuah identitas alfanumerik untuk taksonomi.","type":"string","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/categories":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Laman koleksi saat ini.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Jumlah maksimal item yang akan dimunculkan dalam kumpulan hasil.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Batas hasil yang sesuai dengan sebuah untaian.","type":"string","required":false},"exclude":{"description":"Pastikan kumpulan hasil mengecualikan ID tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Batasi kumpulan hasil untuk ID tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Urutkan atribut penyortiran naik atau menurun.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Urutkan koleksi berdasarkan atribut istilah.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Apakah akan menyembunyikan istilah-istilah yang tak digunakan pada pos manapun.","type":"boolean","default":false,"required":false},"parent":{"description":"Batasi set hasil untuk terma-terma dengan induk tertentu.","type":"integer","required":false},"post":{"description":"Batasi hasil untuk istilah-istilah yang digunakan pada pos tertentu.","type":"integer","default":null,"required":false},"slug":{"description":"Batasi set hasil ke istilah dengan satu atau lebih slug spesifik.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Deskripsi HTML dari istilah tersebut.","type":"string","required":false},"name":{"description":"Judul HTML untuk istilah.","type":"string","required":true},"slug":{"description":"Pengenal alfanumerik untuk istilah yang unik untuk tipe tersebut.","type":"string","required":false},"parent":{"description":"ID induk istilah.","type":"integer","required":false},"meta":{"description":"Ruas-ruas meta.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/wp\/v2\/categories"}]}},"\/wp\/v2\/categories\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Pengidentifikasi unik untuk term.","type":"integer","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Pengidentifikasi unik untuk term.","type":"integer","required":false},"description":{"description":"Deskripsi HTML dari istilah tersebut.","type":"string","required":false},"name":{"description":"Judul HTML untuk istilah.","type":"string","required":false},"slug":{"description":"Pengenal alfanumerik untuk istilah yang unik untuk tipe tersebut.","type":"string","required":false},"parent":{"description":"ID induk istilah.","type":"integer","required":false},"meta":{"description":"Ruas-ruas meta.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Pengidentifikasi unik untuk term.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Nilai harus true, karena istilah tidak mendukung pemindahan ke tong sampah.","required":false}}}]},"\/wp\/v2\/tags":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Laman koleksi saat ini.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Jumlah maksimal item yang akan dimunculkan dalam kumpulan hasil.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Batas hasil yang sesuai dengan sebuah untaian.","type":"string","required":false},"exclude":{"description":"Pastikan kumpulan hasil mengecualikan ID tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Batasi kumpulan hasil untuk ID tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Imbangi hasil dengan jumlah item tertentu.","type":"integer","required":false},"order":{"description":"Urutkan atribut penyortiran naik atau menurun.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Urutkan koleksi berdasarkan atribut istilah.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Apakah akan menyembunyikan istilah-istilah yang tak digunakan pada pos manapun.","type":"boolean","default":false,"required":false},"post":{"description":"Batasi hasil untuk istilah-istilah yang digunakan pada pos tertentu.","type":"integer","default":null,"required":false},"slug":{"description":"Batasi set hasil ke istilah dengan satu atau lebih slug spesifik.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Deskripsi HTML dari istilah tersebut.","type":"string","required":false},"name":{"description":"Judul HTML untuk istilah.","type":"string","required":true},"slug":{"description":"Pengenal alfanumerik untuk istilah yang unik untuk tipe tersebut.","type":"string","required":false},"meta":{"description":"Ruas-ruas meta.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/wp\/v2\/tags"}]}},"\/wp\/v2\/tags\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Pengidentifikasi unik untuk term.","type":"integer","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Pengidentifikasi unik untuk term.","type":"integer","required":false},"description":{"description":"Deskripsi HTML dari istilah tersebut.","type":"string","required":false},"name":{"description":"Judul HTML untuk istilah.","type":"string","required":false},"slug":{"description":"Pengenal alfanumerik untuk istilah yang unik untuk tipe tersebut.","type":"string","required":false},"meta":{"description":"Ruas-ruas meta.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Pengidentifikasi unik untuk term.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Nilai harus true, karena istilah tidak mendukung pemindahan ke tong sampah.","required":false}}}]},"\/wp\/v2\/menus":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Laman koleksi saat ini.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Jumlah maksimal item yang akan dimunculkan dalam kumpulan hasil.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Batas hasil yang sesuai dengan sebuah untaian.","type":"string","required":false},"exclude":{"description":"Pastikan kumpulan hasil mengecualikan ID tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Batasi kumpulan hasil untuk ID tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Imbangi hasil dengan jumlah item tertentu.","type":"integer","required":false},"order":{"description":"Urutkan atribut penyortiran naik atau menurun.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Urutkan koleksi berdasarkan atribut istilah.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Apakah akan menyembunyikan istilah-istilah yang tak digunakan pada pos manapun.","type":"boolean","default":false,"required":false},"post":{"description":"Batasi hasil untuk istilah-istilah yang digunakan pada pos tertentu.","type":"integer","default":null,"required":false},"slug":{"description":"Batasi set hasil ke istilah dengan satu atau lebih slug spesifik.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Deskripsi HTML dari istilah tersebut.","type":"string","required":false},"name":{"description":"Judul HTML untuk istilah.","type":"string","required":true},"slug":{"description":"Pengenal alfanumerik untuk istilah yang unik untuk tipe tersebut.","type":"string","required":false},"meta":{"description":"Ruas-ruas meta.","type":"object","properties":[],"required":false},"locations":{"description":"Lokasi yang ditetapkan pada menu.","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"Apakah akan menambahkan laman tingkat atas ke menu berikut secara otomatis.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/wp\/v2\/menus"}]}},"\/wp\/v2\/menus\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Pengidentifikasi unik untuk term.","type":"integer","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Pengidentifikasi unik untuk term.","type":"integer","required":false},"description":{"description":"Deskripsi HTML dari istilah tersebut.","type":"string","required":false},"name":{"description":"Judul HTML untuk istilah.","type":"string","required":false},"slug":{"description":"Pengenal alfanumerik untuk istilah yang unik untuk tipe tersebut.","type":"string","required":false},"meta":{"description":"Ruas-ruas meta.","type":"object","properties":[],"required":false},"locations":{"description":"Lokasi yang ditetapkan pada menu.","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"Apakah akan menambahkan laman tingkat atas ke menu berikut secara otomatis.","type":"boolean","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Pengidentifikasi unik untuk term.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Nilai harus true, karena istilah tidak mendukung pemindahan ke tong sampah.","required":false}}}]},"\/wp\/v2\/wp_pattern_category":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Laman koleksi saat ini.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Jumlah maksimal item yang akan dimunculkan dalam kumpulan hasil.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Batas hasil yang sesuai dengan sebuah untaian.","type":"string","required":false},"exclude":{"description":"Pastikan kumpulan hasil mengecualikan ID tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Batasi kumpulan hasil untuk ID tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Imbangi hasil dengan jumlah item tertentu.","type":"integer","required":false},"order":{"description":"Urutkan atribut penyortiran naik atau menurun.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Urutkan koleksi berdasarkan atribut istilah.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Apakah akan menyembunyikan istilah-istilah yang tak digunakan pada pos manapun.","type":"boolean","default":false,"required":false},"post":{"description":"Batasi hasil untuk istilah-istilah yang digunakan pada pos tertentu.","type":"integer","default":null,"required":false},"slug":{"description":"Batasi set hasil ke istilah dengan satu atau lebih slug spesifik.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Deskripsi HTML dari istilah tersebut.","type":"string","required":false},"name":{"description":"Judul HTML untuk istilah.","type":"string","required":true},"slug":{"description":"Pengenal alfanumerik untuk istilah yang unik untuk tipe tersebut.","type":"string","required":false},"meta":{"description":"Ruas-ruas meta.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/wp\/v2\/wp_pattern_category"}]}},"\/wp\/v2\/wp_pattern_category\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Pengidentifikasi unik untuk term.","type":"integer","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Pengidentifikasi unik untuk term.","type":"integer","required":false},"description":{"description":"Deskripsi HTML dari istilah tersebut.","type":"string","required":false},"name":{"description":"Judul HTML untuk istilah.","type":"string","required":false},"slug":{"description":"Pengenal alfanumerik untuk istilah yang unik untuk tipe tersebut.","type":"string","required":false},"meta":{"description":"Ruas-ruas meta.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Pengidentifikasi unik untuk term.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Nilai harus true, karena istilah tidak mendukung pemindahan ke tong sampah.","required":false}}}]},"\/wp\/v2\/banner_groups":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Laman koleksi saat ini.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Jumlah maksimal item yang akan dimunculkan dalam kumpulan hasil.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Batas hasil yang sesuai dengan sebuah untaian.","type":"string","required":false},"exclude":{"description":"Pastikan kumpulan hasil mengecualikan ID tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Batasi kumpulan hasil untuk ID tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Urutkan atribut penyortiran naik atau menurun.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Urutkan koleksi berdasarkan atribut istilah.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Apakah akan menyembunyikan istilah-istilah yang tak digunakan pada pos manapun.","type":"boolean","default":false,"required":false},"parent":{"description":"Batasi set hasil untuk terma-terma dengan induk tertentu.","type":"integer","required":false},"post":{"description":"Batasi hasil untuk istilah-istilah yang digunakan pada pos tertentu.","type":"integer","default":null,"required":false},"slug":{"description":"Batasi set hasil ke istilah dengan satu atau lebih slug spesifik.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Deskripsi HTML dari istilah tersebut.","type":"string","required":false},"name":{"description":"Judul HTML untuk istilah.","type":"string","required":true},"slug":{"description":"Pengenal alfanumerik untuk istilah yang unik untuk tipe tersebut.","type":"string","required":false},"parent":{"description":"ID induk istilah.","type":"integer","required":false},"meta":{"description":"Ruas-ruas meta.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/wp\/v2\/banner_groups"}]}},"\/wp\/v2\/banner_groups\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Pengidentifikasi unik untuk term.","type":"integer","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Pengidentifikasi unik untuk term.","type":"integer","required":false},"description":{"description":"Deskripsi HTML dari istilah tersebut.","type":"string","required":false},"name":{"description":"Judul HTML untuk istilah.","type":"string","required":false},"slug":{"description":"Pengenal alfanumerik untuk istilah yang unik untuk tipe tersebut.","type":"string","required":false},"parent":{"description":"ID induk istilah.","type":"integer","required":false},"meta":{"description":"Ruas-ruas meta.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Pengidentifikasi unik untuk term.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Nilai harus true, karena istilah tidak mendukung pemindahan ke tong sampah.","required":false}}}]},"\/wp\/v2\/ld_collection":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Laman koleksi saat ini.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Jumlah maksimal item yang akan dimunculkan dalam kumpulan hasil.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Batas hasil yang sesuai dengan sebuah untaian.","type":"string","required":false},"exclude":{"description":"Pastikan kumpulan hasil mengecualikan ID tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Batasi kumpulan hasil untuk ID tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Urutkan atribut penyortiran naik atau menurun.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Urutkan koleksi berdasarkan atribut istilah.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Apakah akan menyembunyikan istilah-istilah yang tak digunakan pada pos manapun.","type":"boolean","default":false,"required":false},"parent":{"description":"Batasi set hasil untuk terma-terma dengan induk tertentu.","type":"integer","required":false},"post":{"description":"Batasi hasil untuk istilah-istilah yang digunakan pada pos tertentu.","type":"integer","default":null,"required":false},"slug":{"description":"Batasi set hasil ke istilah dengan satu atau lebih slug spesifik.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Deskripsi HTML dari istilah tersebut.","type":"string","required":false},"name":{"description":"Judul HTML untuk istilah.","type":"string","required":true},"slug":{"description":"Pengenal alfanumerik untuk istilah yang unik untuk tipe tersebut.","type":"string","required":false},"parent":{"description":"ID induk istilah.","type":"integer","required":false},"meta":{"description":"Ruas-ruas meta.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/wp\/v2\/ld_collection"}]}},"\/wp\/v2\/ld_collection\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Pengidentifikasi unik untuk term.","type":"integer","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Pengidentifikasi unik untuk term.","type":"integer","required":false},"description":{"description":"Deskripsi HTML dari istilah tersebut.","type":"string","required":false},"name":{"description":"Judul HTML untuk istilah.","type":"string","required":false},"slug":{"description":"Pengenal alfanumerik untuk istilah yang unik untuk tipe tersebut.","type":"string","required":false},"parent":{"description":"ID induk istilah.","type":"integer","required":false},"meta":{"description":"Ruas-ruas meta.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Pengidentifikasi unik untuk term.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Nilai harus true, karena istilah tidak mendukung pemindahan ke tong sampah.","required":false}}}]},"\/wp\/v2\/users":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Laman koleksi saat ini.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Jumlah maksimal item yang akan dimunculkan dalam kumpulan hasil.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Batas hasil yang sesuai dengan sebuah untaian.","type":"string","required":false},"exclude":{"description":"Pastikan kumpulan hasil mengecualikan ID tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Batasi kumpulan hasil untuk ID tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Imbangi hasil dengan jumlah item tertentu.","type":"integer","required":false},"order":{"default":"asc","description":"Urutkan atribut penyortiran naik atau menurun.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"name","description":"Urutkan koleksi berdasarkan atribut pengguna.","enum":["id","include","name","registered_date","slug","include_slugs","email","url"],"type":"string","required":false},"slug":{"description":"Batasi set hasil ke pengguna dengan satu atau lebih slug spesifik.","type":"array","items":{"type":"string"},"required":false},"roles":{"description":"Batasi hasil diatur ke pengguna yang setidaknya satu peran spesifik yang telah disediakan. Terima daftar csv atau peran tunggal.","type":"array","items":{"type":"string"},"required":false},"capabilities":{"description":"Batasi jumlah hasil untuk pengguna sesuai setidaknya satu kapabilitas yang disediakan. Terima kapabilitas daftar csv atau satuan.","type":"array","items":{"type":"string"},"required":false},"who":{"description":"Batasi kumpulan hasil kepada pengguna yang dianggap penulis.","type":"string","enum":["authors"],"required":false},"has_published_posts":{"description":"Batasi jumlah hasil kepada pengguna yang telah mempublikasikan artikel.","type":["boolean","array"],"items":{"type":"string","enum":{"post":"post","page":"page","attachment":"attachment","nav_menu_item":"nav_menu_item","wp_block":"wp_block","wp_template":"wp_template","wp_template_part":"wp_template_part","wp_global_styles":"wp_global_styles","wp_navigation":"wp_navigation","wp_font_family":"wp_font_family","wp_font_face":"wp_font_face","banner":"banner","ld_docs":"ld_docs"}},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"username":{"description":"Nama login untuk pengguna.","type":"string","required":true},"name":{"description":"Nama tampilan untuk pengguna.","type":"string","required":false},"first_name":{"description":"Nama depan pengguna.","type":"string","required":false},"last_name":{"description":"Nama belakang pengguna.","type":"string","required":false},"email":{"description":"Alamat email pengguna.","type":"string","format":"email","required":true},"url":{"description":"URL pengguna.","type":"string","format":"uri","required":false},"description":{"description":"Deskripsi pengguna.","type":"string","required":false},"locale":{"description":"Lokal untuk pengguna.","type":"string","enum":["","en_US","de_DE","es_ES","fa_IR","fr_FR","hi_IN","id_ID","it_IT","ja","nl_NL_formal","pl_PL","pt_PT","ru_RU","tr_TR","vi","zh_CN","zh_TW"],"required":false},"nickname":{"description":"Panggilan untuk pengguna.","type":"string","required":false},"slug":{"description":"Identifikasi alfanumerik untuk pengguna tersebut.","type":"string","required":false},"roles":{"description":"Peran yang ditetapkan untuk pengguna.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Kata sandi untuk pengguna (tak pernah disertakan).","type":"string","required":true},"meta":{"description":"Ruas-ruas meta.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"Preferensi tanggal dan waktu telah diperbarui.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/wp\/v2\/users"}]}},"\/wp\/v2\/users\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Pengidentifikasi unik untuk pengguna.","type":"integer","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Pengidentifikasi unik untuk pengguna.","type":"integer","required":false},"username":{"description":"Nama login untuk pengguna.","type":"string","required":false},"name":{"description":"Nama tampilan untuk pengguna.","type":"string","required":false},"first_name":{"description":"Nama depan pengguna.","type":"string","required":false},"last_name":{"description":"Nama belakang pengguna.","type":"string","required":false},"email":{"description":"Alamat email pengguna.","type":"string","format":"email","required":false},"url":{"description":"URL pengguna.","type":"string","format":"uri","required":false},"description":{"description":"Deskripsi pengguna.","type":"string","required":false},"locale":{"description":"Lokal untuk pengguna.","type":"string","enum":["","en_US","de_DE","es_ES","fa_IR","fr_FR","hi_IN","id_ID","it_IT","ja","nl_NL_formal","pl_PL","pt_PT","ru_RU","tr_TR","vi","zh_CN","zh_TW"],"required":false},"nickname":{"description":"Panggilan untuk pengguna.","type":"string","required":false},"slug":{"description":"Identifikasi alfanumerik untuk pengguna tersebut.","type":"string","required":false},"roles":{"description":"Peran yang ditetapkan untuk pengguna.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Kata sandi untuk pengguna (tak pernah disertakan).","type":"string","required":false},"meta":{"description":"Ruas-ruas meta.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"Preferensi tanggal dan waktu telah diperbarui.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Pengidentifikasi unik untuk pengguna.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Harus true, karena pengguna tidak mendukung pembuangan.","required":false},"reassign":{"type":"integer","description":"Alihkan pos dan tautan pengguna yang dihapus ke ID pengguna ini.","required":true}}}]},"\/wp\/v2\/users\/me":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"username":{"description":"Nama login untuk pengguna.","type":"string","required":false},"name":{"description":"Nama tampilan untuk pengguna.","type":"string","required":false},"first_name":{"description":"Nama depan pengguna.","type":"string","required":false},"last_name":{"description":"Nama belakang pengguna.","type":"string","required":false},"email":{"description":"Alamat email pengguna.","type":"string","format":"email","required":false},"url":{"description":"URL pengguna.","type":"string","format":"uri","required":false},"description":{"description":"Deskripsi pengguna.","type":"string","required":false},"locale":{"description":"Lokal untuk pengguna.","type":"string","enum":["","en_US","de_DE","es_ES","fa_IR","fr_FR","hi_IN","id_ID","it_IT","ja","nl_NL_formal","pl_PL","pt_PT","ru_RU","tr_TR","vi","zh_CN","zh_TW"],"required":false},"nickname":{"description":"Panggilan untuk pengguna.","type":"string","required":false},"slug":{"description":"Identifikasi alfanumerik untuk pengguna tersebut.","type":"string","required":false},"roles":{"description":"Peran yang ditetapkan untuk pengguna.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Kata sandi untuk pengguna (tak pernah disertakan).","type":"string","required":false},"meta":{"description":"Ruas-ruas meta.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"Preferensi tanggal dan waktu telah diperbarui.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false}}},{"methods":["DELETE"],"args":{"force":{"type":"boolean","default":false,"description":"Harus true, karena pengguna tidak mendukung pembuangan.","required":false},"reassign":{"type":"integer","description":"Alihkan pos dan tautan pengguna yang dihapus ke ID pengguna ini.","required":true}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/wp\/v2\/users\/me"}]}},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords":{"namespace":"wp\/v2","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"app_id":{"description":"Tersedia UUID dari aplikasi untuk identifikasi yang unik. Direkomendasikan untuk menggunakan UUID v5 dengan URL atau namespace DNS.","type":"string","format":"uuid","required":false},"name":{"description":"Nama kata sandi aplikasi.","type":"string","minLength":1,"pattern":".*\\S.*","required":true}}},{"methods":["DELETE"],"args":[]}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/introspect":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/(?P<uuid>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"app_id":{"description":"Tersedia UUID dari aplikasi untuk identifikasi yang unik. Direkomendasikan untuk menggunakan UUID v5 dengan URL atau namespace DNS.","type":"string","format":"uuid","required":false},"name":{"description":"Nama kata sandi aplikasi.","type":"string","minLength":1,"pattern":".*\\S.*","required":false}}},{"methods":["DELETE"],"args":[]}]},"\/wp\/v2\/comments":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Laman koleksi saat ini.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Jumlah maksimal item yang akan dimunculkan dalam kumpulan hasil.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Batas hasil yang sesuai dengan sebuah untaian.","type":"string","required":false},"after":{"description":"Batasi tanggapan untuk komentar yang diterbitkan setelah tanggal tertentu sesuai ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Batasi kumpulan hasil untuk komentar dengan ID pengguna tertentu. Membutuhkan otorisasi.","type":"array","items":{"type":"integer"},"required":false},"author_exclude":{"description":"Pastikan kumpulan hasil mengecualikan komentar dengan ID pengguna tertentu. Membutuhkan otorisasi.","type":"array","items":{"type":"integer"},"required":false},"author_email":{"default":null,"description":"Batasi kumpulan hasil hanya dari email penulis tertentu. Membutuhkan otorisasi.","format":"email","type":"string","required":false},"before":{"description":"Batasi tanggapan untuk komentar yang diterbitkan sebelum tanggal tertentu sesuai ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Pastikan kumpulan hasil mengecualikan ID tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Batasi kumpulan hasil untuk ID tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Imbangi hasil dengan jumlah item tertentu.","type":"integer","required":false},"order":{"description":"Urutkan atribut penyortiran naik atau menurun.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortir koleksi berdasarkan atribut komentar.","type":"string","default":"date_gmt","enum":["date","date_gmt","id","include","post","parent","type"],"required":false},"parent":{"default":[],"description":"Batasi kumpulan hasil untuk komentar dengan ID induk tertentu.","type":"array","items":{"type":"integer"},"required":false},"parent_exclude":{"default":[],"description":"Pastikan kumpulan hasil mengecualikan ID induk tertentu.","type":"array","items":{"type":"integer"},"required":false},"post":{"default":[],"description":"Batasi kumpulan hasil untuk komentar dengan ID pos tertentu.","type":"array","items":{"type":"integer"},"required":false},"status":{"default":"approve","description":"Batasi kumpulan hasil untuk komentar dengan status tertentu. Membutuhkan otorisasi.","type":"string","required":false},"type":{"default":"comment","description":"Batasi kumpulan hasil untuk komentar dengan tipe tertentu. Membutuhkan otorisasi.","type":"string","required":false},"password":{"description":"Kata sandi untuk pos jika pos tersebut dilindungi kata sandi.","type":"string","required":false}}},{"methods":["POST"],"args":{"author":{"description":"ID dari objek pengguna, jika penulis adalah pengguna.","type":"integer","required":false},"author_email":{"description":"Alamat email penulis komentar.","type":"string","format":"email","required":false},"author_ip":{"description":"Alamat IP penulis komentar.","type":"string","format":"ip","required":false},"author_name":{"description":"Tampilkan nama penulis komentar.","type":"string","required":false},"author_url":{"description":"URL untuk penulis komentar.","type":"string","format":"uri","required":false},"author_user_agent":{"description":"Agen pengguna untuk penulis komentar.","type":"string","required":false},"content":{"description":"Konten komentar.","type":"object","properties":{"raw":{"description":"Konten komentar, sesuai yang tersimpan di database.","type":"string","context":["edit"]},"rendered":{"description":"Tampilkan konten HTML untuk komentar.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"Tanggal saat komentar dipublikasikan, dalam zona waktu situs.","type":"string","format":"date-time","required":false},"date_gmt":{"description":"Tanggal penerbitan komentar, dalam GMT.","type":"string","format":"date-time","required":false},"parent":{"default":0,"description":"ID induk komentar.","type":"integer","required":false},"post":{"default":0,"description":"ID objek pos terkait.","type":"integer","required":false},"status":{"description":"Status komentar.","type":"string","required":false},"meta":{"description":"Ruas-ruas meta.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/wp\/v2\/comments"}]}},"\/wp\/v2\/comments\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Pengidentifikasi unik untuk komentar.","type":"integer","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Kata sandi untuk pos induk dari komen (jika pos dilindungi kata sandi).","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Pengidentifikasi unik untuk komentar.","type":"integer","required":false},"author":{"description":"ID dari objek pengguna, jika penulis adalah pengguna.","type":"integer","required":false},"author_email":{"description":"Alamat email penulis komentar.","type":"string","format":"email","required":false},"author_ip":{"description":"Alamat IP penulis komentar.","type":"string","format":"ip","required":false},"author_name":{"description":"Tampilkan nama penulis komentar.","type":"string","required":false},"author_url":{"description":"URL untuk penulis komentar.","type":"string","format":"uri","required":false},"author_user_agent":{"description":"Agen pengguna untuk penulis komentar.","type":"string","required":false},"content":{"description":"Konten komentar.","type":"object","properties":{"raw":{"description":"Konten komentar, sesuai yang tersimpan di database.","type":"string","context":["edit"]},"rendered":{"description":"Tampilkan konten HTML untuk komentar.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"Tanggal saat komentar dipublikasikan, dalam zona waktu situs.","type":"string","format":"date-time","required":false},"date_gmt":{"description":"Tanggal penerbitan komentar, dalam GMT.","type":"string","format":"date-time","required":false},"parent":{"description":"ID induk komentar.","type":"integer","required":false},"post":{"description":"ID objek pos terkait.","type":"integer","required":false},"status":{"description":"Status komentar.","type":"string","required":false},"meta":{"description":"Ruas-ruas meta.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Pengidentifikasi unik untuk komentar.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Apakah lewati Tempat Sampah dan paksakan penghapusan.","required":false},"password":{"description":"Kata sandi untuk pos induk dari komen (jika pos dilindungi kata sandi).","type":"string","required":false}}}]},"\/wp\/v2\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed"],"default":"view","required":false},"page":{"description":"Laman koleksi saat ini.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Jumlah maksimal item yang akan dimunculkan dalam kumpulan hasil.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Batas hasil yang sesuai dengan sebuah untaian.","type":"string","required":false},"type":{"default":"post","description":"Batasi hasil dari sebuah tipe objek.","type":"string","enum":["post","term","post-format"],"required":false},"subtype":{"default":"any","description":"Batasi hasil dari satu atau lebih subtipe objek.","type":"array","items":{"enum":["post","page","banner","ld_docs","category","post_tag","banner_groups","ld_collection","any"],"type":"string"},"required":false},"exclude":{"description":"Pastikan kumpulan hasil mengecualikan ID tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Batasi kumpulan hasil untuk ID tertentu.","type":"array","items":{"type":"integer"},"default":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/wp\/v2\/search"}]}},"\/wp\/v2\/block-renderer\/(?P<name>[a-z0-9-]+\/[a-z0-9-]+)":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET","POST"],"args":{"name":{"description":"Nama terdaftar unik untuk blok.","type":"string","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["edit"],"default":"view","required":false},"attributes":{"description":"Atribut untuk blok","type":"object","default":[],"required":false},"post_id":{"description":"ID dari konteks pos.","type":"integer","required":false}}}]},"\/wp\/v2\/block-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"Namespace blok.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/wp\/v2\/block-types"}]}},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"Namespace blok.","type":"string","required":false}}}]},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)\/(?P<name>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Nama blok","type":"string","required":false},"namespace":{"description":"Namespace blok.","type":"string","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/settings":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"title":{"title":"Judul","description":"Judul situs.","type":"string","required":false},"description":{"title":"Slogan","description":"Slogan situs.","type":"string","required":false},"timezone":{"title":"","description":"Kota dalam zona waktu yang sama dengan Anda.","type":"string","required":false},"date_format":{"title":"","description":"Format tanggal untuk semua untaian tanggal.","type":"string","required":false},"time_format":{"title":"","description":"Format waktu untuk semua untaian waktu.","type":"string","required":false},"start_of_week":{"title":"","description":"Urutan hari dalam seminggu yang menjadi mulainya minggu.","type":"integer","required":false},"language":{"title":"","description":"Kode lokal WordPress.","type":"string","required":false},"use_smilies":{"title":"","description":"Konversikan emotikon seperti :-) dan :-P ke grafik saat ditampilkan.","type":"boolean","required":false},"default_category":{"title":"","description":"Kategori pos bawaan.","type":"integer","required":false},"default_post_format":{"title":"","description":"Format pos bawaan.","type":"string","required":false},"posts_per_page":{"title":"Jumlah pos maksimal per halaman","description":"Tampilan maksimum laman blog.","type":"integer","required":false},"show_on_front":{"title":"Tampilkan di depan","description":"Yang akan ditampilkan di laman depan","type":"string","required":false},"page_on_front":{"title":"Laman di depan","description":"ID laman yang seharusnya ditampilkan di laman depan","type":"integer","required":false},"page_for_posts":{"title":"","description":"ID laman yang dapat menampilkan pos terbaru","type":"integer","required":false},"default_ping_status":{"title":"","description":"Izinkan notifikasi tautan dari blog lain (pingbalik dan lacakbalik) pada artikel baru.","type":"string","enum":["open","closed"],"required":false},"default_comment_status":{"title":"Izinkan komentar pada pos baru","description":"Izinkan orang mengirim komentar pada artikel baru.","type":"string","enum":["open","closed"],"required":false},"site_logo":{"title":"Logo","description":"Logo situs.","type":"integer","required":false},"site_icon":{"title":"Ikon","description":"Ikon situs","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/wp\/v2\/settings"}]}},"\/wp\/v2\/themes":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"Batasan hasil diatur hingga pada tema yang memiliki satu atau lebih status.","type":"array","items":{"enum":["active","inactive"],"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/wp\/v2\/themes"}]}},"\/wp\/v2\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"stylesheet":{"description":"Stylesheet tema. Ini secara unik mengidentifikasi tema.","type":"string","required":false}}}]},"\/wp\/v2\/plugins":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"search":{"description":"Batas hasil yang sesuai dengan sebuah untaian.","type":"string","required":false},"status":{"description":"Batasi hasil untuk plugin dengan status yang diberikan.","type":"array","items":{"type":"string","enum":["inactive","active","network-active"]},"required":false}}},{"methods":["POST"],"args":{"slug":{"type":"string","description":"Slug direktori plugin WordPress.org.","pattern":"[\\w\\-]+","required":true},"status":{"description":"Status aktivasi plugin.","type":"string","enum":["inactive","active","network-active"],"default":"inactive","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/wp\/v2\/plugins"}]}},"\/wp\/v2\/plugins\/(?P<plugin>[^.\\\/]+(?:\\\/[^.\\\/]+)?)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false},"status":{"description":"Status aktivasi plugin.","type":"string","enum":["inactive","active","network-active"],"required":false}}},{"methods":["DELETE"],"args":{"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false}}}]},"\/wp\/v2\/sidebars":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/wp\/v2\/sidebars"}]}},"\/wp\/v2\/sidebars\/(?P<id>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Id sidebar yang terdaftar","type":"string","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"widgets":{"description":"Widget yang disusun.","type":"array","items":{"type":["object","string"]},"required":false}}}]},"\/wp\/v2\/widget-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/wp\/v2\/widget-types"}]}},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"ID tipe widget","type":"string","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/encode":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"ID tipe widget","type":"string","required":true},"instance":{"description":"Pengaturan instance widget saat ini.","type":"object","required":false},"form_data":{"description":"Data formulir widget serial untuk dikodekan ke dalam pengaturan instance.","type":"string","required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/render":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"ID tipe widget","type":"string","required":true},"instance":{"description":"Pengaturan instance widget saat ini.","type":"object","required":false}}}]},"\/wp\/v2\/widgets":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"sidebar":{"description":"Sidebar tempat untuk mengembalikan widget.","type":"string","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"id":{"description":"Pengidentifikasi unik untuk widget.","type":"string","required":false},"id_base":{"description":"Jenis widgetnya. Sesuai dengan ID di titik akhir tipe widget.","type":"string","required":false},"sidebar":{"default":"wp_inactive_widgets","description":"Sidebar tempat widget berasal.","type":"string","required":true},"instance":{"description":"Pengaturan instance widget, jika didukung.","type":"object","properties":{"encoded":{"description":"Representasi encode Base64 dari pengaturan instance.","type":"string","context":["edit"]},"hash":{"description":"Hash kriptografik dari pengaturan instance.","type":"string","context":["edit"]},"raw":{"description":"Setelan instance yang tidak dienkode, jika didukung.","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"Data formulir yang dienkode-URL dari formulir widget admin. Digunakan untuk memperbarui widget yang tidak mendukung instance. Hanya tulis.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/wp\/v2\/widgets"}]}},"\/wp\/v2\/widgets\/(?P<id>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Pengidentifikasi unik untuk widget.","type":"string","required":false},"id_base":{"description":"Jenis widgetnya. Sesuai dengan ID di titik akhir tipe widget.","type":"string","required":false},"sidebar":{"description":"Sidebar tempat widget berasal.","type":"string","required":false},"instance":{"description":"Pengaturan instance widget, jika didukung.","type":"object","properties":{"encoded":{"description":"Representasi encode Base64 dari pengaturan instance.","type":"string","context":["edit"]},"hash":{"description":"Hash kriptografik dari pengaturan instance.","type":"string","context":["edit"]},"raw":{"description":"Setelan instance yang tidak dienkode, jika didukung.","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"Data formulir yang dienkode-URL dari formulir widget admin. Digunakan untuk memperbarui widget yang tidak mendukung instance. Hanya tulis.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"force":{"description":"Apakah akan menghapus widget dengan paksa atau memindahkannya ke sidebar nonaktif.","type":"boolean","required":false}}}]},"\/wp\/v2\/block-directory\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view"],"default":"view","required":false},"page":{"description":"Laman koleksi saat ini.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Jumlah maksimal item yang akan dimunculkan dalam kumpulan hasil.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"term":{"description":"Batasi hasil yang telah diatur untuk menghalangi penyesuaian istilah pencarian.","type":"string","minLength":1,"required":true}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/wp\/v2\/block-directory\/search"}]}},"\/wp\/v2\/pattern-directory\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Laman koleksi saat ini.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Jumlah maksimal item yang akan dimunculkan dalam kumpulan hasil.","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"Batas hasil yang sesuai dengan sebuah untaian.","type":"string","minLength":1,"required":false},"category":{"description":"Batasi hasil yang cocok dengan ID kategori.","type":"integer","minimum":1,"required":false},"keyword":{"description":"Batasi hasil yang cocok dengan ID kata kunci.","type":"integer","minimum":1,"required":false},"slug":{"description":"Batasi hasil hanya untuk yang cocok dengan pola (slug).","type":"array","required":false},"offset":{"description":"Imbangi hasil dengan jumlah item tertentu.","type":"integer","required":false},"order":{"description":"Urutkan atribut penyortiran naik atau menurun.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortir koleksi berdasarkan atribut artikel.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","favorite_count"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/wp\/v2\/pattern-directory\/patterns"}]}},"\/wp\/v2\/block-patterns\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/wp\/v2\/block-patterns\/patterns"}]}},"\/wp\/v2\/block-patterns\/categories":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/wp\/v2\/block-patterns\/categories"}]}},"\/wp-site-health\/v1":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-site-health\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/wp-site-health\/v1"}]}},"\/wp-site-health\/v1\/tests\/background-updates":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/wp-site-health\/v1\/tests\/background-updates"}]}},"\/wp-site-health\/v1\/tests\/loopback-requests":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/wp-site-health\/v1\/tests\/loopback-requests"}]}},"\/wp-site-health\/v1\/tests\/https-status":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/wp-site-health\/v1\/tests\/https-status"}]}},"\/wp-site-health\/v1\/tests\/dotorg-communication":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/wp-site-health\/v1\/tests\/dotorg-communication"}]}},"\/wp-site-health\/v1\/tests\/authorization-header":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/wp-site-health\/v1\/tests\/authorization-header"}]}},"\/wp-site-health\/v1\/directory-sizes":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/wp-site-health\/v1\/directory-sizes"}]}},"\/wp-site-health\/v1\/tests\/page-cache":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/wp-site-health\/v1\/tests\/page-cache"}]}},"\/wp-block-editor\/v1":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-block-editor\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/wp-block-editor\/v1"}]}},"\/wp-block-editor\/v1\/url-details":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"URL untuk diproses.","type":"string","format":"uri","required":true}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/wp-block-editor\/v1\/url-details"}]}},"\/wp\/v2\/menu-locations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/wp\/v2\/menu-locations"}]}},"\/wp\/v2\/menu-locations\/(?P<location>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"location":{"description":"Pengenal alfanumerik untuk lokasi menu.","type":"string","required":false},"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp-block-editor\/v1\/export":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/wp-block-editor\/v1\/export"}]}},"\/wp-block-editor\/v1\/navigation-fallback":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/wp-block-editor\/v1\/navigation-fallback"}]}},"\/wp\/v2\/font-collections":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Laman koleksi saat ini.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Jumlah maksimal item yang akan dimunculkan dalam kumpulan hasil.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/wp\/v2\/font-collections"}]}},"\/wp\/v2\/font-collections\/(?P<slug>[\\\/\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Cakupan di mana permintaan dibuat; menentukan ruas-ruas yang ada dalam tanggapan.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]}},"site_logo":0,"site_icon":8851,"site_icon_url":"https:\/\/blog.visual-paradigm.com\/id\/wp-content\/uploads\/sites\/16\/2022\/10\/vp-online-logo.png","_links":{"help":[{"href":"https:\/\/developer.wordpress.org\/rest-api\/"}],"wp:featuredmedia":[{"embeddable":true,"type":"site_icon","href":"https:\/\/blog.visual-paradigm.com\/id\/wp-json\/wp\/v2\/media\/8851"}],"curies":[{"name":"wp","href":"https:\/\/api.w.org\/{rel}","templated":true}]}}
