How to Unlock a PDF File?
With Visual Paradigm Online, you can now edit PDF files online. It is simple to use for individuals and businesses of all sizes. With the free online drag-and-drop PDF editor, you can quickly and easily change the text and graphics in any PDF file. The font choices, as well as additional content like videos, photos, and animation effects, can all be changed in a PDF document. Furthermore, if you need the privacy of your PDF, you can protect the PDF with a password and unlock it in VP online without using a PDF editor. This is a quick tutorial for you to learn how to unlock the password of a PDF easily with our tool. You can watch the attached video or read the guide below.
The locked PDF
Here is our PDF file which is locked by password. After clicking on open this PDF, originally, You have to enter the password if you want to read the content of the PDF.
Select PDF
To unlock the password of PDF, firstly, After login into your Visual Paradigm Online, you will arrive at your workspace in VP Online. You can now go to Dashboard and select Apps-PDF. Then, you can click on the PDF button to import your PDF from your device.
Select unlock PDF
Then, you can click on the Tools button, and a list of functions related to PDF will appear. You can then select unlock PDF to remove the password of the PDF in VP Online.
Choose your PDF file
Then, you can click on the choose file button for uploading your PDF file. Your device window will automatically appear and you can now select your PDF file on your device. You can also just drag and drop your PDF file to the workplace. It is fast and easy for uploading your file.
Enter the password
Then, you can now enter the original password in the below blank. Then, you can then click on continue for further steps of password removal. After entering the correct password for the PDF file, the file will be loaded into VP Online. And now, you can now click on the unlock button below.
Rename your PDF file
After adding the password for the uploaded PDF, you are allowed to change the name of the unlocked PDF. Finally, you can download the unlocked PDF in Visual Paradigm Online. And after downloading the unlocked PDF, you can click to open to PDF. Now, the password is no longer needed when you wish the read the content of the PDF.
