Create a diagram easily with Visual Paradigm Online. In this video, you can see how to reverse a connector in VP Online without changing the path of the connector.
When editing your design, you can reverse a connector, without the need of manual drag & drop
  1. Select the connector, then click on the swap arrows button at the context toolbar, the connector will be swapped its direction.
  2. Your connector ends and their labels will be swapped, but the path of the connector will not be changed.
