{"name":"Visual Paradigm Blog","description":"","url":"https:\/\/blog.visual-paradigm.com\/pl","home":"https:\/\/blog.visual-paradigm.com\/pl","gmt_offset":"8","timezone_string":"","namespaces":["oembed\/1.0","contentviews\/v1","custom-permalinks\/v1","featured-image-from-url\/v2","msls\/v1","yoast\/v1","redirection\/v1","regenerate-thumbnails\/v1","wp\/v2","wp-site-health\/v1","wp-block-editor\/v1"],"authentication":{"application-passwords":{"endpoints":{"authorization":"https:\/\/blog.visual-paradigm.com\/pl\/wp-admin\/authorize-application.php"}}},"routes":{"\/":{"namespace":"","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/"}]}},"\/batch\/v1":{"namespace":"","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"validation":{"type":"string","enum":["require-all-validate","normal"],"default":"normal","required":false},"requests":{"type":"array","maxItems":25,"items":{"type":"object","properties":{"method":{"type":"string","enum":["POST","PUT","PATCH","DELETE"],"default":"POST"},"path":{"type":"string","required":true},"body":{"type":"object","properties":[],"additionalProperties":true},"headers":{"type":"object","properties":[],"additionalProperties":{"type":["string","array"],"items":{"type":"string"}}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/batch\/v1"}]}},"\/oembed\/1.0":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"oembed\/1.0","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/oembed\/1.0"}]}},"\/oembed\/1.0\/embed":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"Adres URL zasobu pobieraj\u0105cego dane oEmbed.","type":"string","format":"uri","required":true},"format":{"default":"json","required":false},"maxwidth":{"default":600,"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/oembed\/1.0\/embed"}]}},"\/oembed\/1.0\/proxy":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"Adres URL zasobu pobieraj\u0105cego dane oEmbed.","type":"string","format":"uri","required":true},"format":{"description":"oEmbed do wykorzystania.","type":"string","default":"json","enum":["json","xml"],"required":false},"maxwidth":{"description":"Maksymalna szeroko\u015b\u0107 osadzonej ramki w pikselach.","type":"integer","default":600,"required":false},"maxheight":{"description":"Maksymalna wysoko\u015b\u0107 osadzonej ramki w pikselach.","type":"integer","required":false},"discover":{"description":"Czy wykonywa\u0107 zapytania oEmbed dla niezaufanych dostawc\u00f3w.","type":"boolean","default":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/oembed\/1.0\/proxy"}]}},"\/contentviews\/v1":{"namespace":"contentviews\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"contentviews\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/contentviews\/v1"}]}},"\/contentviews\/v1\/block_template_pattern":{"namespace":"contentviews\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/contentviews\/v1\/block_template_pattern"}]}},"\/contentviews\/v1\/update_block_template_pattern":{"namespace":"contentviews\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/contentviews\/v1\/update_block_template_pattern"}]}},"\/custom-permalinks\/v1":{"namespace":"custom-permalinks\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"custom-permalinks\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/custom-permalinks\/v1"}]}},"\/custom-permalinks\/v1\/get-permalink\/(?P<id>\\d+)":{"namespace":"custom-permalinks\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"required":false}}}]},"\/featured-image-from-url\/v2":{"namespace":"featured-image-from-url\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"featured-image-from-url\/v2","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/featured-image-from-url\/v2"}]}},"\/featured-image-from-url\/v2\/metadata_counter_api":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/featured-image-from-url\/v2\/metadata_counter_api"}]}},"\/featured-image-from-url\/v2\/enable_fake_api":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/featured-image-from-url\/v2\/enable_fake_api"}]}},"\/featured-image-from-url\/v2\/disable_fake_api":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/featured-image-from-url\/v2\/disable_fake_api"}]}},"\/featured-image-from-url\/v2\/data_clean_api":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/featured-image-from-url\/v2\/data_clean_api"}]}},"\/featured-image-from-url\/v2\/run_delete_all_api":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/featured-image-from-url\/v2\/run_delete_all_api"}]}},"\/featured-image-from-url\/v2\/disable_default_api":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/featured-image-from-url\/v2\/disable_default_api"}]}},"\/featured-image-from-url\/v2\/none_default_api":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/featured-image-from-url\/v2\/none_default_api"}]}},"\/featured-image-from-url\/v2\/pre_deactivate":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/featured-image-from-url\/v2\/pre_deactivate"}]}},"\/featured-image-from-url\/v2\/feedback":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/featured-image-from-url\/v2\/feedback"}]}},"\/featured-image-from-url\/v2\/deactivate_itself":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/featured-image-from-url\/v2\/deactivate_itself"}]}},"\/featured-image-from-url\/v2\/rest_url_api":{"namespace":"featured-image-from-url\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET","POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/featured-image-from-url\/v2\/rest_url_api"}]}},"\/featured-image-from-url\/v2\/metain":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"post_id":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/featured-image-from-url\/v2\/metain"}]}},"\/featured-image-from-url\/v2\/metaout":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"post_id":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/featured-image-from-url\/v2\/metaout"}]}},"\/featured-image-from-url\/v2\/create_thumbnails_list":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/featured-image-from-url\/v2\/create_thumbnails_list"}]}},"\/featured-image-from-url\/v2\/sign_up":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/featured-image-from-url\/v2\/sign_up"}]}},"\/featured-image-from-url\/v2\/connected":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/featured-image-from-url\/v2\/connected"}]}},"\/featured-image-from-url\/v2\/reset_credentials":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/featured-image-from-url\/v2\/reset_credentials"}]}},"\/featured-image-from-url\/v2\/list_all_su":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/featured-image-from-url\/v2\/list_all_su"}]}},"\/featured-image-from-url\/v2\/list_all_fifu":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/featured-image-from-url\/v2\/list_all_fifu"}]}},"\/featured-image-from-url\/v2\/list_all_media_library":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/featured-image-from-url\/v2\/list_all_media_library"}]}},"\/featured-image-from-url\/v2\/list_daily_count":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/featured-image-from-url\/v2\/list_daily_count"}]}},"\/featured-image-from-url\/v2\/delete":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/featured-image-from-url\/v2\/delete"}]}},"\/featured-image-from-url\/v2\/cancel":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/featured-image-from-url\/v2\/cancel"}]}},"\/featured-image-from-url\/v2\/payment_info":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/featured-image-from-url\/v2\/payment_info"}]}},"\/featured-image-from-url\/v2\/cloud_upload_auto":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/featured-image-from-url\/v2\/cloud_upload_auto"}]}},"\/featured-image-from-url\/v2\/cloud_delete_auto":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/featured-image-from-url\/v2\/cloud_delete_auto"}]}},"\/featured-image-from-url\/v2\/cloud_hotlink":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/featured-image-from-url\/v2\/cloud_hotlink"}]}},"\/featured-image-from-url\/v2\/debug-slug\/(?P<slug>[a-z0-9-_]+)":{"namespace":"featured-image-from-url\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"required":true}}}]},"\/featured-image-from-url\/v2\/debug-postmeta\/(?P<post_id>\\d+)":{"namespace":"featured-image-from-url\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"post_id":{"required":true}}}]},"\/featured-image-from-url\/v2\/debug-posts\/(?P<id>\\d+)":{"namespace":"featured-image-from-url\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"required":true}}}]},"\/featured-image-from-url\/v2\/debug-metain":{"namespace":"featured-image-from-url\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/featured-image-from-url\/v2\/debug-metain"}]}},"\/featured-image-from-url\/v2\/debug-metaout":{"namespace":"featured-image-from-url\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/featured-image-from-url\/v2\/debug-metaout"}]}},"\/msls\/v1":{"namespace":"msls\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"msls\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/msls\/v1"}]}},"\/msls\/v1\/duplicate-post":{"namespace":"msls\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"post_id":{"required":true},"target_locale":{"required":true},"_elementor_data":{"required":false},"_yoast_wpseo_title":{"required":false},"_yoast_wpseo_metadesc":{"required":false},"update_existing":{"default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/msls\/v1\/duplicate-post"}]}},"\/msls\/v1\/posts-without-translation\/(?P<target_locale>[a-zA-Z0-9_-]+)":{"namespace":"msls\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"target_locale":{"required":true},"post_type":{"default":"post","required":false}}}]},"\/msls\/v1\/posts-missing-translations":{"namespace":"msls\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"default":"publish","required":false},"post_type":{"default":"all","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/msls\/v1\/posts-missing-translations"}]}},"\/msls\/v1\/fix-taxonomies":{"namespace":"msls\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"source_post_id":{"required":true},"source_blog_id":{"required":true},"target_post_id":{"required":true},"target_blog_id":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/msls\/v1\/fix-taxonomies"}]}},"\/msls\/v1\/fix-all-taxonomies":{"namespace":"msls\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"dry_run":{"default":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/msls\/v1\/fix-all-taxonomies"}]}},"\/msls\/v1\/fix-post-parents":{"namespace":"msls\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"dry_run":{"default":true,"required":false},"source_blog_id":{"default":1,"required":false},"verbose":{"default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/msls\/v1\/fix-post-parents"}]}},"\/msls\/v1\/fix-post-dates":{"namespace":"msls\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"dry_run":{"default":true,"required":false},"source_blog_id":{"default":1,"required":false},"limit":{"default":0,"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/msls\/v1\/fix-post-dates"}]}},"\/msls\/v1\/outdated-translations":{"namespace":"msls\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"post_type":{"default":"all","required":false},"status":{"default":"publish","required":false},"languages":{"default":"","required":false},"source_blog_id":{"default":1,"required":false},"limit":{"default":0,"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/msls\/v1\/outdated-translations"}]}},"\/msls\/v1\/blog-language-map":{"namespace":"msls\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/msls\/v1\/blog-language-map"}]}},"\/yoast\/v1":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"yoast\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/yoast\/v1"}]}},"\/yoast\/v1\/file_size":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"type":"string","description":"The url to retrieve","required":true}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/yoast\/v1\/file_size"}]}},"\/yoast\/v1\/statistics":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/yoast\/v1\/statistics"}]}},"\/yoast\/v1\/new-content-type-visibility\/dismiss-post-type":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"postTypeName":{"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/yoast\/v1\/new-content-type-visibility\/dismiss-post-type"}]}},"\/yoast\/v1\/new-content-type-visibility\/dismiss-taxonomy":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"taxonomyName":{"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/yoast\/v1\/new-content-type-visibility\/dismiss-taxonomy"}]}},"\/yoast\/v1\/readability_scores":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"contentType":{"type":"string","required":true},"taxonomy":{"type":"string","default":"","required":false},"term":{"type":"integer","default":null,"required":false},"troubleshooting":{"type":"bool","default":null,"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/yoast\/v1\/readability_scores"}]}},"\/yoast\/v1\/seo_scores":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"contentType":{"type":"string","required":true},"taxonomy":{"type":"string","default":"","required":false},"term":{"type":"integer","default":null,"required":false},"troubleshooting":{"type":"bool","default":null,"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/yoast\/v1\/seo_scores"}]}},"\/yoast\/v1\/introductions\/(?P<introduction_id>[\\w-]+)\/seen":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"introduction_id":{"type":"string","required":true},"is_seen":{"type":"bool","default":true,"required":false}}}]},"\/yoast\/v1\/wistia_embed_permission":{"namespace":"yoast\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":{"value":{"type":"bool","default":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/yoast\/v1\/wistia_embed_permission"}]}},"\/yoast\/v1\/alerts\/dismiss":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"key":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/yoast\/v1\/alerts\/dismiss"}]}},"\/yoast\/v1\/configuration\/site_representation":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"company_or_person":{"type":"string","enum":["company","person"],"required":true},"company_name":{"type":"string","required":false},"company_logo":{"type":"string","required":false},"company_logo_id":{"type":"integer","required":false},"person_logo":{"type":"string","required":false},"person_logo_id":{"type":"integer","required":false},"company_or_person_user_id":{"type":"integer","required":false},"description":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/yoast\/v1\/configuration\/site_representation"}]}},"\/yoast\/v1\/configuration\/social_profiles":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"facebook_site":{"type":"string","required":false},"twitter_site":{"type":"string","required":false},"other_social_urls":{"type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/yoast\/v1\/configuration\/social_profiles"}]}},"\/yoast\/v1\/configuration\/check_capability":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"user_id":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/yoast\/v1\/configuration\/check_capability"}]}},"\/yoast\/v1\/configuration\/enable_tracking":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"tracking":{"type":"boolean","required":true}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/yoast\/v1\/configuration\/enable_tracking"}]}},"\/yoast\/v1\/configuration\/save_configuration_state":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"finishedSteps":{"type":"array","required":true}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/yoast\/v1\/configuration\/save_configuration_state"}]}},"\/yoast\/v1\/configuration\/get_configuration_state":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/yoast\/v1\/configuration\/get_configuration_state"}]}},"\/yoast\/v1\/import\/(?P<plugin>[\\w-]+)\/(?P<type>[\\w-]+)":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}]},"\/yoast\/v1\/get_head":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/yoast\/v1\/get_head"}]}},"\/yoast\/v1\/indexing\/posts":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/yoast\/v1\/indexing\/posts"}]}},"\/yoast\/v1\/indexing\/terms":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/yoast\/v1\/indexing\/terms"}]}},"\/yoast\/v1\/indexing\/post-type-archives":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/yoast\/v1\/indexing\/post-type-archives"}]}},"\/yoast\/v1\/indexing\/general":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/yoast\/v1\/indexing\/general"}]}},"\/yoast\/v1\/indexing\/prepare":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/yoast\/v1\/indexing\/prepare"}]}},"\/yoast\/v1\/indexing\/indexables-complete":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/yoast\/v1\/indexing\/indexables-complete"}]}},"\/yoast\/v1\/indexing\/complete":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/yoast\/v1\/indexing\/complete"}]}},"\/yoast\/v1\/link-indexing\/posts":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/yoast\/v1\/link-indexing\/posts"}]}},"\/yoast\/v1\/link-indexing\/terms":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/yoast\/v1\/link-indexing\/terms"}]}},"\/yoast\/v1\/integrations\/set_active":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"active":{"type":"boolean","required":true},"integration":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/yoast\/v1\/integrations\/set_active"}]}},"\/yoast\/v1\/meta\/search":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/yoast\/v1\/meta\/search"}]}},"\/yoast\/v1\/semrush\/authenticate":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"code":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/yoast\/v1\/semrush\/authenticate"}]}},"\/yoast\/v1\/semrush\/country_code":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"country_code":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/yoast\/v1\/semrush\/country_code"}]}},"\/yoast\/v1\/semrush\/related_keyphrases":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"keyphrase":{"required":true},"country_code":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/yoast\/v1\/semrush\/related_keyphrases"}]}},"\/yoast\/v1\/workouts":{"namespace":"yoast\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/yoast\/v1\/workouts"}]}},"\/redirection\/v1":{"namespace":"redirection\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"redirection\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/redirection\/v1"}]}},"\/redirection\/v1\/redirect":{"namespace":"redirection\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"filterBy":{"description":"Field to filter by","type":"enum","enum":["url","group"],"required":false},"filter":{"description":"Value to filter by","type":"string","required":false},"orderby":{"description":"Field to order results by","type":"enum","enum":["url","last_count","last_access","position","id"],"required":false},"direction":{"description":"Direction of ordered results","type":"enum","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"filterBy":{"description":"Field to filter by","type":"enum","enum":["url","group"],"required":false},"filter":{"description":"Value to filter by","type":"string","required":false},"orderby":{"description":"Field to order results by","type":"enum","enum":["url","last_count","last_access","position","id"],"required":false},"direction":{"description":"Direction of ordered results","type":"enum","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/redirection\/v1\/redirect"}]}},"\/redirection\/v1\/redirect\/(?P<id>[\\d]+)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/redirection\/v1\/bulk\/redirect\/(?P<bulk>delete|enable|disable|reset)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"filterBy":{"description":"Field to filter by","type":"enum","enum":["url","group"],"required":false},"filter":{"description":"Value to filter by","type":"string","required":false},"orderby":{"description":"Field to order results by","type":"enum","enum":["url","last_count","last_access","position","id"],"required":false},"direction":{"description":"Direction of ordered results","type":"enum","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false},"items":{"description":"Comma separated list of item IDs to perform action on","type":"string|integer","required":true}}}]},"\/redirection\/v1\/group":{"namespace":"redirection\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"filterBy":{"description":"Field to filter by","type":"enum","enum":["name","module"],"required":false},"filter":{"description":"Value to filter by","type":"string","required":false},"orderby":{"description":"Field to order results by","type":"enum","enum":["name","id"],"required":false},"direction":{"description":"Direction of ordered results","type":"enum","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"filterBy":{"description":"Field to filter by","type":"enum","enum":["name","module"],"required":false},"filter":{"description":"Value to filter by","type":"string","required":false},"orderby":{"description":"Field to order results by","type":"enum","enum":["name","id"],"required":false},"direction":{"description":"Direction of ordered results","type":"enum","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false},"moduleId":{"description":"Module ID","type":"integer","minimum":0,"maximum":3,"required":true},"name":{"description":"Group name","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/redirection\/v1\/group"}]}},"\/redirection\/v1\/group\/(?P<id>[\\d]+)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"moduleId":{"description":"Module ID","type":"integer","minimum":0,"maximum":3,"required":true},"name":{"description":"Group name","type":"string","required":true}}}]},"\/redirection\/v1\/bulk\/group\/(?P<bulk>delete|enable|disable)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"filterBy":{"description":"Field to filter by","type":"enum","enum":["name","module"],"required":false},"filter":{"description":"Value to filter by","type":"string","required":false},"orderby":{"description":"Field to order results by","type":"enum","enum":["name","id"],"required":false},"direction":{"description":"Direction of ordered results","type":"enum","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false},"items":{"description":"Comma separated list of item IDs to perform action on","type":"string|integer","required":true}}}]},"\/redirection\/v1\/log":{"namespace":"redirection\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"filterBy":{"description":"Field to filter by","type":"enum","enum":["url","ip","url-exact"],"required":false},"filter":{"description":"Value to filter by","type":"string","required":false},"orderby":{"description":"Field to order results by","type":"enum","enum":["url","ip"],"required":false},"direction":{"description":"Direction of ordered results","type":"enum","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"filterBy":{"description":"Field to filter by","type":"enum","enum":["url","ip","url-exact"],"required":false},"filter":{"description":"Value to filter by","type":"string","required":false},"orderby":{"description":"Field to order results by","type":"enum","enum":["url","ip"],"required":false},"direction":{"description":"Direction of ordered results","type":"enum","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/redirection\/v1\/log"}]}},"\/redirection\/v1\/bulk\/log\/(?P<bulk>delete)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"filterBy":{"description":"Field to filter by","type":"enum","enum":["url","ip","url-exact"],"required":false},"filter":{"description":"Value to filter by","type":"string","required":false},"orderby":{"description":"Field to order results by","type":"enum","enum":["url","ip","url-exact"],"required":false},"direction":{"description":"Direction of ordered results","type":"enum","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false},"items":{"description":"Comma separated list of item IDs to perform action on","type":"string|integer","required":true}}}]},"\/redirection\/v1\/404":{"namespace":"redirection\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"filterBy":{"description":"Field to filter by","type":"enum","enum":["ip","url","url-exact"],"required":false},"filter":{"description":"Value to filter by","type":"string","required":false},"orderby":{"description":"Field to order results by","type":"enum","enum":["ip","url","url-exact"],"required":false},"direction":{"description":"Direction of ordered results","type":"enum","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"filterBy":{"description":"Field to filter by","type":"enum","enum":["ip","url","url-exact"],"required":false},"filter":{"description":"Value to filter by","type":"string","required":false},"orderby":{"description":"Field to order results by","type":"enum","enum":["ip","url","url-exact"],"required":false},"direction":{"description":"Direction of ordered results","type":"enum","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/redirection\/v1\/404"}]}},"\/redirection\/v1\/bulk\/404\/(?P<bulk>delete)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"filterBy":{"description":"Field to filter by","type":"enum","enum":["ip","url","url-exact"],"required":false},"filter":{"description":"Value to filter by","type":"string","required":false},"orderby":{"description":"Field to order results by","type":"enum","enum":["ip","url","url-exact"],"required":false},"direction":{"description":"Direction of ordered results","type":"enum","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false},"items":{"description":"Comma separated list of item IDs to perform action on","type":"string|integer","required":true}}}]},"\/redirection\/v1\/setting":{"namespace":"redirection\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/redirection\/v1\/setting"}]}},"\/redirection\/v1\/plugin":{"namespace":"redirection\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/redirection\/v1\/plugin"}]}},"\/redirection\/v1\/plugin\/delete":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/redirection\/v1\/plugin\/delete"}]}},"\/redirection\/v1\/import\/file\/(?P<group_id>\\d+)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/redirection\/v1\/import\/plugin":{"namespace":"redirection\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/redirection\/v1\/import\/plugin"}]}},"\/redirection\/v1\/import\/plugin\/(?P<plugin>.*?)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/redirection\/v1\/export\/(?P<module>1|2|3|all)\/(?P<format>csv|apache|nginx|json)":{"namespace":"redirection\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/regenerate-thumbnails\/v1":{"namespace":"regenerate-thumbnails\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"regenerate-thumbnails\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/regenerate-thumbnails\/v1"}]}},"\/regenerate-thumbnails\/v1\/regenerate\/(?P<id>[\\d]+)":{"namespace":"regenerate-thumbnails\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"only_regenerate_missing_thumbnails":{"description":"Czy odnowi\u0107 tylko brakuj\u0105ce miniaturki? W\u0142\u0105cz \u017ceby by\u0142o szybciej.","type":"boolean","default":true,"required":false},"delete_unregistered_thumbnail_files":{"description":"Czy usun\u0105\u0107 wszystkie stare, od teraz nie zarejestrowane miniaturki plik\u00f3w?","type":"boolean","default":false,"required":false},"update_usages_in_posts":{"description":"Czy aktualizowa\u0107 tagi obrazka we wszystkich wpisach, kt\u00f3re korzystaj\u0105 z tego za\u0142\u0105cznika?","type":"boolean","default":true,"required":false},"update_usages_in_posts_post_type":{"description":"Rodzaje wpis\u00f3w do aktualizacji. Domy\u015blnie s\u0105 to wszystkie publiczne rodzaje wpis\u00f3w.","type":"array","default":[],"required":false},"update_usages_in_posts_post_ids":{"description":"Konkretne identyfikatory wpis\u00f3w do aktualizacji a nie jakiekolwiek wpisy kt\u00f3re u\u017cywaj\u0105 tego za\u0142\u0105cznika.","type":"array","default":[],"required":false},"update_usages_in_posts_posts_per_loop":{"description":"Liczba wpis\u00f3w do przetworzenia na jeden krok p\u0119tli. Jest to potrzebne do kontrolowania ilo\u015bci u\u017cytej pami\u0119ci i najprawdopodobniej nie potrzebujesz tego zmienia\u0107.","type":"integer","default":10,"required":false}}}]},"\/regenerate-thumbnails\/v1\/attachmentinfo\/(?P<id>[\\d]+)":{"namespace":"regenerate-thumbnails\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/regenerate-thumbnails\/v1\/featuredimages":{"namespace":"regenerate-thumbnails\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/regenerate-thumbnails\/v1\/featuredimages"}]}},"\/wp\/v2":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp\/v2","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/wp\/v2"}]}},"\/wp\/v2\/posts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ogranicz wyniki do pasuj\u0105cych do zapytania.","type":"string","required":false},"after":{"description":"Ogranicz wyniki do wpis\u00f3w opublikowanych po podanej dacie w formacie ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Ogranicz wyniki do zmienionych wpis\u00f3w po podanej dacie w formacie ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Ogranicz do wpis\u00f3w wybranych autor\u00f3w.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Prosz\u0119 si\u0119 upewni\u0107, \u017ce zestaw wynik\u00f3w wyklucza wpisy przypisane do poszczeg\u00f3lnych autor\u00f3w.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Ogranicz wyniki do wpis\u00f3w opublikowanych przed podan\u0105 dat\u0105 w formacie ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Ogranicz wyniki do zmienionych wpis\u00f3w przed podan\u0105 dat\u0105 w formacie ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Upewnij si\u0119, \u017ce zestaw wynik\u00f3w wyklucza okre\u015blone identyfikatory.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ogranicz zbi\u00f3r wynik\u00f3w do wybranych ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Jak interpretowa\u0107 dane wyszukiwania.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Przesu\u0144 wyniki o okre\u015blon\u0105 liczb\u0119 pozycji.","type":"integer","required":false},"order":{"description":"Sortowanie atrybut\u00f3w rosn\u0105co lub malej\u0105co.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortuj kolekcj\u0119 wed\u0142ug atrybutu wpisu.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Tablica nazw kolumn do przeszukania.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ogranicz do wpis\u00f3w posiadaj\u0105cych podan\u0105 uproszczon\u0105 nazw\u0119.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Wy\u0142\u0105cz z wynik\u00f3w wpisy, kt\u00f3re posiadaj\u0105 jeden lub wi\u0119cej status\u00f3w.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limit wyniku ustalony na podstawie relacji pomi\u0119dzy wieloma taksonomiami.\t","type":"string","enum":["AND","OR"],"required":false},"categories":{"description":"Ograniczaj zestaw wynik\u00f3w do pozycji z okre\u015blonymi terminami z taksonomii categories.","type":["object","array"],"oneOf":[{"title":"Lista identyfikatora terminu","description":"Dopasuj terminy do wypisanych identyfikator\u00f3w.","type":"array","items":{"type":"integer"}},{"title":"Identyfikator terminy w zapytaniu Taxonomy Query","description":"Wykonaj zaawansowane zapytanie z terminem.","type":"object","properties":{"terms":{"description":"Identyfikatory termin\u00f3w.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Czy uwzgl\u0119dnia\u0107 terminy podrz\u0119dne w terminach ograniczaj\u0105cych zestaw wynik\u00f3w.","type":"boolean","default":false},"operator":{"description":"Czy elementy musz\u0105 by\u0107 przypisane do wszystkich czy do wybranych termin\u00f3w?","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"categories_exclude":{"description":"Ogranicz do element\u00f3w posiadaj\u0105cych podany termin w taksonomii: categories.","type":["object","array"],"oneOf":[{"title":"Lista identyfikatora terminu","description":"Dopasuj terminy do wypisanych identyfikator\u00f3w.","type":"array","items":{"type":"integer"}},{"title":"Identyfikator terminy w zapytaniu Taxonomy Query","description":"Wykonaj zaawansowane zapytanie z terminem.","type":"object","properties":{"terms":{"description":"Identyfikatory termin\u00f3w.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Czy uwzgl\u0119dnia\u0107 terminy podrz\u0119dne w terminach ograniczaj\u0105cych zestaw wynik\u00f3w.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"tags":{"description":"Ograniczaj zestaw wynik\u00f3w do pozycji z okre\u015blonymi terminami z taksonomii tags.","type":["object","array"],"oneOf":[{"title":"Lista identyfikatora terminu","description":"Dopasuj terminy do wypisanych identyfikator\u00f3w.","type":"array","items":{"type":"integer"}},{"title":"Identyfikator terminy w zapytaniu Taxonomy Query","description":"Wykonaj zaawansowane zapytanie z terminem.","type":"object","properties":{"terms":{"description":"Identyfikatory termin\u00f3w.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Czy elementy musz\u0105 by\u0107 przypisane do wszystkich czy do wybranych termin\u00f3w?","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"tags_exclude":{"description":"Ogranicz do element\u00f3w posiadaj\u0105cych podany termin w taksonomii: tags.","type":["object","array"],"oneOf":[{"title":"Lista identyfikatora terminu","description":"Dopasuj terminy do wypisanych identyfikator\u00f3w.","type":"array","items":{"type":"integer"}},{"title":"Identyfikator terminy w zapytaniu Taxonomy Query","description":"Wykonaj zaawansowane zapytanie z terminem.","type":"object","properties":{"terms":{"description":"Identyfikatory termin\u00f3w.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"sticky":{"description":"Ogranicz zestaw wynik\u00f3w do przypi\u0119tych element\u00f3w.","type":"boolean","required":false},"format":{"description":"Ogranicz zestaw wynik\u00f3w do element\u00f3w przypisanych do jednego lub wi\u0119cej wybranych format\u00f3w.","type":"array","uniqueItems":true,"items":{"enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Data publikacji wpisu w strefie czasowej witryny.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data wpisu zosta\u0142a opublikowana jako GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeryczny identyfikator dla wpisu unikatowy dla jego typu.","type":"string","required":false},"status":{"description":"Nazwa statusu wpisu.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Has\u0142o ochrony dost\u0119pu do tre\u015bci i zajawki.","type":"string","required":false},"title":{"description":"Tytu\u0142 wpisu.","type":"object","properties":{"raw":{"description":"Tytu\u0142 wpisu, istniej\u0105cy w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Tytu\u0142 HTML wpisu, przekszta\u0142cony do wy\u015bwietlania.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Tre\u015b\u0107 wpisu.","type":"object","properties":{"raw":{"description":"Tre\u015b\u0107 wpisu, tak jak zosta\u0142a zapisana w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Zawarto\u015b\u0107 HMTL wpisu, przetworzona do wy\u015bwietlenia.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Wersja bloku tre\u015bci u\u017cywanego we wpisie.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Czy tre\u015b\u0107 jest chronia has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Identyfikator autora wpisu.","type":"integer","required":false},"excerpt":{"description":"Zajawka wpisu.","type":"object","properties":{"raw":{"description":"Zajawka wpisu, tak jak wyst\u0119puje w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Wycinek HTML dla wpisu, przekszta\u0142cony do wy\u015bwietlenia.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Czy zajawka zabezpieczona jest has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Identyfikator wyr\u00f3\u017cniaj\u0105cego pliku medialnego wpisu.","type":"integer","required":false},"comment_status":{"description":"To czy wpis mo\u017ce by\u0107 komentowany.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"To, czy wpis mo\u017ce by\u0107 pingowany.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"Format wpisu.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Pola meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"Czy wpis powinien by\u0107 traktowany jako przypi\u0119ty.","type":"boolean","required":false},"template":{"description":"Plik motywu u\u017cywany do wy\u015bwietlania wpisu.","type":"string","required":false},"categories":{"description":"Terminy przypisane do wpisu w taksonomii: category","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Terminy przypisane do wpisu w taksonomii: post_tag","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/wp\/v2\/posts"}]}},"\/wp\/v2\/posts\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator wpisu.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Nadpisz domy\u015bln\u0105 d\u0142ugo\u015b\u0107 zajawki.","type":"integer","required":false},"password":{"description":"Has\u0142o dla wpisu, je\u015bli jest on chroniony has\u0142em.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator wpisu.","type":"integer","required":false},"date":{"description":"Data publikacji wpisu w strefie czasowej witryny.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data wpisu zosta\u0142a opublikowana jako GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeryczny identyfikator dla wpisu unikatowy dla jego typu.","type":"string","required":false},"status":{"description":"Nazwa statusu wpisu.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Has\u0142o ochrony dost\u0119pu do tre\u015bci i zajawki.","type":"string","required":false},"title":{"description":"Tytu\u0142 wpisu.","type":"object","properties":{"raw":{"description":"Tytu\u0142 wpisu, istniej\u0105cy w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Tytu\u0142 HTML wpisu, przekszta\u0142cony do wy\u015bwietlania.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Tre\u015b\u0107 wpisu.","type":"object","properties":{"raw":{"description":"Tre\u015b\u0107 wpisu, tak jak zosta\u0142a zapisana w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Zawarto\u015b\u0107 HMTL wpisu, przetworzona do wy\u015bwietlenia.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Wersja bloku tre\u015bci u\u017cywanego we wpisie.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Czy tre\u015b\u0107 jest chronia has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Identyfikator autora wpisu.","type":"integer","required":false},"excerpt":{"description":"Zajawka wpisu.","type":"object","properties":{"raw":{"description":"Zajawka wpisu, tak jak wyst\u0119puje w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Wycinek HTML dla wpisu, przekszta\u0142cony do wy\u015bwietlenia.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Czy zajawka zabezpieczona jest has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Identyfikator wyr\u00f3\u017cniaj\u0105cego pliku medialnego wpisu.","type":"integer","required":false},"comment_status":{"description":"To czy wpis mo\u017ce by\u0107 komentowany.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"To, czy wpis mo\u017ce by\u0107 pingowany.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"Format wpisu.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Pola meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"Czy wpis powinien by\u0107 traktowany jako przypi\u0119ty.","type":"boolean","required":false},"template":{"description":"Plik motywu u\u017cywany do wy\u015bwietlania wpisu.","type":"string","required":false},"categories":{"description":"Terminy przypisane do wpisu w taksonomii: category","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Terminy przypisane do wpisu w taksonomii: post_tag","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator wpisu.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Okre\u015bla, czy pomin\u0105\u0107 kosz i wymusi\u0107 usuni\u0119cie.","required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator wpisu nadrz\u0119dnego wersji.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ogranicz wyniki do pasuj\u0105cych do zapytania.","type":"string","required":false},"exclude":{"description":"Upewnij si\u0119, \u017ce zestaw wynik\u00f3w wyklucza okre\u015blone identyfikatory.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ogranicz zbi\u00f3r wynik\u00f3w do wybranych ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Przesu\u0144 wyniki o okre\u015blon\u0105 liczb\u0119 pozycji.","type":"integer","required":false},"order":{"description":"Sortowanie atrybut\u00f3w rosn\u0105co lub malej\u0105co.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortuj zbi\u00f3r po atrybutach obiektu.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator wpisu nadrz\u0119dnego wersji.","type":"integer","required":false},"id":{"description":"Unikatowy identyfikator wersji.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Identyfikator wpisu nadrz\u0119dnego wersji.","type":"integer","required":false},"id":{"description":"Unikatowy identyfikator wersji.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Musi by\u0107 w\u0142\u0105czone, poniewa\u017c w wersjach nie u\u017cywamy kosza.","required":false}}}]},"\/wp\/v2\/posts\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator elementu nadrz\u0119dnego autozapisu.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Identyfikator elementu nadrz\u0119dnego autozapisu.","type":"integer","required":false},"date":{"description":"Data publikacji wpisu w strefie czasowej witryny.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data wpisu zosta\u0142a opublikowana jako GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeryczny identyfikator dla wpisu unikatowy dla jego typu.","type":"string","required":false},"status":{"description":"Nazwa statusu wpisu.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Has\u0142o ochrony dost\u0119pu do tre\u015bci i zajawki.","type":"string","required":false},"title":{"description":"Tytu\u0142 wpisu.","type":"object","properties":{"raw":{"description":"Tytu\u0142 wpisu, istniej\u0105cy w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Tytu\u0142 HTML wpisu, przekszta\u0142cony do wy\u015bwietlania.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Tre\u015b\u0107 wpisu.","type":"object","properties":{"raw":{"description":"Tre\u015b\u0107 wpisu, tak jak zosta\u0142a zapisana w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Zawarto\u015b\u0107 HMTL wpisu, przetworzona do wy\u015bwietlenia.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Wersja bloku tre\u015bci u\u017cywanego we wpisie.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Czy tre\u015b\u0107 jest chronia has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Identyfikator autora wpisu.","type":"integer","required":false},"excerpt":{"description":"Zajawka wpisu.","type":"object","properties":{"raw":{"description":"Zajawka wpisu, tak jak wyst\u0119puje w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Wycinek HTML dla wpisu, przekszta\u0142cony do wy\u015bwietlenia.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Czy zajawka zabezpieczona jest has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Identyfikator wyr\u00f3\u017cniaj\u0105cego pliku medialnego wpisu.","type":"integer","required":false},"comment_status":{"description":"To czy wpis mo\u017ce by\u0107 komentowany.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"To, czy wpis mo\u017ce by\u0107 pingowany.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"Format wpisu.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Pola meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"Czy wpis powinien by\u0107 traktowany jako przypi\u0119ty.","type":"boolean","required":false},"template":{"description":"Plik motywu u\u017cywany do wy\u015bwietlania wpisu.","type":"string","required":false},"categories":{"description":"Terminy przypisane do wpisu w taksonomii: category","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Terminy przypisane do wpisu w taksonomii: post_tag","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator elementu nadrz\u0119dnego autozapisu.","type":"integer","required":false},"id":{"description":"Identyfikator automatycznego zapisu.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/pages":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ogranicz wyniki do pasuj\u0105cych do zapytania.","type":"string","required":false},"after":{"description":"Ogranicz wyniki do wpis\u00f3w opublikowanych po podanej dacie w formacie ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Ogranicz wyniki do zmienionych wpis\u00f3w po podanej dacie w formacie ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Ogranicz do wpis\u00f3w wybranych autor\u00f3w.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Prosz\u0119 si\u0119 upewni\u0107, \u017ce zestaw wynik\u00f3w wyklucza wpisy przypisane do poszczeg\u00f3lnych autor\u00f3w.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Ogranicz wyniki do wpis\u00f3w opublikowanych przed podan\u0105 dat\u0105 w formacie ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Ogranicz wyniki do zmienionych wpis\u00f3w przed podan\u0105 dat\u0105 w formacie ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Upewnij si\u0119, \u017ce zestaw wynik\u00f3w wyklucza okre\u015blone identyfikatory.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ogranicz zbi\u00f3r wynik\u00f3w do wybranych ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Ogranicz wyniki do wpis\u00f3w z okre\u015blon\u0105 warto\u015bci\u0105 menu_order.","type":"integer","required":false},"search_semantics":{"description":"Jak interpretowa\u0107 dane wyszukiwania.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Przesu\u0144 wyniki o okre\u015blon\u0105 liczb\u0119 pozycji.","type":"integer","required":false},"order":{"description":"Sortowanie atrybut\u00f3w rosn\u0105co lub malej\u0105co.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortuj kolekcj\u0119 wed\u0142ug atrybutu wpisu.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"parent":{"description":"Ogranicz wyniki do obiekt\u00f3w, kt\u00f3rych elementy nadrz\u0119dne maj\u0105 wybrane identyfikatory.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Ogranicz zestaw wynik\u00f3w do wszystkich element\u00f3w z wyj\u0105tkiem tych o okre\u015blonym identyfikatorze nadrz\u0119dnym.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Tablica nazw kolumn do przeszukania.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ogranicz do wpis\u00f3w posiadaj\u0105cych podan\u0105 uproszczon\u0105 nazw\u0119.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Wy\u0142\u0105cz z wynik\u00f3w wpisy, kt\u00f3re posiadaj\u0105 jeden lub wi\u0119cej status\u00f3w.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Data publikacji wpisu w strefie czasowej witryny.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data wpisu zosta\u0142a opublikowana jako GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeryczny identyfikator dla wpisu unikatowy dla jego typu.","type":"string","required":false},"status":{"description":"Nazwa statusu wpisu.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Has\u0142o ochrony dost\u0119pu do tre\u015bci i zajawki.","type":"string","required":false},"parent":{"description":"Identyfikator elementu nadrz\u0119dnego wpisu.","type":"integer","required":false},"title":{"description":"Tytu\u0142 wpisu.","type":"object","properties":{"raw":{"description":"Tytu\u0142 wpisu, istniej\u0105cy w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Tytu\u0142 HTML wpisu, przekszta\u0142cony do wy\u015bwietlania.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Tre\u015b\u0107 wpisu.","type":"object","properties":{"raw":{"description":"Tre\u015b\u0107 wpisu, tak jak zosta\u0142a zapisana w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Zawarto\u015b\u0107 HMTL wpisu, przetworzona do wy\u015bwietlenia.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Wersja bloku tre\u015bci u\u017cywanego we wpisie.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Czy tre\u015b\u0107 jest chronia has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Identyfikator autora wpisu.","type":"integer","required":false},"excerpt":{"description":"Zajawka wpisu.","type":"object","properties":{"raw":{"description":"Zajawka wpisu, tak jak wyst\u0119puje w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Wycinek HTML dla wpisu, przekszta\u0142cony do wy\u015bwietlenia.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Czy zajawka zabezpieczona jest has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Identyfikator wyr\u00f3\u017cniaj\u0105cego pliku medialnego wpisu.","type":"integer","required":false},"comment_status":{"description":"To czy wpis mo\u017ce by\u0107 komentowany.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"To, czy wpis mo\u017ce by\u0107 pingowany.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"Kolejno\u015b\u0107 wpis\u00f3w w stosunku do innych.","type":"integer","required":false},"meta":{"description":"Pola meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Plik motywu u\u017cywany do wy\u015bwietlania wpisu.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/wp\/v2\/pages"}]}},"\/wp\/v2\/pages\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator wpisu.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Nadpisz domy\u015bln\u0105 d\u0142ugo\u015b\u0107 zajawki.","type":"integer","required":false},"password":{"description":"Has\u0142o dla wpisu, je\u015bli jest on chroniony has\u0142em.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator wpisu.","type":"integer","required":false},"date":{"description":"Data publikacji wpisu w strefie czasowej witryny.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data wpisu zosta\u0142a opublikowana jako GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeryczny identyfikator dla wpisu unikatowy dla jego typu.","type":"string","required":false},"status":{"description":"Nazwa statusu wpisu.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Has\u0142o ochrony dost\u0119pu do tre\u015bci i zajawki.","type":"string","required":false},"parent":{"description":"Identyfikator elementu nadrz\u0119dnego wpisu.","type":"integer","required":false},"title":{"description":"Tytu\u0142 wpisu.","type":"object","properties":{"raw":{"description":"Tytu\u0142 wpisu, istniej\u0105cy w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Tytu\u0142 HTML wpisu, przekszta\u0142cony do wy\u015bwietlania.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Tre\u015b\u0107 wpisu.","type":"object","properties":{"raw":{"description":"Tre\u015b\u0107 wpisu, tak jak zosta\u0142a zapisana w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Zawarto\u015b\u0107 HMTL wpisu, przetworzona do wy\u015bwietlenia.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Wersja bloku tre\u015bci u\u017cywanego we wpisie.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Czy tre\u015b\u0107 jest chronia has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Identyfikator autora wpisu.","type":"integer","required":false},"excerpt":{"description":"Zajawka wpisu.","type":"object","properties":{"raw":{"description":"Zajawka wpisu, tak jak wyst\u0119puje w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Wycinek HTML dla wpisu, przekszta\u0142cony do wy\u015bwietlenia.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Czy zajawka zabezpieczona jest has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Identyfikator wyr\u00f3\u017cniaj\u0105cego pliku medialnego wpisu.","type":"integer","required":false},"comment_status":{"description":"To czy wpis mo\u017ce by\u0107 komentowany.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"To, czy wpis mo\u017ce by\u0107 pingowany.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"Kolejno\u015b\u0107 wpis\u00f3w w stosunku do innych.","type":"integer","required":false},"meta":{"description":"Pola meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Plik motywu u\u017cywany do wy\u015bwietlania wpisu.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator wpisu.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Okre\u015bla, czy pomin\u0105\u0107 kosz i wymusi\u0107 usuni\u0119cie.","required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator wpisu nadrz\u0119dnego wersji.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ogranicz wyniki do pasuj\u0105cych do zapytania.","type":"string","required":false},"exclude":{"description":"Upewnij si\u0119, \u017ce zestaw wynik\u00f3w wyklucza okre\u015blone identyfikatory.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ogranicz zbi\u00f3r wynik\u00f3w do wybranych ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Przesu\u0144 wyniki o okre\u015blon\u0105 liczb\u0119 pozycji.","type":"integer","required":false},"order":{"description":"Sortowanie atrybut\u00f3w rosn\u0105co lub malej\u0105co.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortuj zbi\u00f3r po atrybutach obiektu.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator wpisu nadrz\u0119dnego wersji.","type":"integer","required":false},"id":{"description":"Unikatowy identyfikator wersji.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Identyfikator wpisu nadrz\u0119dnego wersji.","type":"integer","required":false},"id":{"description":"Unikatowy identyfikator wersji.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Musi by\u0107 w\u0142\u0105czone, poniewa\u017c w wersjach nie u\u017cywamy kosza.","required":false}}}]},"\/wp\/v2\/pages\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator elementu nadrz\u0119dnego autozapisu.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Identyfikator elementu nadrz\u0119dnego wpisu.","type":"integer","required":false},"date":{"description":"Data publikacji wpisu w strefie czasowej witryny.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data wpisu zosta\u0142a opublikowana jako GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeryczny identyfikator dla wpisu unikatowy dla jego typu.","type":"string","required":false},"status":{"description":"Nazwa statusu wpisu.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Has\u0142o ochrony dost\u0119pu do tre\u015bci i zajawki.","type":"string","required":false},"title":{"description":"Tytu\u0142 wpisu.","type":"object","properties":{"raw":{"description":"Tytu\u0142 wpisu, istniej\u0105cy w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Tytu\u0142 HTML wpisu, przekszta\u0142cony do wy\u015bwietlania.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Tre\u015b\u0107 wpisu.","type":"object","properties":{"raw":{"description":"Tre\u015b\u0107 wpisu, tak jak zosta\u0142a zapisana w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Zawarto\u015b\u0107 HMTL wpisu, przetworzona do wy\u015bwietlenia.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Wersja bloku tre\u015bci u\u017cywanego we wpisie.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Czy tre\u015b\u0107 jest chronia has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Identyfikator autora wpisu.","type":"integer","required":false},"excerpt":{"description":"Zajawka wpisu.","type":"object","properties":{"raw":{"description":"Zajawka wpisu, tak jak wyst\u0119puje w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Wycinek HTML dla wpisu, przekszta\u0142cony do wy\u015bwietlenia.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Czy zajawka zabezpieczona jest has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Identyfikator wyr\u00f3\u017cniaj\u0105cego pliku medialnego wpisu.","type":"integer","required":false},"comment_status":{"description":"To czy wpis mo\u017ce by\u0107 komentowany.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"To, czy wpis mo\u017ce by\u0107 pingowany.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"Kolejno\u015b\u0107 wpis\u00f3w w stosunku do innych.","type":"integer","required":false},"meta":{"description":"Pola meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Plik motywu u\u017cywany do wy\u015bwietlania wpisu.","type":"string","required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator elementu nadrz\u0119dnego autozapisu.","type":"integer","required":false},"id":{"description":"Identyfikator automatycznego zapisu.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/media":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ogranicz wyniki do pasuj\u0105cych do zapytania.","type":"string","required":false},"after":{"description":"Ogranicz wyniki do wpis\u00f3w opublikowanych po podanej dacie w formacie ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Ogranicz wyniki do zmienionych wpis\u00f3w po podanej dacie w formacie ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Ogranicz do wpis\u00f3w wybranych autor\u00f3w.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Prosz\u0119 si\u0119 upewni\u0107, \u017ce zestaw wynik\u00f3w wyklucza wpisy przypisane do poszczeg\u00f3lnych autor\u00f3w.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Ogranicz wyniki do wpis\u00f3w opublikowanych przed podan\u0105 dat\u0105 w formacie ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Ogranicz wyniki do zmienionych wpis\u00f3w przed podan\u0105 dat\u0105 w formacie ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Upewnij si\u0119, \u017ce zestaw wynik\u00f3w wyklucza okre\u015blone identyfikatory.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ogranicz zbi\u00f3r wynik\u00f3w do wybranych ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Jak interpretowa\u0107 dane wyszukiwania.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Przesu\u0144 wyniki o okre\u015blon\u0105 liczb\u0119 pozycji.","type":"integer","required":false},"order":{"description":"Sortowanie atrybut\u00f3w rosn\u0105co lub malej\u0105co.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortuj kolekcj\u0119 wed\u0142ug atrybutu wpisu.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"parent":{"description":"Ogranicz wyniki do obiekt\u00f3w, kt\u00f3rych elementy nadrz\u0119dne maj\u0105 wybrane identyfikatory.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Ogranicz zestaw wynik\u00f3w do wszystkich element\u00f3w z wyj\u0105tkiem tych o okre\u015blonym identyfikatorze nadrz\u0119dnym.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Tablica nazw kolumn do przeszukania.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ogranicz do wpis\u00f3w posiadaj\u0105cych podan\u0105 uproszczon\u0105 nazw\u0119.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"inherit","description":"Wy\u0142\u0105cz z wynik\u00f3w wpisy, kt\u00f3re posiadaj\u0105 jeden lub wi\u0119cej status\u00f3w.","type":"array","items":{"enum":["inherit","private","trash"],"type":"string"},"required":false},"media_type":{"default":null,"description":"Ogranicz wyniki do za\u0142\u0105cznik\u00f3w do odkre\u015blonego rodzaju medi\u00f3w.","type":"string","enum":["image","video","audio","application","font"],"required":false},"mime_type":{"default":null,"description":"Ogranicz do za\u0142\u0105cznik\u00f3w o wybranym typie MIME.","type":"string","required":false}}},{"methods":["POST"],"args":{"date":{"description":"Data publikacji wpisu w strefie czasowej witryny.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data wpisu zosta\u0142a opublikowana jako GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeryczny identyfikator dla wpisu unikatowy dla jego typu.","type":"string","required":false},"status":{"description":"Nazwa statusu wpisu.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"title":{"description":"Tytu\u0142 wpisu.","type":"object","properties":{"raw":{"description":"Tytu\u0142 wpisu, istniej\u0105cy w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Tytu\u0142 HTML wpisu, przekszta\u0142cony do wy\u015bwietlania.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Identyfikator autora wpisu.","type":"integer","required":false},"featured_media":{"description":"Identyfikator wyr\u00f3\u017cniaj\u0105cego pliku medialnego wpisu.","type":"integer","required":false},"comment_status":{"description":"To czy wpis mo\u017ce by\u0107 komentowany.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"To, czy wpis mo\u017ce by\u0107 pingowany.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Pola meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Plik motywu u\u017cywany do wy\u015bwietlania wpisu.","type":"string","required":false},"alt_text":{"description":"Tekst alternatywny wy\u015bwietlany zamiast za\u0142\u0105cznika.","type":"string","required":false},"caption":{"description":"Podpis za\u0142\u0105cznika.","type":"object","properties":{"raw":{"description":"Podpis za\u0142\u0105cznika, dok\u0142adnie taki jak w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Podpis HTML dla za\u0142\u0105cznik\u00f3w, przekszta\u0142cony do wy\u015bwietlania.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Opis za\u0142\u0105cznika.","type":"object","properties":{"raw":{"description":"Opis za\u0142\u0105cznika, dok\u0142adnie taki jak w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Opis HTML za\u0142\u0105cznika - gotowy do wy\u015bwietlania ","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"Identyfikator wpisu powi\u0105zanego z za\u0142\u0105cznikiem.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/wp\/v2\/media"}]}},"\/wp\/v2\/media\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unikatowy identyfikator wpisu.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unikatowy identyfikator wpisu.","type":"integer","required":false},"date":{"description":"Data publikacji wpisu w strefie czasowej witryny.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data wpisu zosta\u0142a opublikowana jako GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeryczny identyfikator dla wpisu unikatowy dla jego typu.","type":"string","required":false},"status":{"description":"Nazwa statusu wpisu.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"title":{"description":"Tytu\u0142 wpisu.","type":"object","properties":{"raw":{"description":"Tytu\u0142 wpisu, istniej\u0105cy w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Tytu\u0142 HTML wpisu, przekszta\u0142cony do wy\u015bwietlania.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Identyfikator autora wpisu.","type":"integer","required":false},"featured_media":{"description":"Identyfikator wyr\u00f3\u017cniaj\u0105cego pliku medialnego wpisu.","type":"integer","required":false},"comment_status":{"description":"To czy wpis mo\u017ce by\u0107 komentowany.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"To, czy wpis mo\u017ce by\u0107 pingowany.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Pola meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Plik motywu u\u017cywany do wy\u015bwietlania wpisu.","type":"string","required":false},"alt_text":{"description":"Tekst alternatywny wy\u015bwietlany zamiast za\u0142\u0105cznika.","type":"string","required":false},"caption":{"description":"Podpis za\u0142\u0105cznika.","type":"object","properties":{"raw":{"description":"Podpis za\u0142\u0105cznika, dok\u0142adnie taki jak w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Podpis HTML dla za\u0142\u0105cznik\u00f3w, przekszta\u0142cony do wy\u015bwietlania.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Opis za\u0142\u0105cznika.","type":"object","properties":{"raw":{"description":"Opis za\u0142\u0105cznika, dok\u0142adnie taki jak w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Opis HTML za\u0142\u0105cznika - gotowy do wy\u015bwietlania ","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"Identyfikator wpisu powi\u0105zanego z za\u0142\u0105cznikiem.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unikatowy identyfikator wpisu.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Okre\u015bla, czy pomin\u0105\u0107 kosz i wymusi\u0107 usuni\u0119cie.","required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/post-process":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Unikatowy identyfikator za\u0142\u0105czonego medium.","type":"integer","required":false},"action":{"type":"string","enum":["create-image-subsizes"],"required":true}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/edit":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"src":{"description":"Adres URL do edytowanego obrazka.","type":"string","format":"uri","required":true},"modifiers":{"description":"Tablica edycji obrazka.","type":"array","minItems":1,"items":{"description":"Edycja obrazka.","type":"object","required":["type","args"],"oneOf":[{"title":"Obracanie","properties":{"type":{"description":"Typ obracania.","type":"string","enum":["rotate"]},"args":{"description":"Argumenty obracania.","type":"object","required":["angle"],"properties":{"angle":{"description":"K\u0105t obrotu zgodnie z ruchem wskaz\u00f3wek zegara w stopniach.","type":"number"}}}}},{"title":"Kadruj","properties":{"type":{"description":"Typ kadrowania.","type":"string","enum":["crop"]},"args":{"description":"Skopiuj argumenty.","type":"object","required":["left","top","width","height"],"properties":{"left":{"description":"Pozycja od lewej do rozpocz\u0119cia przycinania jako procent d\u0142ugo\u015bci obrazu.","type":"number"},"top":{"description":"Pozycja od g\u00f3ry do rozpocz\u0119cia przycinania jako procent wysoko\u015bci obrazu.","type":"number"},"width":{"description":"Szeroko\u015b\u0107 kadrowania jako procent szeroko\u015bci obrazka.","type":"number"},"height":{"description":"Wysoko\u015b\u0107 kadrowania jako procent wysoko\u015bci obrazka.","type":"number"}}}}}]},"required":false},"rotation":{"description":"Stopie\u0144 obr\u00f3cenia obrazu zgodnie z ruchem wskaz\u00f3wek zegara w stopniach. PRZESTARZA\u0141E: Zamiast tego u\u017cyj \u201emodyfikator\u00f3w\u201d.","type":"integer","minimum":0,"exclusiveMinimum":true,"maximum":360,"exclusiveMaximum":true,"required":false},"x":{"description":"Warto\u015b\u0107 procentowa obrazu - pozycja X przyci\u0119cia obrazu. PRZESTARZA\u0141E: Zamiast tego prosz\u0119 u\u017cy\u0107 `modyfikator\u00f3w`.","type":"number","minimum":0,"maximum":100,"required":false},"y":{"description":"Warto\u015b\u0107 procentowa obrazu - pozycja Y przyci\u0119cia obrazu. PRZESTARZA\u0141E: Zamiast tego prosz\u0119 u\u017cy\u0107 `modyfikator\u00f3w`.","type":"number","minimum":0,"maximum":100,"required":false},"width":{"description":"Warto\u015b\u0107 procentowa obrazu - d\u0142ugo\u015b\u0107 przyci\u0119cia obrazu. PRZESTARZA\u0141E: Zamiast tego prosz\u0119 u\u017cy\u0107 `modyfikator\u00f3w`.","type":"number","minimum":0,"maximum":100,"required":false},"height":{"description":"Warto\u015b\u0107 procentowa obrazu - wysoko\u015b\u0107 przyci\u0119cia obrazu. PRZESTARZA\u0141E: Zamiast tego prosz\u0119 u\u017cy\u0107 `modyfikator\u00f3w`.","type":"number","minimum":0,"maximum":100,"required":false}}}]},"\/wp\/v2\/menu-items":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ogranicz wyniki do pasuj\u0105cych do zapytania.","type":"string","required":false},"after":{"description":"Ogranicz wyniki do wpis\u00f3w opublikowanych po podanej dacie w formacie ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Ogranicz wyniki do zmienionych wpis\u00f3w po podanej dacie w formacie ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Ogranicz wyniki do wpis\u00f3w opublikowanych przed podan\u0105 dat\u0105 w formacie ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Ogranicz wyniki do zmienionych wpis\u00f3w przed podan\u0105 dat\u0105 w formacie ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Upewnij si\u0119, \u017ce zestaw wynik\u00f3w wyklucza okre\u015blone identyfikatory.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ogranicz zbi\u00f3r wynik\u00f3w do wybranych ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Jak interpretowa\u0107 dane wyszukiwania.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Przesu\u0144 wyniki o okre\u015blon\u0105 liczb\u0119 pozycji.","type":"integer","required":false},"order":{"description":"Sortowanie atrybut\u00f3w rosn\u0105co lub malej\u0105co.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortuj zbi\u00f3r po atrybutach obiektu.","type":"string","default":"menu_order","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Tablica nazw kolumn do przeszukania.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ogranicz do wpis\u00f3w posiadaj\u0105cych podan\u0105 uproszczon\u0105 nazw\u0119.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Wy\u0142\u0105cz z wynik\u00f3w wpisy, kt\u00f3re posiadaj\u0105 jeden lub wi\u0119cej status\u00f3w.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limit wyniku ustalony na podstawie relacji pomi\u0119dzy wieloma taksonomiami.\t","type":"string","enum":["AND","OR"],"required":false},"menus":{"description":"Ograniczaj zestaw wynik\u00f3w do pozycji z okre\u015blonymi terminami z taksonomii menus.","type":["object","array"],"oneOf":[{"title":"Lista identyfikatora terminu","description":"Dopasuj terminy do wypisanych identyfikator\u00f3w.","type":"array","items":{"type":"integer"}},{"title":"Identyfikator terminy w zapytaniu Taxonomy Query","description":"Wykonaj zaawansowane zapytanie z terminem.","type":"object","properties":{"terms":{"description":"Identyfikatory termin\u00f3w.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Czy elementy musz\u0105 by\u0107 przypisane do wszystkich czy do wybranych termin\u00f3w?","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"menus_exclude":{"description":"Ogranicz do element\u00f3w posiadaj\u0105cych podany termin w taksonomii: menus.","type":["object","array"],"oneOf":[{"title":"Lista identyfikatora terminu","description":"Dopasuj terminy do wypisanych identyfikator\u00f3w.","type":"array","items":{"type":"integer"}},{"title":"Identyfikator terminy w zapytaniu Taxonomy Query","description":"Wykonaj zaawansowane zapytanie z terminem.","type":"object","properties":{"terms":{"description":"Identyfikatory termin\u00f3w.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"menu_order":{"description":"Ogranicz wyniki do wpis\u00f3w z okre\u015blon\u0105 warto\u015bci\u0105 menu_order.","type":"integer","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"title":{"description":"Tytu\u0142 obiektu.","type":["string","object"],"properties":{"raw":{"description":"Tytu\u0142 obiektu, istniej\u0105cy w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Tytu\u0142 HTML obiektu, przekszta\u0142cony do wy\u015bwietlania.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"default":"custom","description":"Rodzina pierwotnie reprezentowanych obiekt\u00f3w, na przyk\u0142ad \u201epost_type\u201d lub \u201etaxonomy\u201d.","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"default":"publish","description":"Nazwa statusu obiektu.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"parent":{"default":0,"description":"Identyfikator elementu nadrz\u0119dnego dla obiektu.","type":"integer","minimum":0,"required":false},"attr_title":{"description":"Tekst atrybutu title odno\u015bnika dla elementu menu.","type":"string","required":false},"classes":{"description":"Nazwy klas odno\u015bnika dla elementu menu.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"Opis elementu menu.","type":"string","required":false},"menu_order":{"default":1,"description":"Identyfikator w bazie danych dla elementu nav_menu_item, kt\u00f3ry jest elementem nadrz\u0119dnym menu tego elementu, je\u015bli istnieje, w przeciwnym razie 0.","type":"integer","minimum":1,"required":false},"object":{"description":"Typ pierwotnie reprezentowanego obiektu, na przyk\u0142ad \u201ekategoria\u201d, \u201ewpis\u201d lub \u201eza\u0142\u0105cznik\u201d.","type":"string","required":false},"object_id":{"default":0,"description":"Identyfikator w bazie danych oryginalnego obiektu, kt\u00f3ry reprezentuje wybran\u0105 pozycj\u0119 menu, np.  identyfikator wpisu i term_id dla kategorii.","type":"integer","minimum":0,"required":false},"target":{"description":"Atrybut target odno\u015bnika dla elementu menu.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"Adres URL do kt\u00f3rego prowadzi element menu.","type":"string","format":"uri","required":false},"xfn":{"description":"Relacja XFN odno\u015bnika w elemencie menu.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Poj\u0119cia przypisane do obiektu w taksonomii o nazwie: nav_menu","type":"integer","required":false},"meta":{"description":"Pola meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/wp\/v2\/menu-items"}]}},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator wpisu.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator wpisu.","type":"integer","required":false},"title":{"description":"Tytu\u0142 obiektu.","type":["string","object"],"properties":{"raw":{"description":"Tytu\u0142 obiektu, istniej\u0105cy w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Tytu\u0142 HTML obiektu, przekszta\u0142cony do wy\u015bwietlania.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"Rodzina pierwotnie reprezentowanych obiekt\u00f3w, na przyk\u0142ad \u201epost_type\u201d lub \u201etaxonomy\u201d.","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"Nazwa statusu obiektu.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"parent":{"description":"Identyfikator elementu nadrz\u0119dnego dla obiektu.","type":"integer","minimum":0,"required":false},"attr_title":{"description":"Tekst atrybutu title odno\u015bnika dla elementu menu.","type":"string","required":false},"classes":{"description":"Nazwy klas odno\u015bnika dla elementu menu.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"Opis elementu menu.","type":"string","required":false},"menu_order":{"description":"Identyfikator w bazie danych dla elementu nav_menu_item, kt\u00f3ry jest elementem nadrz\u0119dnym menu tego elementu, je\u015bli istnieje, w przeciwnym razie 0.","type":"integer","minimum":1,"required":false},"object":{"description":"Typ pierwotnie reprezentowanego obiektu, na przyk\u0142ad \u201ekategoria\u201d, \u201ewpis\u201d lub \u201eza\u0142\u0105cznik\u201d.","type":"string","required":false},"object_id":{"description":"Identyfikator w bazie danych oryginalnego obiektu, kt\u00f3ry reprezentuje wybran\u0105 pozycj\u0119 menu, np.  identyfikator wpisu i term_id dla kategorii.","type":"integer","minimum":0,"required":false},"target":{"description":"Atrybut target odno\u015bnika dla elementu menu.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"Adres URL do kt\u00f3rego prowadzi element menu.","type":"string","format":"uri","required":false},"xfn":{"description":"Relacja XFN odno\u015bnika w elemencie menu.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Poj\u0119cia przypisane do obiektu w taksonomii o nazwie: nav_menu","type":"integer","required":false},"meta":{"description":"Pola meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""}},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator wpisu.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Okre\u015bla, czy pomin\u0105\u0107 kosz i wymusi\u0107 usuni\u0119cie.","required":false}}}]},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator elementu nadrz\u0119dnego autozapisu.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Identyfikator elementu nadrz\u0119dnego dla obiektu.","type":"integer","minimum":0,"required":false},"title":{"description":"Tytu\u0142 obiektu.","type":["string","object"],"properties":{"raw":{"description":"Tytu\u0142 obiektu, istniej\u0105cy w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Tytu\u0142 HTML obiektu, przekszta\u0142cony do wy\u015bwietlania.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"Rodzina pierwotnie reprezentowanych obiekt\u00f3w, na przyk\u0142ad \u201epost_type\u201d lub \u201etaxonomy\u201d.","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"Nazwa statusu obiektu.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"attr_title":{"description":"Tekst atrybutu title odno\u015bnika dla elementu menu.","type":"string","required":false},"classes":{"description":"Nazwy klas odno\u015bnika dla elementu menu.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"Opis elementu menu.","type":"string","required":false},"menu_order":{"description":"Identyfikator w bazie danych dla elementu nav_menu_item, kt\u00f3ry jest elementem nadrz\u0119dnym menu tego elementu, je\u015bli istnieje, w przeciwnym razie 0.","type":"integer","minimum":1,"required":false},"object":{"description":"Typ pierwotnie reprezentowanego obiektu, na przyk\u0142ad \u201ekategoria\u201d, \u201ewpis\u201d lub \u201eza\u0142\u0105cznik\u201d.","type":"string","required":false},"object_id":{"description":"Identyfikator w bazie danych oryginalnego obiektu, kt\u00f3ry reprezentuje wybran\u0105 pozycj\u0119 menu, np.  identyfikator wpisu i term_id dla kategorii.","type":"integer","minimum":0,"required":false},"target":{"description":"Atrybut target odno\u015bnika dla elementu menu.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"Adres URL do kt\u00f3rego prowadzi element menu.","type":"string","format":"uri","required":false},"xfn":{"description":"Relacja XFN odno\u015bnika w elemencie menu.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Poj\u0119cia przypisane do obiektu w taksonomii o nazwie: nav_menu","type":"integer","required":false},"meta":{"description":"Pola meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""}},"required":false}}}]},"\/wp\/v2\/menu-items\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator elementu nadrz\u0119dnego autozapisu.","type":"integer","required":false},"id":{"description":"Identyfikator automatycznego zapisu.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/blocks":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ogranicz wyniki do pasuj\u0105cych do zapytania.","type":"string","required":false},"after":{"description":"Ogranicz wyniki do wpis\u00f3w opublikowanych po podanej dacie w formacie ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Ogranicz wyniki do zmienionych wpis\u00f3w po podanej dacie w formacie ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Ogranicz wyniki do wpis\u00f3w opublikowanych przed podan\u0105 dat\u0105 w formacie ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Ogranicz wyniki do zmienionych wpis\u00f3w przed podan\u0105 dat\u0105 w formacie ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Upewnij si\u0119, \u017ce zestaw wynik\u00f3w wyklucza okre\u015blone identyfikatory.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ogranicz zbi\u00f3r wynik\u00f3w do wybranych ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Jak interpretowa\u0107 dane wyszukiwania.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Przesu\u0144 wyniki o okre\u015blon\u0105 liczb\u0119 pozycji.","type":"integer","required":false},"order":{"description":"Sortowanie atrybut\u00f3w rosn\u0105co lub malej\u0105co.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortuj kolekcj\u0119 wed\u0142ug atrybutu wpisu.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Tablica nazw kolumn do przeszukania.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ogranicz do wpis\u00f3w posiadaj\u0105cych podan\u0105 uproszczon\u0105 nazw\u0119.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Wy\u0142\u0105cz z wynik\u00f3w wpisy, kt\u00f3re posiadaj\u0105 jeden lub wi\u0119cej status\u00f3w.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limit wyniku ustalony na podstawie relacji pomi\u0119dzy wieloma taksonomiami.\t","type":"string","enum":["AND","OR"],"required":false},"wp_pattern_category":{"description":"Ograniczaj zestaw wynik\u00f3w do pozycji z okre\u015blonymi terminami z taksonomii wp_pattern_category.","type":["object","array"],"oneOf":[{"title":"Lista identyfikatora terminu","description":"Dopasuj terminy do wypisanych identyfikator\u00f3w.","type":"array","items":{"type":"integer"}},{"title":"Identyfikator terminy w zapytaniu Taxonomy Query","description":"Wykonaj zaawansowane zapytanie z terminem.","type":"object","properties":{"terms":{"description":"Identyfikatory termin\u00f3w.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Czy elementy musz\u0105 by\u0107 przypisane do wszystkich czy do wybranych termin\u00f3w?","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"wp_pattern_category_exclude":{"description":"Ogranicz do element\u00f3w posiadaj\u0105cych podany termin w taksonomii: wp_pattern_category.","type":["object","array"],"oneOf":[{"title":"Lista identyfikatora terminu","description":"Dopasuj terminy do wypisanych identyfikator\u00f3w.","type":"array","items":{"type":"integer"}},{"title":"Identyfikator terminy w zapytaniu Taxonomy Query","description":"Wykonaj zaawansowane zapytanie z terminem.","type":"object","properties":{"terms":{"description":"Identyfikatory termin\u00f3w.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Data publikacji wpisu w strefie czasowej witryny.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data wpisu zosta\u0142a opublikowana jako GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeryczny identyfikator dla wpisu unikatowy dla jego typu.","type":"string","required":false},"status":{"description":"Nazwa statusu wpisu.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Has\u0142o ochrony dost\u0119pu do tre\u015bci i zajawki.","type":"string","required":false},"title":{"description":"Tytu\u0142 wpisu.","type":"object","properties":{"raw":{"description":"Tytu\u0142 wpisu, istniej\u0105cy w bazie danych.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"Tre\u015b\u0107 wpisu.","type":"object","properties":{"raw":{"description":"Tre\u015b\u0107 wpisu, tak jak zosta\u0142a zapisana w bazie danych.","type":"string","context":["view","edit"]},"block_version":{"description":"Wersja bloku tre\u015bci u\u017cywanego we wpisie.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Czy tre\u015b\u0107 jest chronia has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"Zajawka wpisu.","type":"object","properties":{"raw":{"description":"Zajawka wpisu, tak jak wyst\u0119puje w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Wycinek HTML dla wpisu, przekszta\u0142cony do wy\u015bwietlenia.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Czy zajawka zabezpieczona jest has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Pola meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Plik motywu u\u017cywany do wy\u015bwietlania wpisu.","type":"string","required":false},"wp_pattern_category":{"description":"Terminy przypisane do wpisu w taksonomii: wp_pattern_category","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/wp\/v2\/blocks"}]}},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator wpisu.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Nadpisz domy\u015bln\u0105 d\u0142ugo\u015b\u0107 zajawki.","type":"integer","required":false},"password":{"description":"Has\u0142o dla wpisu, je\u015bli jest on chroniony has\u0142em.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator wpisu.","type":"integer","required":false},"date":{"description":"Data publikacji wpisu w strefie czasowej witryny.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data wpisu zosta\u0142a opublikowana jako GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeryczny identyfikator dla wpisu unikatowy dla jego typu.","type":"string","required":false},"status":{"description":"Nazwa statusu wpisu.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Has\u0142o ochrony dost\u0119pu do tre\u015bci i zajawki.","type":"string","required":false},"title":{"description":"Tytu\u0142 wpisu.","type":"object","properties":{"raw":{"description":"Tytu\u0142 wpisu, istniej\u0105cy w bazie danych.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"Tre\u015b\u0107 wpisu.","type":"object","properties":{"raw":{"description":"Tre\u015b\u0107 wpisu, tak jak zosta\u0142a zapisana w bazie danych.","type":"string","context":["view","edit"]},"block_version":{"description":"Wersja bloku tre\u015bci u\u017cywanego we wpisie.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Czy tre\u015b\u0107 jest chronia has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"Zajawka wpisu.","type":"object","properties":{"raw":{"description":"Zajawka wpisu, tak jak wyst\u0119puje w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Wycinek HTML dla wpisu, przekszta\u0142cony do wy\u015bwietlenia.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Czy zajawka zabezpieczona jest has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Pola meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Plik motywu u\u017cywany do wy\u015bwietlania wpisu.","type":"string","required":false},"wp_pattern_category":{"description":"Terminy przypisane do wpisu w taksonomii: wp_pattern_category","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator wpisu.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Okre\u015bla, czy pomin\u0105\u0107 kosz i wymusi\u0107 usuni\u0119cie.","required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator wpisu nadrz\u0119dnego wersji.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ogranicz wyniki do pasuj\u0105cych do zapytania.","type":"string","required":false},"exclude":{"description":"Upewnij si\u0119, \u017ce zestaw wynik\u00f3w wyklucza okre\u015blone identyfikatory.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ogranicz zbi\u00f3r wynik\u00f3w do wybranych ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Przesu\u0144 wyniki o okre\u015blon\u0105 liczb\u0119 pozycji.","type":"integer","required":false},"order":{"description":"Sortowanie atrybut\u00f3w rosn\u0105co lub malej\u0105co.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortuj zbi\u00f3r po atrybutach obiektu.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator wpisu nadrz\u0119dnego wersji.","type":"integer","required":false},"id":{"description":"Unikatowy identyfikator wersji.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Identyfikator wpisu nadrz\u0119dnego wersji.","type":"integer","required":false},"id":{"description":"Unikatowy identyfikator wersji.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Musi by\u0107 w\u0142\u0105czone, poniewa\u017c w wersjach nie u\u017cywamy kosza.","required":false}}}]},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator elementu nadrz\u0119dnego autozapisu.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Identyfikator elementu nadrz\u0119dnego autozapisu.","type":"integer","required":false},"date":{"description":"Data publikacji wpisu w strefie czasowej witryny.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data wpisu zosta\u0142a opublikowana jako GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeryczny identyfikator dla wpisu unikatowy dla jego typu.","type":"string","required":false},"status":{"description":"Nazwa statusu wpisu.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Has\u0142o ochrony dost\u0119pu do tre\u015bci i zajawki.","type":"string","required":false},"title":{"description":"Tytu\u0142 wpisu.","type":"object","properties":{"raw":{"description":"Tytu\u0142 wpisu, istniej\u0105cy w bazie danych.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"Tre\u015b\u0107 wpisu.","type":"object","properties":{"raw":{"description":"Tre\u015b\u0107 wpisu, tak jak zosta\u0142a zapisana w bazie danych.","type":"string","context":["view","edit"]},"block_version":{"description":"Wersja bloku tre\u015bci u\u017cywanego we wpisie.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Czy tre\u015b\u0107 jest chronia has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"Zajawka wpisu.","type":"object","properties":{"raw":{"description":"Zajawka wpisu, tak jak wyst\u0119puje w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Wycinek HTML dla wpisu, przekszta\u0142cony do wy\u015bwietlenia.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Czy zajawka zabezpieczona jest has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Pola meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Plik motywu u\u017cywany do wy\u015bwietlania wpisu.","type":"string","required":false},"wp_pattern_category":{"description":"Terminy przypisane do wpisu w taksonomii: wp_pattern_category","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator elementu nadrz\u0119dnego autozapisu.","type":"integer","required":false},"id":{"description":"Identyfikator automatycznego zapisu.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator szablonu","type":"string","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ogranicz wyniki do pasuj\u0105cych do zapytania.","type":"string","required":false},"exclude":{"description":"Upewnij si\u0119, \u017ce zestaw wynik\u00f3w wyklucza okre\u015blone identyfikatory.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ogranicz zbi\u00f3r wynik\u00f3w do wybranych ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Przesu\u0144 wyniki o okre\u015blon\u0105 liczb\u0119 pozycji.","type":"integer","required":false},"order":{"description":"Sortowanie atrybut\u00f3w rosn\u0105co lub malej\u0105co.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortuj zbi\u00f3r po atrybutach obiektu.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator szablonu","type":"string","required":false},"id":{"description":"Unikatowy identyfikator wersji.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Identyfikator szablonu","type":"string","required":false},"id":{"description":"Unikatowy identyfikator wersji.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Musi by\u0107 w\u0142\u0105czone, poniewa\u017c w wersjach nie u\u017cywamy kosza.","required":false}}}]},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identyfikator szablonu","type":"string","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"id":{"description":"Identyfikator szablonu","type":"string","required":false},"slug":{"description":"Unikatowa uproszczona nazwa identyfikuj\u0105ca szablon.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identyfikator szablonu w motywie.","type":"string","required":false},"type":{"description":"Typ szablonu.","type":"string","required":false},"content":{"description":"Zawarto\u015b\u0107 szablonu.","type":["object","string"],"properties":{"raw":{"description":"Tre\u015b\u0107 szablonu, tak jak zosta\u0142a zapisana w bazie danych.","type":"string","context":["view","edit"]},"block_version":{"description":"Wersja bloku tre\u015bci u\u017cywanego w szablonie.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Tytu\u0142 szablonu.","type":["object","string"],"properties":{"raw":{"description":"Tytu\u0142 wpisu, istniej\u0105cy w bazie danych.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Tytu\u0142 HTML wpisu, przekszta\u0142cony do wy\u015bwietlania.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Opis szablonu.","type":"string","required":false},"status":{"description":"Status szablonu.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"Identyfikator autora szablonu.","type":"integer","required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator szablonu","type":"string","required":false},"id":{"description":"Identyfikator automatycznego zapisu.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/templates":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"Zaw\u0119\u017a u\u017cycie tylko dla wybranego identyfikatora wpisu.","type":"integer","required":false},"area":{"description":"Ogranicz do okre\u015blonego obszaru fragmenu szablonu.","type":"string","required":false},"post_type":{"description":"Typ wpisu, dla kt\u00f3rego chcesz pobra\u0107 szablony.","type":"string","required":false}}},{"methods":["POST"],"args":{"slug":{"description":"Unikatowa uproszczona nazwa identyfikuj\u0105ca szablon.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"Identyfikator szablonu w motywie.","type":"string","required":false},"type":{"description":"Typ szablonu.","type":"string","required":false},"content":{"default":"","description":"Zawarto\u015b\u0107 szablonu.","type":["object","string"],"properties":{"raw":{"description":"Tre\u015b\u0107 szablonu, tak jak zosta\u0142a zapisana w bazie danych.","type":"string","context":["view","edit"]},"block_version":{"description":"Wersja bloku tre\u015bci u\u017cywanego w szablonie.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"Tytu\u0142 szablonu.","type":["object","string"],"properties":{"raw":{"description":"Tytu\u0142 wpisu, istniej\u0105cy w bazie danych.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Tytu\u0142 HTML wpisu, przekszta\u0142cony do wy\u015bwietlania.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"Opis szablonu.","type":"string","required":false},"status":{"default":"publish","description":"Status szablonu.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"Identyfikator autora szablonu.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/wp\/v2\/templates"}]}},"\/wp\/v2\/templates\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Uproszczona nazwa szablonu, dla kt\u00f3rego mo\u017cna uzyska\u0107 awaryjne rozwi\u0105zanie","type":"string","required":true},"is_custom":{"description":"Wskazuje, czy szablon jest w\u0142asny, czy stanowi cz\u0119\u015b\u0107 hierarchii szablon\u00f3w","type":"boolean","required":false},"template_prefix":{"description":"Prefiks szablonu dla tworzonego szablonu. S\u0142u\u017cy do wyodr\u0119bnienia g\u0142\u00f3wnego typu szablonu np. w `taksonomia-ksi\u0105\u017cki` wyodr\u0119bniamy `taksonomia`","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/wp\/v2\/templates\/lookup"}]}},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identyfikator szablonu","type":"string","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identyfikator szablonu","type":"string","required":false},"slug":{"description":"Unikatowa uproszczona nazwa identyfikuj\u0105ca szablon.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identyfikator szablonu w motywie.","type":"string","required":false},"type":{"description":"Typ szablonu.","type":"string","required":false},"content":{"description":"Zawarto\u015b\u0107 szablonu.","type":["object","string"],"properties":{"raw":{"description":"Tre\u015b\u0107 szablonu, tak jak zosta\u0142a zapisana w bazie danych.","type":"string","context":["view","edit"]},"block_version":{"description":"Wersja bloku tre\u015bci u\u017cywanego w szablonie.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Tytu\u0142 szablonu.","type":["object","string"],"properties":{"raw":{"description":"Tytu\u0142 wpisu, istniej\u0105cy w bazie danych.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Tytu\u0142 HTML wpisu, przekszta\u0142cony do wy\u015bwietlania.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Opis szablonu.","type":"string","required":false},"status":{"description":"Status szablonu.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"Identyfikator autora szablonu.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identyfikator szablonu","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"Okre\u015bla, czy pomin\u0105\u0107 kosz i wymusi\u0107 usuni\u0119cie.","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator szablonu","type":"string","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ogranicz wyniki do pasuj\u0105cych do zapytania.","type":"string","required":false},"exclude":{"description":"Upewnij si\u0119, \u017ce zestaw wynik\u00f3w wyklucza okre\u015blone identyfikatory.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ogranicz zbi\u00f3r wynik\u00f3w do wybranych ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Przesu\u0144 wyniki o okre\u015blon\u0105 liczb\u0119 pozycji.","type":"integer","required":false},"order":{"description":"Sortowanie atrybut\u00f3w rosn\u0105co lub malej\u0105co.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortuj zbi\u00f3r po atrybutach obiektu.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator szablonu","type":"string","required":false},"id":{"description":"Unikatowy identyfikator wersji.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Identyfikator szablonu","type":"string","required":false},"id":{"description":"Unikatowy identyfikator wersji.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Musi by\u0107 w\u0142\u0105czone, poniewa\u017c w wersjach nie u\u017cywamy kosza.","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identyfikator szablonu","type":"string","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"id":{"description":"Identyfikator szablonu","type":"string","required":false},"slug":{"description":"Unikatowa uproszczona nazwa identyfikuj\u0105ca szablon.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identyfikator szablonu w motywie.","type":"string","required":false},"type":{"description":"Typ szablonu.","type":"string","required":false},"content":{"description":"Zawarto\u015b\u0107 szablonu.","type":["object","string"],"properties":{"raw":{"description":"Tre\u015b\u0107 szablonu, tak jak zosta\u0142a zapisana w bazie danych.","type":"string","context":["view","edit"]},"block_version":{"description":"Wersja bloku tre\u015bci u\u017cywanego w szablonie.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Tytu\u0142 szablonu.","type":["object","string"],"properties":{"raw":{"description":"Tytu\u0142 wpisu, istniej\u0105cy w bazie danych.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Tytu\u0142 HTML wpisu, przekszta\u0142cony do wy\u015bwietlania.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Opis szablonu.","type":"string","required":false},"status":{"description":"Status szablonu.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"Identyfikator autora szablonu.","type":"integer","required":false},"area":{"description":"Gdzie fragment szablonu b\u0119dzie przeznaczony do u\u017cytku (nag\u0142\u00f3wek, stopka, itd.)","type":"string","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator szablonu","type":"string","required":false},"id":{"description":"Identyfikator automatycznego zapisu.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/template-parts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"Zaw\u0119\u017a u\u017cycie tylko dla wybranego identyfikatora wpisu.","type":"integer","required":false},"area":{"description":"Ogranicz do okre\u015blonego obszaru fragmenu szablonu.","type":"string","required":false},"post_type":{"description":"Typ wpisu, dla kt\u00f3rego chcesz pobra\u0107 szablony.","type":"string","required":false}}},{"methods":["POST"],"args":{"slug":{"description":"Unikatowa uproszczona nazwa identyfikuj\u0105ca szablon.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"Identyfikator szablonu w motywie.","type":"string","required":false},"type":{"description":"Typ szablonu.","type":"string","required":false},"content":{"default":"","description":"Zawarto\u015b\u0107 szablonu.","type":["object","string"],"properties":{"raw":{"description":"Tre\u015b\u0107 szablonu, tak jak zosta\u0142a zapisana w bazie danych.","type":"string","context":["view","edit"]},"block_version":{"description":"Wersja bloku tre\u015bci u\u017cywanego w szablonie.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"Tytu\u0142 szablonu.","type":["object","string"],"properties":{"raw":{"description":"Tytu\u0142 wpisu, istniej\u0105cy w bazie danych.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Tytu\u0142 HTML wpisu, przekszta\u0142cony do wy\u015bwietlania.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"Opis szablonu.","type":"string","required":false},"status":{"default":"publish","description":"Status szablonu.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"Identyfikator autora szablonu.","type":"integer","required":false},"area":{"description":"Gdzie fragment szablonu b\u0119dzie przeznaczony do u\u017cytku (nag\u0142\u00f3wek, stopka, itd.)","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/wp\/v2\/template-parts"}]}},"\/wp\/v2\/template-parts\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Uproszczona nazwa szablonu, dla kt\u00f3rego mo\u017cna uzyska\u0107 awaryjne rozwi\u0105zanie","type":"string","required":true},"is_custom":{"description":"Wskazuje, czy szablon jest w\u0142asny, czy stanowi cz\u0119\u015b\u0107 hierarchii szablon\u00f3w","type":"boolean","required":false},"template_prefix":{"description":"Prefiks szablonu dla tworzonego szablonu. S\u0142u\u017cy do wyodr\u0119bnienia g\u0142\u00f3wnego typu szablonu np. w `taksonomia-ksi\u0105\u017cki` wyodr\u0119bniamy `taksonomia`","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/wp\/v2\/template-parts\/lookup"}]}},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identyfikator szablonu","type":"string","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identyfikator szablonu","type":"string","required":false},"slug":{"description":"Unikatowa uproszczona nazwa identyfikuj\u0105ca szablon.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identyfikator szablonu w motywie.","type":"string","required":false},"type":{"description":"Typ szablonu.","type":"string","required":false},"content":{"description":"Zawarto\u015b\u0107 szablonu.","type":["object","string"],"properties":{"raw":{"description":"Tre\u015b\u0107 szablonu, tak jak zosta\u0142a zapisana w bazie danych.","type":"string","context":["view","edit"]},"block_version":{"description":"Wersja bloku tre\u015bci u\u017cywanego w szablonie.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Tytu\u0142 szablonu.","type":["object","string"],"properties":{"raw":{"description":"Tytu\u0142 wpisu, istniej\u0105cy w bazie danych.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Tytu\u0142 HTML wpisu, przekszta\u0142cony do wy\u015bwietlania.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Opis szablonu.","type":"string","required":false},"status":{"description":"Status szablonu.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"Identyfikator autora szablonu.","type":"integer","required":false},"area":{"description":"Gdzie fragment szablonu b\u0119dzie przeznaczony do u\u017cytku (nag\u0142\u00f3wek, stopka, itd.)","type":"string","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identyfikator szablonu","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"Okre\u015bla, czy pomin\u0105\u0107 kosz i wymusi\u0107 usuni\u0119cie.","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator wpisu nadrz\u0119dnego wersji.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","minimum":1,"maximum":100,"required":false},"offset":{"description":"Przesu\u0144 wyniki o okre\u015blon\u0105 liczb\u0119 pozycji.","type":"integer","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator elementu nadrz\u0119dnego globalnej wersji styl\u00f3w.","type":"integer","required":false},"id":{"description":"Unikatowy identyfikator globalnej wersji styl\u00f3w.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[\\\/\\s%\\w\\.\\(\\)\\[\\]\\@_\\-]+)\/variations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"Identyfikator motywu","type":"string","required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"Identyfikator motywu","type":"string","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<id>[\\\/\\w-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"id":{"description":"Identyfikator szablonu","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":false},"args":{"styles":{"description":"Style globalne","type":["object"],"required":false},"settings":{"description":"Ustawienia globalne","type":["object"],"required":false},"title":{"description":"Tytu\u0142 globalnej wariacji styl\u00f3w.","type":["object","string"],"properties":{"raw":{"description":"Tytu\u0142 globalnej odmiany styl\u00f3w, jaka istnieje w bazie danych.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Tytu\u0142 HTML wpisu, przekszta\u0142cony do wy\u015bwietlania.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false}}}]},"\/wp\/v2\/navigation":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ogranicz wyniki do pasuj\u0105cych do zapytania.","type":"string","required":false},"after":{"description":"Ogranicz wyniki do wpis\u00f3w opublikowanych po podanej dacie w formacie ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Ogranicz wyniki do zmienionych wpis\u00f3w po podanej dacie w formacie ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Ogranicz wyniki do wpis\u00f3w opublikowanych przed podan\u0105 dat\u0105 w formacie ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Ogranicz wyniki do zmienionych wpis\u00f3w przed podan\u0105 dat\u0105 w formacie ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Upewnij si\u0119, \u017ce zestaw wynik\u00f3w wyklucza okre\u015blone identyfikatory.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ogranicz zbi\u00f3r wynik\u00f3w do wybranych ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Jak interpretowa\u0107 dane wyszukiwania.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Przesu\u0144 wyniki o okre\u015blon\u0105 liczb\u0119 pozycji.","type":"integer","required":false},"order":{"description":"Sortowanie atrybut\u00f3w rosn\u0105co lub malej\u0105co.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortuj kolekcj\u0119 wed\u0142ug atrybutu wpisu.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Tablica nazw kolumn do przeszukania.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ogranicz do wpis\u00f3w posiadaj\u0105cych podan\u0105 uproszczon\u0105 nazw\u0119.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Wy\u0142\u0105cz z wynik\u00f3w wpisy, kt\u00f3re posiadaj\u0105 jeden lub wi\u0119cej status\u00f3w.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Data publikacji wpisu w strefie czasowej witryny.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data wpisu zosta\u0142a opublikowana jako GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeryczny identyfikator dla wpisu unikatowy dla jego typu.","type":"string","required":false},"status":{"description":"Nazwa statusu wpisu.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Has\u0142o ochrony dost\u0119pu do tre\u015bci i zajawki.","type":"string","required":false},"title":{"description":"Tytu\u0142 wpisu.","type":"object","properties":{"raw":{"description":"Tytu\u0142 wpisu, istniej\u0105cy w bazie danych.","type":"string","context":["edit","embed"]},"rendered":{"description":"Tytu\u0142 HTML wpisu, przekszta\u0142cony do wy\u015bwietlania.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Tre\u015b\u0107 wpisu.","type":"object","properties":{"raw":{"description":"Tre\u015b\u0107 wpisu, tak jak zosta\u0142a zapisana w bazie danych.","type":"string","context":["edit","embed"]},"rendered":{"description":"Zawarto\u015b\u0107 HMTL wpisu, przetworzona do wy\u015bwietlenia.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Wersja bloku tre\u015bci u\u017cywanego we wpisie.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Czy tre\u015b\u0107 jest chronia has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Pola meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Plik motywu u\u017cywany do wy\u015bwietlania wpisu.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/wp\/v2\/navigation"}]}},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator wpisu.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Has\u0142o dla wpisu, je\u015bli jest on chroniony has\u0142em.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator wpisu.","type":"integer","required":false},"date":{"description":"Data publikacji wpisu w strefie czasowej witryny.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data wpisu zosta\u0142a opublikowana jako GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeryczny identyfikator dla wpisu unikatowy dla jego typu.","type":"string","required":false},"status":{"description":"Nazwa statusu wpisu.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Has\u0142o ochrony dost\u0119pu do tre\u015bci i zajawki.","type":"string","required":false},"title":{"description":"Tytu\u0142 wpisu.","type":"object","properties":{"raw":{"description":"Tytu\u0142 wpisu, istniej\u0105cy w bazie danych.","type":"string","context":["edit","embed"]},"rendered":{"description":"Tytu\u0142 HTML wpisu, przekszta\u0142cony do wy\u015bwietlania.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Tre\u015b\u0107 wpisu.","type":"object","properties":{"raw":{"description":"Tre\u015b\u0107 wpisu, tak jak zosta\u0142a zapisana w bazie danych.","type":"string","context":["edit","embed"]},"rendered":{"description":"Zawarto\u015b\u0107 HMTL wpisu, przetworzona do wy\u015bwietlenia.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Wersja bloku tre\u015bci u\u017cywanego we wpisie.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Czy tre\u015b\u0107 jest chronia has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Pola meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Plik motywu u\u017cywany do wy\u015bwietlania wpisu.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator wpisu.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Okre\u015bla, czy pomin\u0105\u0107 kosz i wymusi\u0107 usuni\u0119cie.","required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator wpisu nadrz\u0119dnego wersji.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ogranicz wyniki do pasuj\u0105cych do zapytania.","type":"string","required":false},"exclude":{"description":"Upewnij si\u0119, \u017ce zestaw wynik\u00f3w wyklucza okre\u015blone identyfikatory.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ogranicz zbi\u00f3r wynik\u00f3w do wybranych ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Przesu\u0144 wyniki o okre\u015blon\u0105 liczb\u0119 pozycji.","type":"integer","required":false},"order":{"description":"Sortowanie atrybut\u00f3w rosn\u0105co lub malej\u0105co.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortuj zbi\u00f3r po atrybutach obiektu.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator wpisu nadrz\u0119dnego wersji.","type":"integer","required":false},"id":{"description":"Unikatowy identyfikator wersji.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Identyfikator wpisu nadrz\u0119dnego wersji.","type":"integer","required":false},"id":{"description":"Unikatowy identyfikator wersji.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Musi by\u0107 w\u0142\u0105czone, poniewa\u017c w wersjach nie u\u017cywamy kosza.","required":false}}}]},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator elementu nadrz\u0119dnego autozapisu.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Identyfikator elementu nadrz\u0119dnego autozapisu.","type":"integer","required":false},"date":{"description":"Data publikacji wpisu w strefie czasowej witryny.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data wpisu zosta\u0142a opublikowana jako GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeryczny identyfikator dla wpisu unikatowy dla jego typu.","type":"string","required":false},"status":{"description":"Nazwa statusu wpisu.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Has\u0142o ochrony dost\u0119pu do tre\u015bci i zajawki.","type":"string","required":false},"title":{"description":"Tytu\u0142 wpisu.","type":"object","properties":{"raw":{"description":"Tytu\u0142 wpisu, istniej\u0105cy w bazie danych.","type":"string","context":["edit","embed"]},"rendered":{"description":"Tytu\u0142 HTML wpisu, przekszta\u0142cony do wy\u015bwietlania.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Tre\u015b\u0107 wpisu.","type":"object","properties":{"raw":{"description":"Tre\u015b\u0107 wpisu, tak jak zosta\u0142a zapisana w bazie danych.","type":"string","context":["edit","embed"]},"rendered":{"description":"Zawarto\u015b\u0107 HMTL wpisu, przetworzona do wy\u015bwietlenia.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Wersja bloku tre\u015bci u\u017cywanego we wpisie.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Czy tre\u015b\u0107 jest chronia has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Pola meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Plik motywu u\u017cywany do wy\u015bwietlania wpisu.","type":"string","required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator elementu nadrz\u0119dnego autozapisu.","type":"integer","required":false},"id":{"description":"Identyfikator automatycznego zapisu.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/font-families":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"Upewnij si\u0119, \u017ce zestaw wynik\u00f3w wyklucza okre\u015blone identyfikatory.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ogranicz zbi\u00f3r wynik\u00f3w do wybranych ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Jak interpretowa\u0107 dane wyszukiwania.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Przesu\u0144 wyniki o okre\u015blon\u0105 liczb\u0119 pozycji.","type":"integer","required":false},"order":{"description":"Sortowanie atrybut\u00f3w rosn\u0105co lub malej\u0105co.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortuj kolekcj\u0119 wed\u0142ug atrybutu wpisu.","type":"string","default":"id","enum":["id","include"],"required":false},"slug":{"description":"Ogranicz do wpis\u00f3w posiadaj\u0105cych podan\u0105 uproszczon\u0105 nazw\u0119.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"theme_json_version":{"description":"Wersja schematu theme.json u\u017cywanego do ustawie\u0144 typografii.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"deklaracja font-family w formacie theme.json, zakodowana jako ci\u0105g znak\u00f3w.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/wp\/v2\/font-families"}]}},"\/wp\/v2\/font-families\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unikatowy identyfikator wpisu.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unikatowy identyfikator wpisu.","type":"integer","required":false},"theme_json_version":{"description":"Wersja schematu theme.json u\u017cywanego do ustawie\u0144 typografii.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"deklaracja font-family w formacie theme.json, zakodowana jako ci\u0105g znak\u00f3w.","type":"string","required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Unikatowy identyfikator wpisu.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Okre\u015bla, czy pomin\u0105\u0107 kosz i wymusi\u0107 usuni\u0119cie.","required":false}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"Identyfikator nadrz\u0119dnej rodziny kroju pisma dla odmiany.","type":"integer","required":true},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"Upewnij si\u0119, \u017ce zestaw wynik\u00f3w wyklucza okre\u015blone identyfikatory.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ogranicz zbi\u00f3r wynik\u00f3w do wybranych ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Jak interpretowa\u0107 dane wyszukiwania.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Przesu\u0144 wyniki o okre\u015blon\u0105 liczb\u0119 pozycji.","type":"integer","required":false},"order":{"description":"Sortowanie atrybut\u00f3w rosn\u0105co lub malej\u0105co.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortuj kolekcj\u0119 wed\u0142ug atrybutu wpisu.","type":"string","default":"id","enum":["id","include"],"required":false}}},{"methods":["POST"],"args":{"font_family_id":{"description":"Identyfikator nadrz\u0119dnej rodziny kroju pisma dla odmiany.","type":"integer","required":true},"theme_json_version":{"description":"Wersja schematu theme.json u\u017cywanego do ustawie\u0144 typografii.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_face_settings":{"description":"deklaracja font-face w formacie theme.json, zakodowana jako ci\u0105g znak\u00f3w.","type":"string","required":true}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"Identyfikator nadrz\u0119dnej rodziny kroju pisma dla odmiany.","type":"integer","required":true},"id":{"description":"Unikatowy identyfikator odmiany kroju pisma.","type":"integer","required":true},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"font_family_id":{"description":"Identyfikator nadrz\u0119dnej rodziny kroju pisma dla odmiany.","type":"integer","required":true},"id":{"description":"Unikatowy identyfikator odmiany kroju pisma.","type":"integer","required":true},"force":{"type":"boolean","default":false,"description":"Okre\u015bla, czy pomin\u0105\u0107 kosz i wymusi\u0107 usuni\u0119cie.","required":false}}}]},"\/wp\/v2\/banner":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ogranicz wyniki do pasuj\u0105cych do zapytania.","type":"string","required":false},"after":{"description":"Ogranicz wyniki do wpis\u00f3w opublikowanych po podanej dacie w formacie ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Ogranicz wyniki do zmienionych wpis\u00f3w po podanej dacie w formacie ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Ogranicz do wpis\u00f3w wybranych autor\u00f3w.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Prosz\u0119 si\u0119 upewni\u0107, \u017ce zestaw wynik\u00f3w wyklucza wpisy przypisane do poszczeg\u00f3lnych autor\u00f3w.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Ogranicz wyniki do wpis\u00f3w opublikowanych przed podan\u0105 dat\u0105 w formacie ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Ogranicz wyniki do zmienionych wpis\u00f3w przed podan\u0105 dat\u0105 w formacie ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Upewnij si\u0119, \u017ce zestaw wynik\u00f3w wyklucza okre\u015blone identyfikatory.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ogranicz zbi\u00f3r wynik\u00f3w do wybranych ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Jak interpretowa\u0107 dane wyszukiwania.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Przesu\u0144 wyniki o okre\u015blon\u0105 liczb\u0119 pozycji.","type":"integer","required":false},"order":{"description":"Sortowanie atrybut\u00f3w rosn\u0105co lub malej\u0105co.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortuj kolekcj\u0119 wed\u0142ug atrybutu wpisu.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Tablica nazw kolumn do przeszukania.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ogranicz do wpis\u00f3w posiadaj\u0105cych podan\u0105 uproszczon\u0105 nazw\u0119.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Wy\u0142\u0105cz z wynik\u00f3w wpisy, kt\u00f3re posiadaj\u0105 jeden lub wi\u0119cej status\u00f3w.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limit wyniku ustalony na podstawie relacji pomi\u0119dzy wieloma taksonomiami.\t","type":"string","enum":["AND","OR"],"required":false},"banner_groups":{"description":"Ograniczaj zestaw wynik\u00f3w do pozycji z okre\u015blonymi terminami z taksonomii banner_groups.","type":["object","array"],"oneOf":[{"title":"Lista identyfikatora terminu","description":"Dopasuj terminy do wypisanych identyfikator\u00f3w.","type":"array","items":{"type":"integer"}},{"title":"Identyfikator terminy w zapytaniu Taxonomy Query","description":"Wykonaj zaawansowane zapytanie z terminem.","type":"object","properties":{"terms":{"description":"Identyfikatory termin\u00f3w.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Czy uwzgl\u0119dnia\u0107 terminy podrz\u0119dne w terminach ograniczaj\u0105cych zestaw wynik\u00f3w.","type":"boolean","default":false},"operator":{"description":"Czy elementy musz\u0105 by\u0107 przypisane do wszystkich czy do wybranych termin\u00f3w?","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"banner_groups_exclude":{"description":"Ogranicz do element\u00f3w posiadaj\u0105cych podany termin w taksonomii: banner_groups.","type":["object","array"],"oneOf":[{"title":"Lista identyfikatora terminu","description":"Dopasuj terminy do wypisanych identyfikator\u00f3w.","type":"array","items":{"type":"integer"}},{"title":"Identyfikator terminy w zapytaniu Taxonomy Query","description":"Wykonaj zaawansowane zapytanie z terminem.","type":"object","properties":{"terms":{"description":"Identyfikatory termin\u00f3w.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Czy uwzgl\u0119dnia\u0107 terminy podrz\u0119dne w terminach ograniczaj\u0105cych zestaw wynik\u00f3w.","type":"boolean","default":false}},"additionalProperties":false}],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Data publikacji wpisu w strefie czasowej witryny.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data wpisu zosta\u0142a opublikowana jako GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeryczny identyfikator dla wpisu unikatowy dla jego typu.","type":"string","required":false},"status":{"description":"Nazwa statusu wpisu.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Has\u0142o ochrony dost\u0119pu do tre\u015bci i zajawki.","type":"string","required":false},"title":{"description":"Tytu\u0142 wpisu.","type":"object","properties":{"raw":{"description":"Tytu\u0142 wpisu, istniej\u0105cy w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Tytu\u0142 HTML wpisu, przekszta\u0142cony do wy\u015bwietlania.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Tre\u015b\u0107 wpisu.","type":"object","properties":{"raw":{"description":"Tre\u015b\u0107 wpisu, tak jak zosta\u0142a zapisana w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Zawarto\u015b\u0107 HMTL wpisu, przetworzona do wy\u015bwietlenia.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Wersja bloku tre\u015bci u\u017cywanego we wpisie.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Czy tre\u015b\u0107 jest chronia has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Identyfikator autora wpisu.","type":"integer","required":false},"excerpt":{"description":"Zajawka wpisu.","type":"object","properties":{"raw":{"description":"Zajawka wpisu, tak jak wyst\u0119puje w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Wycinek HTML dla wpisu, przekszta\u0142cony do wy\u015bwietlenia.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Czy zajawka zabezpieczona jest has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Identyfikator wyr\u00f3\u017cniaj\u0105cego pliku medialnego wpisu.","type":"integer","required":false},"comment_status":{"description":"To czy wpis mo\u017ce by\u0107 komentowany.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"To, czy wpis mo\u017ce by\u0107 pingowany.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Pola meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Plik motywu u\u017cywany do wy\u015bwietlania wpisu.","type":"string","required":false},"banner_groups":{"description":"Terminy przypisane do wpisu w taksonomii: banner_groups","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/wp\/v2\/banner"}]}},"\/wp\/v2\/banner\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator wpisu.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Nadpisz domy\u015bln\u0105 d\u0142ugo\u015b\u0107 zajawki.","type":"integer","required":false},"password":{"description":"Has\u0142o dla wpisu, je\u015bli jest on chroniony has\u0142em.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator wpisu.","type":"integer","required":false},"date":{"description":"Data publikacji wpisu w strefie czasowej witryny.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data wpisu zosta\u0142a opublikowana jako GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeryczny identyfikator dla wpisu unikatowy dla jego typu.","type":"string","required":false},"status":{"description":"Nazwa statusu wpisu.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Has\u0142o ochrony dost\u0119pu do tre\u015bci i zajawki.","type":"string","required":false},"title":{"description":"Tytu\u0142 wpisu.","type":"object","properties":{"raw":{"description":"Tytu\u0142 wpisu, istniej\u0105cy w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Tytu\u0142 HTML wpisu, przekszta\u0142cony do wy\u015bwietlania.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Tre\u015b\u0107 wpisu.","type":"object","properties":{"raw":{"description":"Tre\u015b\u0107 wpisu, tak jak zosta\u0142a zapisana w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Zawarto\u015b\u0107 HMTL wpisu, przetworzona do wy\u015bwietlenia.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Wersja bloku tre\u015bci u\u017cywanego we wpisie.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Czy tre\u015b\u0107 jest chronia has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Identyfikator autora wpisu.","type":"integer","required":false},"excerpt":{"description":"Zajawka wpisu.","type":"object","properties":{"raw":{"description":"Zajawka wpisu, tak jak wyst\u0119puje w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Wycinek HTML dla wpisu, przekszta\u0142cony do wy\u015bwietlenia.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Czy zajawka zabezpieczona jest has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Identyfikator wyr\u00f3\u017cniaj\u0105cego pliku medialnego wpisu.","type":"integer","required":false},"comment_status":{"description":"To czy wpis mo\u017ce by\u0107 komentowany.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"To, czy wpis mo\u017ce by\u0107 pingowany.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Pola meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Plik motywu u\u017cywany do wy\u015bwietlania wpisu.","type":"string","required":false},"banner_groups":{"description":"Terminy przypisane do wpisu w taksonomii: banner_groups","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator wpisu.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Okre\u015bla, czy pomin\u0105\u0107 kosz i wymusi\u0107 usuni\u0119cie.","required":false}}}]},"\/wp\/v2\/banner\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator elementu nadrz\u0119dnego autozapisu.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Identyfikator elementu nadrz\u0119dnego autozapisu.","type":"integer","required":false},"date":{"description":"Data publikacji wpisu w strefie czasowej witryny.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data wpisu zosta\u0142a opublikowana jako GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeryczny identyfikator dla wpisu unikatowy dla jego typu.","type":"string","required":false},"status":{"description":"Nazwa statusu wpisu.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Has\u0142o ochrony dost\u0119pu do tre\u015bci i zajawki.","type":"string","required":false},"title":{"description":"Tytu\u0142 wpisu.","type":"object","properties":{"raw":{"description":"Tytu\u0142 wpisu, istniej\u0105cy w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Tytu\u0142 HTML wpisu, przekszta\u0142cony do wy\u015bwietlania.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Tre\u015b\u0107 wpisu.","type":"object","properties":{"raw":{"description":"Tre\u015b\u0107 wpisu, tak jak zosta\u0142a zapisana w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Zawarto\u015b\u0107 HMTL wpisu, przetworzona do wy\u015bwietlenia.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Wersja bloku tre\u015bci u\u017cywanego we wpisie.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Czy tre\u015b\u0107 jest chronia has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Identyfikator autora wpisu.","type":"integer","required":false},"excerpt":{"description":"Zajawka wpisu.","type":"object","properties":{"raw":{"description":"Zajawka wpisu, tak jak wyst\u0119puje w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Wycinek HTML dla wpisu, przekszta\u0142cony do wy\u015bwietlenia.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Czy zajawka zabezpieczona jest has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Identyfikator wyr\u00f3\u017cniaj\u0105cego pliku medialnego wpisu.","type":"integer","required":false},"comment_status":{"description":"To czy wpis mo\u017ce by\u0107 komentowany.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"To, czy wpis mo\u017ce by\u0107 pingowany.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Pola meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Plik motywu u\u017cywany do wy\u015bwietlania wpisu.","type":"string","required":false},"banner_groups":{"description":"Terminy przypisane do wpisu w taksonomii: banner_groups","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/banner\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator elementu nadrz\u0119dnego autozapisu.","type":"integer","required":false},"id":{"description":"Identyfikator automatycznego zapisu.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/ld_docs":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ogranicz wyniki do pasuj\u0105cych do zapytania.","type":"string","required":false},"after":{"description":"Ogranicz wyniki do wpis\u00f3w opublikowanych po podanej dacie w formacie ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Ogranicz wyniki do zmienionych wpis\u00f3w po podanej dacie w formacie ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Ogranicz do wpis\u00f3w wybranych autor\u00f3w.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Prosz\u0119 si\u0119 upewni\u0107, \u017ce zestaw wynik\u00f3w wyklucza wpisy przypisane do poszczeg\u00f3lnych autor\u00f3w.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Ogranicz wyniki do wpis\u00f3w opublikowanych przed podan\u0105 dat\u0105 w formacie ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Ogranicz wyniki do zmienionych wpis\u00f3w przed podan\u0105 dat\u0105 w formacie ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Upewnij si\u0119, \u017ce zestaw wynik\u00f3w wyklucza okre\u015blone identyfikatory.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ogranicz zbi\u00f3r wynik\u00f3w do wybranych ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Ogranicz wyniki do wpis\u00f3w z okre\u015blon\u0105 warto\u015bci\u0105 menu_order.","type":"integer","required":false},"search_semantics":{"description":"Jak interpretowa\u0107 dane wyszukiwania.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Przesu\u0144 wyniki o okre\u015blon\u0105 liczb\u0119 pozycji.","type":"integer","required":false},"order":{"description":"Sortowanie atrybut\u00f3w rosn\u0105co lub malej\u0105co.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortuj kolekcj\u0119 wed\u0142ug atrybutu wpisu.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"parent":{"description":"Ogranicz wyniki do obiekt\u00f3w, kt\u00f3rych elementy nadrz\u0119dne maj\u0105 wybrane identyfikatory.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Ogranicz zestaw wynik\u00f3w do wszystkich element\u00f3w z wyj\u0105tkiem tych o okre\u015blonym identyfikatorze nadrz\u0119dnym.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Tablica nazw kolumn do przeszukania.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ogranicz do wpis\u00f3w posiadaj\u0105cych podan\u0105 uproszczon\u0105 nazw\u0119.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Wy\u0142\u0105cz z wynik\u00f3w wpisy, kt\u00f3re posiadaj\u0105 jeden lub wi\u0119cej status\u00f3w.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limit wyniku ustalony na podstawie relacji pomi\u0119dzy wieloma taksonomiami.\t","type":"string","enum":["AND","OR"],"required":false},"ld_collection":{"description":"Ograniczaj zestaw wynik\u00f3w do pozycji z okre\u015blonymi terminami z taksonomii ld_collection.","type":["object","array"],"oneOf":[{"title":"Lista identyfikatora terminu","description":"Dopasuj terminy do wypisanych identyfikator\u00f3w.","type":"array","items":{"type":"integer"}},{"title":"Identyfikator terminy w zapytaniu Taxonomy Query","description":"Wykonaj zaawansowane zapytanie z terminem.","type":"object","properties":{"terms":{"description":"Identyfikatory termin\u00f3w.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Czy uwzgl\u0119dnia\u0107 terminy podrz\u0119dne w terminach ograniczaj\u0105cych zestaw wynik\u00f3w.","type":"boolean","default":false},"operator":{"description":"Czy elementy musz\u0105 by\u0107 przypisane do wszystkich czy do wybranych termin\u00f3w?","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"ld_collection_exclude":{"description":"Ogranicz do element\u00f3w posiadaj\u0105cych podany termin w taksonomii: ld_collection.","type":["object","array"],"oneOf":[{"title":"Lista identyfikatora terminu","description":"Dopasuj terminy do wypisanych identyfikator\u00f3w.","type":"array","items":{"type":"integer"}},{"title":"Identyfikator terminy w zapytaniu Taxonomy Query","description":"Wykonaj zaawansowane zapytanie z terminem.","type":"object","properties":{"terms":{"description":"Identyfikatory termin\u00f3w.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Czy uwzgl\u0119dnia\u0107 terminy podrz\u0119dne w terminach ograniczaj\u0105cych zestaw wynik\u00f3w.","type":"boolean","default":false}},"additionalProperties":false}],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Data publikacji wpisu w strefie czasowej witryny.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data wpisu zosta\u0142a opublikowana jako GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeryczny identyfikator dla wpisu unikatowy dla jego typu.","type":"string","required":false},"status":{"description":"Nazwa statusu wpisu.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Has\u0142o ochrony dost\u0119pu do tre\u015bci i zajawki.","type":"string","required":false},"parent":{"description":"Identyfikator elementu nadrz\u0119dnego wpisu.","type":"integer","required":false},"title":{"description":"Tytu\u0142 wpisu.","type":"object","properties":{"raw":{"description":"Tytu\u0142 wpisu, istniej\u0105cy w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Tytu\u0142 HTML wpisu, przekszta\u0142cony do wy\u015bwietlania.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Tre\u015b\u0107 wpisu.","type":"object","properties":{"raw":{"description":"Tre\u015b\u0107 wpisu, tak jak zosta\u0142a zapisana w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Zawarto\u015b\u0107 HMTL wpisu, przetworzona do wy\u015bwietlenia.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Wersja bloku tre\u015bci u\u017cywanego we wpisie.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Czy tre\u015b\u0107 jest chronia has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Identyfikator autora wpisu.","type":"integer","required":false},"excerpt":{"description":"Zajawka wpisu.","type":"object","properties":{"raw":{"description":"Zajawka wpisu, tak jak wyst\u0119puje w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Wycinek HTML dla wpisu, przekszta\u0142cony do wy\u015bwietlenia.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Czy zajawka zabezpieczona jest has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Identyfikator wyr\u00f3\u017cniaj\u0105cego pliku medialnego wpisu.","type":"integer","required":false},"menu_order":{"description":"Kolejno\u015b\u0107 wpis\u00f3w w stosunku do innych.","type":"integer","required":false},"meta":{"description":"Pola meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Plik motywu u\u017cywany do wy\u015bwietlania wpisu.","type":"string","required":false},"ld_collection":{"description":"Terminy przypisane do wpisu w taksonomii: ld_collection","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/wp\/v2\/ld_docs"}]}},"\/wp\/v2\/ld_docs\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator wpisu.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Nadpisz domy\u015bln\u0105 d\u0142ugo\u015b\u0107 zajawki.","type":"integer","required":false},"password":{"description":"Has\u0142o dla wpisu, je\u015bli jest on chroniony has\u0142em.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator wpisu.","type":"integer","required":false},"date":{"description":"Data publikacji wpisu w strefie czasowej witryny.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data wpisu zosta\u0142a opublikowana jako GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeryczny identyfikator dla wpisu unikatowy dla jego typu.","type":"string","required":false},"status":{"description":"Nazwa statusu wpisu.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Has\u0142o ochrony dost\u0119pu do tre\u015bci i zajawki.","type":"string","required":false},"parent":{"description":"Identyfikator elementu nadrz\u0119dnego wpisu.","type":"integer","required":false},"title":{"description":"Tytu\u0142 wpisu.","type":"object","properties":{"raw":{"description":"Tytu\u0142 wpisu, istniej\u0105cy w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Tytu\u0142 HTML wpisu, przekszta\u0142cony do wy\u015bwietlania.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Tre\u015b\u0107 wpisu.","type":"object","properties":{"raw":{"description":"Tre\u015b\u0107 wpisu, tak jak zosta\u0142a zapisana w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Zawarto\u015b\u0107 HMTL wpisu, przetworzona do wy\u015bwietlenia.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Wersja bloku tre\u015bci u\u017cywanego we wpisie.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Czy tre\u015b\u0107 jest chronia has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Identyfikator autora wpisu.","type":"integer","required":false},"excerpt":{"description":"Zajawka wpisu.","type":"object","properties":{"raw":{"description":"Zajawka wpisu, tak jak wyst\u0119puje w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Wycinek HTML dla wpisu, przekszta\u0142cony do wy\u015bwietlenia.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Czy zajawka zabezpieczona jest has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Identyfikator wyr\u00f3\u017cniaj\u0105cego pliku medialnego wpisu.","type":"integer","required":false},"menu_order":{"description":"Kolejno\u015b\u0107 wpis\u00f3w w stosunku do innych.","type":"integer","required":false},"meta":{"description":"Pola meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Plik motywu u\u017cywany do wy\u015bwietlania wpisu.","type":"string","required":false},"ld_collection":{"description":"Terminy przypisane do wpisu w taksonomii: ld_collection","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator wpisu.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Okre\u015bla, czy pomin\u0105\u0107 kosz i wymusi\u0107 usuni\u0119cie.","required":false}}}]},"\/wp\/v2\/ld_docs\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator elementu nadrz\u0119dnego autozapisu.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Identyfikator elementu nadrz\u0119dnego wpisu.","type":"integer","required":false},"date":{"description":"Data publikacji wpisu w strefie czasowej witryny.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data wpisu zosta\u0142a opublikowana jako GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Alfanumeryczny identyfikator dla wpisu unikatowy dla jego typu.","type":"string","required":false},"status":{"description":"Nazwa statusu wpisu.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Has\u0142o ochrony dost\u0119pu do tre\u015bci i zajawki.","type":"string","required":false},"title":{"description":"Tytu\u0142 wpisu.","type":"object","properties":{"raw":{"description":"Tytu\u0142 wpisu, istniej\u0105cy w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Tytu\u0142 HTML wpisu, przekszta\u0142cony do wy\u015bwietlania.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Tre\u015b\u0107 wpisu.","type":"object","properties":{"raw":{"description":"Tre\u015b\u0107 wpisu, tak jak zosta\u0142a zapisana w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Zawarto\u015b\u0107 HMTL wpisu, przetworzona do wy\u015bwietlenia.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Wersja bloku tre\u015bci u\u017cywanego we wpisie.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Czy tre\u015b\u0107 jest chronia has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Identyfikator autora wpisu.","type":"integer","required":false},"excerpt":{"description":"Zajawka wpisu.","type":"object","properties":{"raw":{"description":"Zajawka wpisu, tak jak wyst\u0119puje w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Wycinek HTML dla wpisu, przekszta\u0142cony do wy\u015bwietlenia.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Czy zajawka zabezpieczona jest has\u0142em.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Identyfikator wyr\u00f3\u017cniaj\u0105cego pliku medialnego wpisu.","type":"integer","required":false},"menu_order":{"description":"Kolejno\u015b\u0107 wpis\u00f3w w stosunku do innych.","type":"integer","required":false},"meta":{"description":"Pola meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Plik motywu u\u017cywany do wy\u015bwietlania wpisu.","type":"string","required":false},"ld_collection":{"description":"Terminy przypisane do wpisu w taksonomii: ld_collection","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/ld_docs\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Identyfikator elementu nadrz\u0119dnego autozapisu.","type":"integer","required":false},"id":{"description":"Identyfikator automatycznego zapisu.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/wp\/v2\/types"}]}},"\/wp\/v2\/types\/(?P<type>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"description":"Identyfikator alfa-numeryczny dla typu tre\u015bci.","type":"string","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/statuses":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/wp\/v2\/statuses"}]}},"\/wp\/v2\/statuses\/(?P<status>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"Identyfikator alfanumeryczny statusu.","type":"string","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/taxonomies":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"type":{"description":"Ogranicz wyniki do taksonomii powi\u0105zanych z okre\u015blonym typem tre\u015bci.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/wp\/v2\/taxonomies"}]}},"\/wp\/v2\/taxonomies\/(?P<taxonomy>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"taxonomy":{"description":"Alfanumeryczny identyfikator taksonomii.","type":"string","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/categories":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ogranicz wyniki do pasuj\u0105cych do zapytania.","type":"string","required":false},"exclude":{"description":"Upewnij si\u0119, \u017ce zestaw wynik\u00f3w wyklucza okre\u015blone identyfikatory.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ogranicz zbi\u00f3r wynik\u00f3w do wybranych ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Sortowanie atrybut\u00f3w rosn\u0105co lub malej\u0105co.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortuj zbi\u00f3r wed\u0142ug atrybutu taksonomii.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Czy ukry\u0107 taksonomie nieprzypisane do \u017cadnych wpis\u00f3w.","type":"boolean","default":false,"required":false},"parent":{"description":"Ogranicz wyniki do taksonomii posiadaj\u0105cych okre\u015blony element nadrz\u0119dny.","type":"integer","required":false},"post":{"description":"Ogranicz wyniki do taksonomii powi\u0105zanych z okre\u015blonym wpisem.","type":"integer","default":null,"required":false},"slug":{"description":"Ogranicz wyniki taksonomii do jednej lub wielu uproszczonych nazw.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Opis HTML dla taksonomii:","type":"string","required":false},"name":{"description":"Tytu\u0142 HTML taksonomii.","type":"string","required":true},"slug":{"description":"Alfanumeryczny identyfikator dla poj\u0119cia unikatowy dla jego typu.","type":"string","required":false},"parent":{"description":"Identyfikator taksonomii nadrz\u0119dnej.","type":"integer","required":false},"meta":{"description":"Pola meta.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/wp\/v2\/categories"}]}},"\/wp\/v2\/categories\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator dla taksonomii.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator dla taksonomii.","type":"integer","required":false},"description":{"description":"Opis HTML dla taksonomii:","type":"string","required":false},"name":{"description":"Tytu\u0142 HTML taksonomii.","type":"string","required":false},"slug":{"description":"Alfanumeryczny identyfikator dla poj\u0119cia unikatowy dla jego typu.","type":"string","required":false},"parent":{"description":"Identyfikator taksonomii nadrz\u0119dnej.","type":"integer","required":false},"meta":{"description":"Pola meta.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator dla taksonomii.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Musi by\u0107 w\u0142\u0105czone, poniewa\u017c w taksonomiach nie u\u017cywamy kosza.","required":false}}}]},"\/wp\/v2\/tags":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ogranicz wyniki do pasuj\u0105cych do zapytania.","type":"string","required":false},"exclude":{"description":"Upewnij si\u0119, \u017ce zestaw wynik\u00f3w wyklucza okre\u015blone identyfikatory.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ogranicz zbi\u00f3r wynik\u00f3w do wybranych ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Przesu\u0144 wyniki o okre\u015blon\u0105 liczb\u0119 pozycji.","type":"integer","required":false},"order":{"description":"Sortowanie atrybut\u00f3w rosn\u0105co lub malej\u0105co.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortuj zbi\u00f3r wed\u0142ug atrybutu taksonomii.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Czy ukry\u0107 taksonomie nieprzypisane do \u017cadnych wpis\u00f3w.","type":"boolean","default":false,"required":false},"post":{"description":"Ogranicz wyniki do taksonomii powi\u0105zanych z okre\u015blonym wpisem.","type":"integer","default":null,"required":false},"slug":{"description":"Ogranicz wyniki taksonomii do jednej lub wielu uproszczonych nazw.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Opis HTML dla taksonomii:","type":"string","required":false},"name":{"description":"Tytu\u0142 HTML taksonomii.","type":"string","required":true},"slug":{"description":"Alfanumeryczny identyfikator dla poj\u0119cia unikatowy dla jego typu.","type":"string","required":false},"meta":{"description":"Pola meta.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/wp\/v2\/tags"}]}},"\/wp\/v2\/tags\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator dla taksonomii.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator dla taksonomii.","type":"integer","required":false},"description":{"description":"Opis HTML dla taksonomii:","type":"string","required":false},"name":{"description":"Tytu\u0142 HTML taksonomii.","type":"string","required":false},"slug":{"description":"Alfanumeryczny identyfikator dla poj\u0119cia unikatowy dla jego typu.","type":"string","required":false},"meta":{"description":"Pola meta.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator dla taksonomii.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Musi by\u0107 w\u0142\u0105czone, poniewa\u017c w taksonomiach nie u\u017cywamy kosza.","required":false}}}]},"\/wp\/v2\/menus":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ogranicz wyniki do pasuj\u0105cych do zapytania.","type":"string","required":false},"exclude":{"description":"Upewnij si\u0119, \u017ce zestaw wynik\u00f3w wyklucza okre\u015blone identyfikatory.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ogranicz zbi\u00f3r wynik\u00f3w do wybranych ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Przesu\u0144 wyniki o okre\u015blon\u0105 liczb\u0119 pozycji.","type":"integer","required":false},"order":{"description":"Sortowanie atrybut\u00f3w rosn\u0105co lub malej\u0105co.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortuj zbi\u00f3r wed\u0142ug atrybutu taksonomii.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Czy ukry\u0107 taksonomie nieprzypisane do \u017cadnych wpis\u00f3w.","type":"boolean","default":false,"required":false},"post":{"description":"Ogranicz wyniki do taksonomii powi\u0105zanych z okre\u015blonym wpisem.","type":"integer","default":null,"required":false},"slug":{"description":"Ogranicz wyniki taksonomii do jednej lub wielu uproszczonych nazw.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Opis HTML dla taksonomii:","type":"string","required":false},"name":{"description":"Tytu\u0142 HTML taksonomii.","type":"string","required":true},"slug":{"description":"Alfanumeryczny identyfikator dla poj\u0119cia unikatowy dla jego typu.","type":"string","required":false},"meta":{"description":"Pola meta.","type":"object","properties":[],"required":false},"locations":{"description":"Po\u0142o\u017cenie przypisana do menu.","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"Czy automatycznie dodawa\u0107 strony najwy\u017cszego poziomu do tego menu.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/wp\/v2\/menus"}]}},"\/wp\/v2\/menus\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator dla taksonomii.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator dla taksonomii.","type":"integer","required":false},"description":{"description":"Opis HTML dla taksonomii:","type":"string","required":false},"name":{"description":"Tytu\u0142 HTML taksonomii.","type":"string","required":false},"slug":{"description":"Alfanumeryczny identyfikator dla poj\u0119cia unikatowy dla jego typu.","type":"string","required":false},"meta":{"description":"Pola meta.","type":"object","properties":[],"required":false},"locations":{"description":"Po\u0142o\u017cenie przypisana do menu.","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"Czy automatycznie dodawa\u0107 strony najwy\u017cszego poziomu do tego menu.","type":"boolean","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator dla taksonomii.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Musi by\u0107 w\u0142\u0105czone, poniewa\u017c w taksonomiach nie u\u017cywamy kosza.","required":false}}}]},"\/wp\/v2\/wp_pattern_category":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ogranicz wyniki do pasuj\u0105cych do zapytania.","type":"string","required":false},"exclude":{"description":"Upewnij si\u0119, \u017ce zestaw wynik\u00f3w wyklucza okre\u015blone identyfikatory.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ogranicz zbi\u00f3r wynik\u00f3w do wybranych ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Przesu\u0144 wyniki o okre\u015blon\u0105 liczb\u0119 pozycji.","type":"integer","required":false},"order":{"description":"Sortowanie atrybut\u00f3w rosn\u0105co lub malej\u0105co.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortuj zbi\u00f3r wed\u0142ug atrybutu taksonomii.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Czy ukry\u0107 taksonomie nieprzypisane do \u017cadnych wpis\u00f3w.","type":"boolean","default":false,"required":false},"post":{"description":"Ogranicz wyniki do taksonomii powi\u0105zanych z okre\u015blonym wpisem.","type":"integer","default":null,"required":false},"slug":{"description":"Ogranicz wyniki taksonomii do jednej lub wielu uproszczonych nazw.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Opis HTML dla taksonomii:","type":"string","required":false},"name":{"description":"Tytu\u0142 HTML taksonomii.","type":"string","required":true},"slug":{"description":"Alfanumeryczny identyfikator dla poj\u0119cia unikatowy dla jego typu.","type":"string","required":false},"meta":{"description":"Pola meta.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/wp\/v2\/wp_pattern_category"}]}},"\/wp\/v2\/wp_pattern_category\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator dla taksonomii.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator dla taksonomii.","type":"integer","required":false},"description":{"description":"Opis HTML dla taksonomii:","type":"string","required":false},"name":{"description":"Tytu\u0142 HTML taksonomii.","type":"string","required":false},"slug":{"description":"Alfanumeryczny identyfikator dla poj\u0119cia unikatowy dla jego typu.","type":"string","required":false},"meta":{"description":"Pola meta.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator dla taksonomii.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Musi by\u0107 w\u0142\u0105czone, poniewa\u017c w taksonomiach nie u\u017cywamy kosza.","required":false}}}]},"\/wp\/v2\/banner_groups":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ogranicz wyniki do pasuj\u0105cych do zapytania.","type":"string","required":false},"exclude":{"description":"Upewnij si\u0119, \u017ce zestaw wynik\u00f3w wyklucza okre\u015blone identyfikatory.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ogranicz zbi\u00f3r wynik\u00f3w do wybranych ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Sortowanie atrybut\u00f3w rosn\u0105co lub malej\u0105co.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortuj zbi\u00f3r wed\u0142ug atrybutu taksonomii.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Czy ukry\u0107 taksonomie nieprzypisane do \u017cadnych wpis\u00f3w.","type":"boolean","default":false,"required":false},"parent":{"description":"Ogranicz wyniki do taksonomii posiadaj\u0105cych okre\u015blony element nadrz\u0119dny.","type":"integer","required":false},"post":{"description":"Ogranicz wyniki do taksonomii powi\u0105zanych z okre\u015blonym wpisem.","type":"integer","default":null,"required":false},"slug":{"description":"Ogranicz wyniki taksonomii do jednej lub wielu uproszczonych nazw.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Opis HTML dla taksonomii:","type":"string","required":false},"name":{"description":"Tytu\u0142 HTML taksonomii.","type":"string","required":true},"slug":{"description":"Alfanumeryczny identyfikator dla poj\u0119cia unikatowy dla jego typu.","type":"string","required":false},"parent":{"description":"Identyfikator taksonomii nadrz\u0119dnej.","type":"integer","required":false},"meta":{"description":"Pola meta.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/wp\/v2\/banner_groups"}]}},"\/wp\/v2\/banner_groups\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator dla taksonomii.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator dla taksonomii.","type":"integer","required":false},"description":{"description":"Opis HTML dla taksonomii:","type":"string","required":false},"name":{"description":"Tytu\u0142 HTML taksonomii.","type":"string","required":false},"slug":{"description":"Alfanumeryczny identyfikator dla poj\u0119cia unikatowy dla jego typu.","type":"string","required":false},"parent":{"description":"Identyfikator taksonomii nadrz\u0119dnej.","type":"integer","required":false},"meta":{"description":"Pola meta.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator dla taksonomii.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Musi by\u0107 w\u0142\u0105czone, poniewa\u017c w taksonomiach nie u\u017cywamy kosza.","required":false}}}]},"\/wp\/v2\/ld_collection":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ogranicz wyniki do pasuj\u0105cych do zapytania.","type":"string","required":false},"exclude":{"description":"Upewnij si\u0119, \u017ce zestaw wynik\u00f3w wyklucza okre\u015blone identyfikatory.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ogranicz zbi\u00f3r wynik\u00f3w do wybranych ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Sortowanie atrybut\u00f3w rosn\u0105co lub malej\u0105co.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortuj zbi\u00f3r wed\u0142ug atrybutu taksonomii.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Czy ukry\u0107 taksonomie nieprzypisane do \u017cadnych wpis\u00f3w.","type":"boolean","default":false,"required":false},"parent":{"description":"Ogranicz wyniki do taksonomii posiadaj\u0105cych okre\u015blony element nadrz\u0119dny.","type":"integer","required":false},"post":{"description":"Ogranicz wyniki do taksonomii powi\u0105zanych z okre\u015blonym wpisem.","type":"integer","default":null,"required":false},"slug":{"description":"Ogranicz wyniki taksonomii do jednej lub wielu uproszczonych nazw.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Opis HTML dla taksonomii:","type":"string","required":false},"name":{"description":"Tytu\u0142 HTML taksonomii.","type":"string","required":true},"slug":{"description":"Alfanumeryczny identyfikator dla poj\u0119cia unikatowy dla jego typu.","type":"string","required":false},"parent":{"description":"Identyfikator taksonomii nadrz\u0119dnej.","type":"integer","required":false},"meta":{"description":"Pola meta.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/wp\/v2\/ld_collection"}]}},"\/wp\/v2\/ld_collection\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator dla taksonomii.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator dla taksonomii.","type":"integer","required":false},"description":{"description":"Opis HTML dla taksonomii:","type":"string","required":false},"name":{"description":"Tytu\u0142 HTML taksonomii.","type":"string","required":false},"slug":{"description":"Alfanumeryczny identyfikator dla poj\u0119cia unikatowy dla jego typu.","type":"string","required":false},"parent":{"description":"Identyfikator taksonomii nadrz\u0119dnej.","type":"integer","required":false},"meta":{"description":"Pola meta.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator dla taksonomii.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Musi by\u0107 w\u0142\u0105czone, poniewa\u017c w taksonomiach nie u\u017cywamy kosza.","required":false}}}]},"\/wp\/v2\/users":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ogranicz wyniki do pasuj\u0105cych do zapytania.","type":"string","required":false},"exclude":{"description":"Upewnij si\u0119, \u017ce zestaw wynik\u00f3w wyklucza okre\u015blone identyfikatory.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ogranicz zbi\u00f3r wynik\u00f3w do wybranych ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Przesu\u0144 wyniki o okre\u015blon\u0105 liczb\u0119 pozycji.","type":"integer","required":false},"order":{"default":"asc","description":"Sortowanie atrybut\u00f3w rosn\u0105co lub malej\u0105co.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"name","description":"Sortuj kolekcj\u0119 wed\u0142ug atrybutu u\u017cytkownika.","enum":["id","include","name","registered_date","slug","include_slugs","email","url"],"type":"string","required":false},"slug":{"description":"Ogranicz wynik do u\u017cytkownik\u00f3w za pomoc\u0105 co najmniej jednej uproszczonej nazwy.","type":"array","items":{"type":"string"},"required":false},"roles":{"description":"Ogranicz do zasob\u00f3w pasuj\u0105cych do co najmniej jednej z podanych r\u00f3l. Akceptowana jest lista rozdzielana przecinkami lub pojedyncza rola.","type":"array","items":{"type":"string"},"required":false},"capabilities":{"description":"Ogranicz zestaw wynik\u00f3w do u\u017cytkownik\u00f3w z co najmniej jednym uprawnieniem. Akceptowana jest lista csv lub pojedyncze uprawnienie.","type":"array","items":{"type":"string"},"required":false},"who":{"description":"Ogranicza wyniki do u\u017cytkownik\u00f3w uznawanych za autor\u00f3w.","type":"string","enum":["authors"],"required":false},"has_published_posts":{"description":"Ogranicz zestaw wynik\u00f3w do u\u017cytkownik\u00f3w, kt\u00f3rzy opublikowali wpisy.","type":["boolean","array"],"items":{"type":"string","enum":{"post":"post","page":"page","attachment":"attachment","nav_menu_item":"nav_menu_item","wp_block":"wp_block","wp_template":"wp_template","wp_template_part":"wp_template_part","wp_global_styles":"wp_global_styles","wp_navigation":"wp_navigation","wp_font_family":"wp_font_family","wp_font_face":"wp_font_face","banner":"banner","ld_docs":"ld_docs"}},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"username":{"description":"Login u\u017cytkownika.","type":"string","required":true},"name":{"description":"Wy\u015bwietlana nazwa u\u017cytkownika.","type":"string","required":false},"first_name":{"description":"Imi\u0119 u\u017cytkownika.","type":"string","required":false},"last_name":{"description":"Nazwisko u\u017cytkownika.","type":"string","required":false},"email":{"description":"Adres e-mail u\u017cytkownika.","type":"string","format":"email","required":true},"url":{"description":"Adres URL u\u017cytkownika.","type":"string","format":"uri","required":false},"description":{"description":"Opis u\u017cytkownika.","type":"string","required":false},"locale":{"description":"Ustawienia regionalne u\u017cytkownika.","type":"string","enum":["","en_US","de_DE","es_ES","fa_IR","fr_FR","hi_IN","id_ID","it_IT","ja","nl_NL_formal","pl_PL","pt_PT","ru_RU","tr_TR","vi","zh_CN","zh_TW"],"required":false},"nickname":{"description":"Pseudonim u\u017cytkownika.","type":"string","required":false},"slug":{"description":"Identyfikator alfanumeryczny uzytkownika.","type":"string","required":false},"roles":{"description":"U\u017cytkownikowi przypisano wybrane role.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Has\u0142o u\u017cytkownika (nigdy do\u0142\u0105czane).","type":"string","required":true},"meta":{"description":"Pola meta.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"Data i godzina aktualizacji preferencji.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/wp\/v2\/users"}]}},"\/wp\/v2\/users\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator u\u017cytkownika.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator u\u017cytkownika.","type":"integer","required":false},"username":{"description":"Login u\u017cytkownika.","type":"string","required":false},"name":{"description":"Wy\u015bwietlana nazwa u\u017cytkownika.","type":"string","required":false},"first_name":{"description":"Imi\u0119 u\u017cytkownika.","type":"string","required":false},"last_name":{"description":"Nazwisko u\u017cytkownika.","type":"string","required":false},"email":{"description":"Adres e-mail u\u017cytkownika.","type":"string","format":"email","required":false},"url":{"description":"Adres URL u\u017cytkownika.","type":"string","format":"uri","required":false},"description":{"description":"Opis u\u017cytkownika.","type":"string","required":false},"locale":{"description":"Ustawienia regionalne u\u017cytkownika.","type":"string","enum":["","en_US","de_DE","es_ES","fa_IR","fr_FR","hi_IN","id_ID","it_IT","ja","nl_NL_formal","pl_PL","pt_PT","ru_RU","tr_TR","vi","zh_CN","zh_TW"],"required":false},"nickname":{"description":"Pseudonim u\u017cytkownika.","type":"string","required":false},"slug":{"description":"Identyfikator alfanumeryczny uzytkownika.","type":"string","required":false},"roles":{"description":"U\u017cytkownikowi przypisano wybrane role.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Has\u0142o u\u017cytkownika (nigdy do\u0142\u0105czane).","type":"string","required":false},"meta":{"description":"Pola meta.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"Data i godzina aktualizacji preferencji.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator u\u017cytkownika.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Musi by\u0107 w\u0142\u0105czone, poniewa\u017c w u\u017cytkownikach nie u\u017cywamy kosza.","required":false},"reassign":{"type":"integer","description":"Przypisz wpisy i odno\u015bniki usuni\u0119tego autora do autora o podanym identyfikatorze.","required":true}}}]},"\/wp\/v2\/users\/me":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"username":{"description":"Login u\u017cytkownika.","type":"string","required":false},"name":{"description":"Wy\u015bwietlana nazwa u\u017cytkownika.","type":"string","required":false},"first_name":{"description":"Imi\u0119 u\u017cytkownika.","type":"string","required":false},"last_name":{"description":"Nazwisko u\u017cytkownika.","type":"string","required":false},"email":{"description":"Adres e-mail u\u017cytkownika.","type":"string","format":"email","required":false},"url":{"description":"Adres URL u\u017cytkownika.","type":"string","format":"uri","required":false},"description":{"description":"Opis u\u017cytkownika.","type":"string","required":false},"locale":{"description":"Ustawienia regionalne u\u017cytkownika.","type":"string","enum":["","en_US","de_DE","es_ES","fa_IR","fr_FR","hi_IN","id_ID","it_IT","ja","nl_NL_formal","pl_PL","pt_PT","ru_RU","tr_TR","vi","zh_CN","zh_TW"],"required":false},"nickname":{"description":"Pseudonim u\u017cytkownika.","type":"string","required":false},"slug":{"description":"Identyfikator alfanumeryczny uzytkownika.","type":"string","required":false},"roles":{"description":"U\u017cytkownikowi przypisano wybrane role.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Has\u0142o u\u017cytkownika (nigdy do\u0142\u0105czane).","type":"string","required":false},"meta":{"description":"Pola meta.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"Data i godzina aktualizacji preferencji.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false}}},{"methods":["DELETE"],"args":{"force":{"type":"boolean","default":false,"description":"Musi by\u0107 w\u0142\u0105czone, poniewa\u017c w u\u017cytkownikach nie u\u017cywamy kosza.","required":false},"reassign":{"type":"integer","description":"Przypisz wpisy i odno\u015bniki usuni\u0119tego autora do autora o podanym identyfikatorze.","required":true}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/wp\/v2\/users\/me"}]}},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords":{"namespace":"wp\/v2","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"app_id":{"description":"UUID dostarczony przez aplikacj\u0119 w celu jej jednoznacznej identyfikacji. Zaleca si\u0119 u\u017cywanie UUID v5 z adresem URL lub przestrzeni\u0105 nazw DNS.","type":"string","format":"uuid","required":false},"name":{"description":"Nazwa has\u0142a aplikacji.","type":"string","minLength":1,"pattern":".*\\S.*","required":true}}},{"methods":["DELETE"],"args":[]}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/introspect":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/(?P<uuid>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"app_id":{"description":"UUID dostarczony przez aplikacj\u0119 w celu jej jednoznacznej identyfikacji. Zaleca si\u0119 u\u017cywanie UUID v5 z adresem URL lub przestrzeni\u0105 nazw DNS.","type":"string","format":"uuid","required":false},"name":{"description":"Nazwa has\u0142a aplikacji.","type":"string","minLength":1,"pattern":".*\\S.*","required":false}}},{"methods":["DELETE"],"args":[]}]},"\/wp\/v2\/comments":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ogranicz wyniki do pasuj\u0105cych do zapytania.","type":"string","required":false},"after":{"description":"Ogranicz do komentarzy opublikowanych po dacie podanej w formacie ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Ogranicz wyniki do komentarzy powi\u0105zanych z wybranym identyfikatorem u\u017cytkownika. Wymagana autoryzacja.","type":"array","items":{"type":"integer"},"required":false},"author_exclude":{"description":"Wy\u0142\u0105cz komentarze powi\u0105zane z u\u017cytkownikami o identyfikatorach. Wymagana autoryzacja.","type":"array","items":{"type":"integer"},"required":false},"author_email":{"default":null,"description":"Ogranicz wyniki na podstawie adresu e-mail autora. Wymagana autoryzacja.","format":"email","type":"string","required":false},"before":{"description":"Ogranicz do komentarzy opublikowanych przed dat\u0105 podan\u0105 w formacie ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Upewnij si\u0119, \u017ce zestaw wynik\u00f3w wyklucza okre\u015blone identyfikatory.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ogranicz zbi\u00f3r wynik\u00f3w do wybranych ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Przesu\u0144 wyniki o okre\u015blon\u0105 liczb\u0119 pozycji.","type":"integer","required":false},"order":{"description":"Sortowanie atrybut\u00f3w rosn\u0105co lub malej\u0105co.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortuj kolekcj\u0119 za pomoc\u0105 trybuty komentarza.","type":"string","default":"date_gmt","enum":["date","date_gmt","id","include","post","parent","type"],"required":false},"parent":{"default":[],"description":"Ogranicz wyniki do komentarzy powi\u0105zanych z okre\u015blonymi identyfikatorami element\u00f3w nadrz\u0119dnych.","type":"array","items":{"type":"integer"},"required":false},"parent_exclude":{"default":[],"description":"Prosz\u0119 si\u0119 upewni\u0107, \u017ce zestaw wynik\u00f3w wyklucza okre\u015blone identyfikatory element\u00f3w nadrz\u0119dnych.","type":"array","items":{"type":"integer"},"required":false},"post":{"default":[],"description":"Ogranicz wyniki do komentarzy powi\u0105zanych z okre\u015blonymi identyfikatorami wpis\u00f3w.","type":"array","items":{"type":"integer"},"required":false},"status":{"default":"approve","description":"Ogranicz do wybranego statusu komentarzy. Wymagana autoryzacja.","type":"string","required":false},"type":{"default":"comment","description":"Ogranicz do wybranego rodzaju  komentarzy. Wymagana autoryzacja.","type":"string","required":false},"password":{"description":"Has\u0142o dla wpisu, je\u015bli jest on chroniony has\u0142em.","type":"string","required":false}}},{"methods":["POST"],"args":{"author":{"description":"Identyfikator obiektu u\u017cytkownika, je\u017celi autor by\u0142 u\u017cytkownikiem.","type":"integer","required":false},"author_email":{"description":"Adres e-mail autora komentarza.","type":"string","format":"email","required":false},"author_ip":{"description":"Adres IP autora komentarza.","type":"string","format":"ip","required":false},"author_name":{"description":"Wy\u015bwietlana nazwa autora komentarza.","type":"string","required":false},"author_url":{"description":"Adres URL autora komentarza.","type":"string","format":"uri","required":false},"author_user_agent":{"description":"Klient u\u017cytkownika autora komentarza.","type":"string","required":false},"content":{"description":"Tre\u015b\u0107 komentarza.","type":"object","properties":{"raw":{"description":"Tre\u015b\u0107 komentarza, dok\u0142adnie takie jak w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Zawarto\u015b\u0107 HMTL komentarza, przetworzona do wy\u015bwietlenia.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"Data opublikowania komentarza w strefie czasowej witryny. ","type":"string","format":"date-time","required":false},"date_gmt":{"description":"Data komentarza zosta\u0142a opublikowana jako GMT.","type":"string","format":"date-time","required":false},"parent":{"default":0,"description":"Identyfikator elementu nadrz\u0119dnego komentarza.","type":"integer","required":false},"post":{"default":0,"description":"Identyfikator powi\u0105zanego obiektu wpisu.","type":"integer","required":false},"status":{"description":"Stan komentarza.","type":"string","required":false},"meta":{"description":"Pola meta.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/wp\/v2\/comments"}]}},"\/wp\/v2\/comments\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unikatowy identyfikator komentarza.","type":"integer","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Has\u0142o dla nadrz\u0119dnego wpisu (je\u015bli wpis jest chroniony has\u0142em).","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unikatowy identyfikator komentarza.","type":"integer","required":false},"author":{"description":"Identyfikator obiektu u\u017cytkownika, je\u017celi autor by\u0142 u\u017cytkownikiem.","type":"integer","required":false},"author_email":{"description":"Adres e-mail autora komentarza.","type":"string","format":"email","required":false},"author_ip":{"description":"Adres IP autora komentarza.","type":"string","format":"ip","required":false},"author_name":{"description":"Wy\u015bwietlana nazwa autora komentarza.","type":"string","required":false},"author_url":{"description":"Adres URL autora komentarza.","type":"string","format":"uri","required":false},"author_user_agent":{"description":"Klient u\u017cytkownika autora komentarza.","type":"string","required":false},"content":{"description":"Tre\u015b\u0107 komentarza.","type":"object","properties":{"raw":{"description":"Tre\u015b\u0107 komentarza, dok\u0142adnie takie jak w bazie danych.","type":"string","context":["edit"]},"rendered":{"description":"Zawarto\u015b\u0107 HMTL komentarza, przetworzona do wy\u015bwietlenia.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"Data opublikowania komentarza w strefie czasowej witryny. ","type":"string","format":"date-time","required":false},"date_gmt":{"description":"Data komentarza zosta\u0142a opublikowana jako GMT.","type":"string","format":"date-time","required":false},"parent":{"description":"Identyfikator elementu nadrz\u0119dnego komentarza.","type":"integer","required":false},"post":{"description":"Identyfikator powi\u0105zanego obiektu wpisu.","type":"integer","required":false},"status":{"description":"Stan komentarza.","type":"string","required":false},"meta":{"description":"Pola meta.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unikatowy identyfikator komentarza.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Okre\u015bla, czy pomin\u0105\u0107 kosz i wymusi\u0107 usuni\u0119cie.","required":false},"password":{"description":"Has\u0142o dla nadrz\u0119dnego wpisu (je\u015bli wpis jest chroniony has\u0142em).","type":"string","required":false}}}]},"\/wp\/v2\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ogranicz wyniki do pasuj\u0105cych do zapytania.","type":"string","required":false},"type":{"default":"post","description":"Ogranicz wyniki wyszukiwania do wybranego typu obiektu.","type":"string","enum":["post","term","post-format"],"required":false},"subtype":{"default":"any","description":"Ogranicz wyniki wyszukiwania do jednego lub wi\u0119cej podtyp\u00f3w obiektu.","type":"array","items":{"enum":["post","page","banner","ld_docs","category","post_tag","banner_groups","ld_collection","any"],"type":"string"},"required":false},"exclude":{"description":"Upewnij si\u0119, \u017ce zestaw wynik\u00f3w wyklucza okre\u015blone identyfikatory.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ogranicz zbi\u00f3r wynik\u00f3w do wybranych ID.","type":"array","items":{"type":"integer"},"default":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/wp\/v2\/search"}]}},"\/wp\/v2\/block-renderer\/(?P<name>[a-z0-9-]+\/[a-z0-9-]+)":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET","POST"],"args":{"name":{"description":"Zarejestrowana, unikalna nazwa bloku.","type":"string","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["edit"],"default":"view","required":false},"attributes":{"description":"Atrybuty bloku.","type":"object","default":[],"required":false},"post_id":{"description":"Identyfikator kontekstu wpisu.","type":"integer","required":false}}}]},"\/wp\/v2\/block-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"Przestrze\u0144 nazw bloku.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/wp\/v2\/block-types"}]}},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"Przestrze\u0144 nazw bloku.","type":"string","required":false}}}]},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)\/(?P<name>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Nazwa bloku.","type":"string","required":false},"namespace":{"description":"Przestrze\u0144 nazw bloku.","type":"string","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/settings":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"title":{"title":"Tytu\u0142","description":"Tytu\u0142 witryny.","type":"string","required":false},"description":{"title":"Slogan","description":"Motto witryny.","type":"string","required":false},"timezone":{"title":"","description":"Miasto w twojej strefie czasowej,","type":"string","required":false},"date_format":{"title":"","description":"Format daty dla wszystkich wyst\u0105pe\u0144","type":"string","required":false},"time_format":{"title":"","description":"Format czasu dla wszystkich wyst\u0105pe\u0144","type":"string","required":false},"start_of_week":{"title":"","description":"Numer dnia tygodnia, dla kt\u00f3rego powinien si\u0119 on zaczyna\u0107.","type":"integer","required":false},"language":{"title":"","description":"Kod ustawie\u0144 regionalnych WordPressa.","type":"string","required":false},"use_smilies":{"title":"","description":"W czasie wy\u015bwietlania zmienia emotikony :-) i :-P na grafiki.","type":"boolean","required":false},"default_category":{"title":"","description":"Domy\u015blna kategoria wpisu.","type":"integer","required":false},"default_post_format":{"title":"","description":"Domy\u015blny format wpisu.","type":"string","required":false},"posts_per_page":{"title":"Maksymalna liczba wpis\u00f3w na stron\u0119","description":"Strony blogu wy\u015bwietlaj\u0105 maksymalnie tyle wpis\u00f3w.","type":"integer","required":false},"show_on_front":{"title":"Poka\u017c na stronie g\u0142\u00f3wnej","description":"Co pokaza\u0107 na stronie g\u0142\u00f3wnej","type":"string","required":false},"page_on_front":{"title":"Strona strony g\u0142\u00f3wnej","description":"Identyfikator strony, kt\u00f3ra powinna by\u0107 wy\u015bwietlana na stronie g\u0142\u00f3wnej","type":"integer","required":false},"page_for_posts":{"title":"","description":"Identyfikator strony, kt\u00f3ra powinna wy\u015bwietla\u0107 najnowsze wpisy","type":"integer","required":false},"default_ping_status":{"title":"","description":"Pozwala na powiadomienia z innych witryn (pingbacki i trackbacki) w nowych artyku\u0142ach.","type":"string","enum":["open","closed"],"required":false},"default_comment_status":{"title":"Zezwalaj na komentowanie nowych wpis\u00f3w","description":"Zezw\u00f3l na komentowanie nowych wpis\u00f3w.","type":"string","enum":["open","closed"],"required":false},"site_logo":{"title":"Logo","description":"Logo witryny.","type":"integer","required":false},"site_icon":{"title":"Ikonka","description":"Ikonka witryny.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/wp\/v2\/settings"}]}},"\/wp\/v2\/themes":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"Ogranicz wyniki do motyw\u00f3w posiadaj\u0105cych co najmniej jeden status.","type":"array","items":{"enum":["active","inactive"],"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/wp\/v2\/themes"}]}},"\/wp\/v2\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"stylesheet":{"description":"Arkusz styl\u00f3w motywu jednoznacznie go identyfikuje.","type":"string","required":false}}}]},"\/wp\/v2\/plugins":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"search":{"description":"Ogranicz wyniki do pasuj\u0105cych do zapytania.","type":"string","required":false},"status":{"description":"Ogranicza wyniki do wtyczek o podanym statusie.","type":"array","items":{"type":"string","enum":["inactive","active","network-active"]},"required":false}}},{"methods":["POST"],"args":{"slug":{"type":"string","description":"Uproszczona nazwa w katalogu wtyczek WordPress.org.","pattern":"[\\w\\-]+","required":true},"status":{"description":"Status aktywacji wtyczki.","type":"string","enum":["inactive","active","network-active"],"default":"inactive","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/wp\/v2\/plugins"}]}},"\/wp\/v2\/plugins\/(?P<plugin>[^.\\\/]+(?:\\\/[^.\\\/]+)?)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false},"status":{"description":"Status aktywacji wtyczki.","type":"string","enum":["inactive","active","network-active"],"required":false}}},{"methods":["DELETE"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false}}}]},"\/wp\/v2\/sidebars":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/wp\/v2\/sidebars"}]}},"\/wp\/v2\/sidebars\/(?P<id>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identyfikator zarejestrowanego panelu bocznego","type":"string","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"widgets":{"description":"Zagnie\u017cd\u017cone wid\u017cety.","type":"array","items":{"type":["object","string"]},"required":false}}}]},"\/wp\/v2\/widget-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/wp\/v2\/widget-types"}]}},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identyfikator typu wid\u017cetu.","type":"string","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/encode":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Identyfikator typu wid\u017cetu.","type":"string","required":true},"instance":{"description":"Aktualne ustawienia instancji wid\u017cetu.","type":"object","required":false},"form_data":{"description":"Serializowane dane formularza wid\u017cetu do zakodowania w ustawieniach instancji.","type":"string","required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/render":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Identyfikator typu wid\u017cetu.","type":"string","required":true},"instance":{"description":"Aktualne ustawienia instancji wid\u017cetu.","type":"object","required":false}}}]},"\/wp\/v2\/widgets":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"sidebar":{"description":"Pasek boczny do zwracania wid\u017cet\u00f3w.","type":"string","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator wid\u017cetu.","type":"string","required":false},"id_base":{"description":"Typ wid\u017cetu. Odpowiada identyfikatorowi typu wid\u017cetu.","type":"string","required":false},"sidebar":{"default":"wp_inactive_widgets","description":"Pasek boczny, do kt\u00f3rego nale\u017cy wid\u017cet.","type":"string","required":true},"instance":{"description":"Ustawienia instancji wid\u017cetu, je\u015bli s\u0105 obs\u0142ugiwane.","type":"object","properties":{"encoded":{"description":"Ustawienia instancji zakodowane Base64.","type":"string","context":["edit"]},"hash":{"description":"Hash kryptograficzny ustawie\u0144 instancji.","type":"string","context":["edit"]},"raw":{"description":"Niezakodowane ustawienia instancji, je\u015bli s\u0105 obs\u0142ugiwane.","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"Zakodowane w adresie URL dane z formularza wid\u017cetu. S\u0142u\u017cy do aktualizacji wid\u017cetu, kt\u00f3ry nie obs\u0142uguje instancji. Tylko zapisywanie.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/wp\/v2\/widgets"}]}},"\/wp\/v2\/widgets\/(?P<id>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Unikatowy identyfikator wid\u017cetu.","type":"string","required":false},"id_base":{"description":"Typ wid\u017cetu. Odpowiada identyfikatorowi typu wid\u017cetu.","type":"string","required":false},"sidebar":{"description":"Pasek boczny, do kt\u00f3rego nale\u017cy wid\u017cet.","type":"string","required":false},"instance":{"description":"Ustawienia instancji wid\u017cetu, je\u015bli s\u0105 obs\u0142ugiwane.","type":"object","properties":{"encoded":{"description":"Ustawienia instancji zakodowane Base64.","type":"string","context":["edit"]},"hash":{"description":"Hash kryptograficzny ustawie\u0144 instancji.","type":"string","context":["edit"]},"raw":{"description":"Niezakodowane ustawienia instancji, je\u015bli s\u0105 obs\u0142ugiwane.","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"Zakodowane w adresie URL dane z formularza wid\u017cetu. S\u0142u\u017cy do aktualizacji wid\u017cetu, kt\u00f3ry nie obs\u0142uguje instancji. Tylko zapisywanie.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"force":{"description":"Czy wymusi\u0107 usuni\u0119cie wid\u017cetu, czy przenie\u015b\u0107 go na nieaktywny pasek boczny?","type":"boolean","required":false}}}]},"\/wp\/v2\/block-directory\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"term":{"description":"Ogranicz wyniki wyszukiwania do pasuj\u0105cych blok\u00f3w.","type":"string","minLength":1,"required":true}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/wp\/v2\/block-directory\/search"}]}},"\/wp\/v2\/pattern-directory\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ogranicz wyniki do pasuj\u0105cych do zapytania.","type":"string","minLength":1,"required":false},"category":{"description":"Ogranicz wyniki do pasuj\u0105cych do kategorii.","type":"integer","minimum":1,"required":false},"keyword":{"description":"Ogranicz wyniki do pasuj\u0105cych do s\u0142owa kluczowego.","type":"integer","minimum":1,"required":false},"slug":{"description":"Ogranicz wyniki do pasuj\u0105cych do wzorca (uproszczona nazwa).","type":"array","required":false},"offset":{"description":"Przesu\u0144 wyniki o okre\u015blon\u0105 liczb\u0119 pozycji.","type":"integer","required":false},"order":{"description":"Sortowanie atrybut\u00f3w rosn\u0105co lub malej\u0105co.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sortuj kolekcj\u0119 wed\u0142ug atrybutu wpisu.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","favorite_count"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/wp\/v2\/pattern-directory\/patterns"}]}},"\/wp\/v2\/block-patterns\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/wp\/v2\/block-patterns\/patterns"}]}},"\/wp\/v2\/block-patterns\/categories":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/wp\/v2\/block-patterns\/categories"}]}},"\/wp-site-health\/v1":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-site-health\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/wp-site-health\/v1"}]}},"\/wp-site-health\/v1\/tests\/background-updates":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/wp-site-health\/v1\/tests\/background-updates"}]}},"\/wp-site-health\/v1\/tests\/loopback-requests":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/wp-site-health\/v1\/tests\/loopback-requests"}]}},"\/wp-site-health\/v1\/tests\/https-status":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/wp-site-health\/v1\/tests\/https-status"}]}},"\/wp-site-health\/v1\/tests\/dotorg-communication":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/wp-site-health\/v1\/tests\/dotorg-communication"}]}},"\/wp-site-health\/v1\/tests\/authorization-header":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/wp-site-health\/v1\/tests\/authorization-header"}]}},"\/wp-site-health\/v1\/directory-sizes":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/wp-site-health\/v1\/directory-sizes"}]}},"\/wp-site-health\/v1\/tests\/page-cache":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/wp-site-health\/v1\/tests\/page-cache"}]}},"\/wp-block-editor\/v1":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-block-editor\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/wp-block-editor\/v1"}]}},"\/wp-block-editor\/v1\/url-details":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"Adres URL do przetworzenia.","type":"string","format":"uri","required":true}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/wp-block-editor\/v1\/url-details"}]}},"\/wp\/v2\/menu-locations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/wp\/v2\/menu-locations"}]}},"\/wp\/v2\/menu-locations\/(?P<location>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"location":{"description":"Identyfikator alfanumeryczny dla po\u0142o\u017cenia menu.","type":"string","required":false},"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp-block-editor\/v1\/export":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/wp-block-editor\/v1\/export"}]}},"\/wp-block-editor\/v1\/navigation-fallback":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/wp-block-editor\/v1\/navigation-fallback"}]}},"\/wp\/v2\/font-collections":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Obecna strona kolekcji.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maksymalna liczba element\u00f3w, kt\u00f3re maj\u0105 by\u0107 zwr\u00f3cone w zestawie wynik\u00f3w.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/wp\/v2\/font-collections"}]}},"\/wp\/v2\/font-collections\/(?P<slug>[\\\/\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Kontekst w kt\u00f3rym wykonywane jest \u017c\u0105danie. Okre\u015bla pola obecne w odpowiedzi.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]}},"site_logo":0,"site_icon":8725,"site_icon_url":"https:\/\/blog.visual-paradigm.com\/pl\/wp-content\/uploads\/sites\/15\/2022\/10\/vp-online-logo.png","_links":{"help":[{"href":"https:\/\/developer.wordpress.org\/rest-api\/"}],"wp:featuredmedia":[{"embeddable":true,"type":"site_icon","href":"https:\/\/blog.visual-paradigm.com\/pl\/wp-json\/wp\/v2\/media\/8725"}],"curies":[{"name":"wp","href":"https:\/\/api.w.org\/{rel}","templated":true}]}}
