How to Extract Audio from MOV video for FREE
Sometimes, we might want to extract audio from a video is to use the audio separately, without the video content. For example, we may want to use a specific audio clip from a video in a podcast, music production or another video project. Extracting audio from a video can save time and effort in re-recording or searching for the same audio clip elsewhere.
VP Online File Conversion is a powerful tool for you to do so. In this article, we will show you how to extract audio from MOV for free!
MOV v.s.MP3
MOV and MP3 are two different file formats used for different purposes. MOV is a video format commonly used in Apple‘s QuickTime Player, while MP3 is a compressed audio format that is widely used for music and other audio applications. Here are the differences between them :
- Audio vs. Video: MP3 is an audio format, while MOV is a video format. MP3 is designed to compress audio files while retaining high quality, making it ideal for music and other audio applications. MOV, on the other hand, is designed to store and play video files, as well as audio tracks.
- Compression: Both formats use different compression techniques. MP3 uses lossy compression, which removes some audio data that is not readily apparent to the human ear, while MOV uses lossless compression, which retains all of the original video and audio data.
- File Size: MP3 files are typically smaller in size compared to MOV files because they contain only audio data. This makes them easier to share or store, especially when working with large audio files.
- Compatibility: MP3 is a widely used audio format that is supported by most audio players, devices and software. MOV, on the other hand, is more limited in terms of compatibility and may require specific software or hardware to play or edit.
Why you need to convert MOV to MP3
There are several reasons why we may need to convert MOV to MP3. For example, we may want to extract audio from a video file and save it as a separate audio format for listening on an MP3 player or other device.
Converting MOV to MP3 also reduces the file size, making it easier to share or store audio files. In addition, some software or devices may not support the MOV format, but they may be compatible with MP3, so converting to MP3 ensures broader compatibility.
Click Product and select File Conversion in VP Online.
Select Video Converters, and then click MOV to MP3 Converter.
Upload your MOV to the page and click Convert button to start the process.
When finished, we can download the MP3 file to our device.
