VP Online Smartboard is a powerful and intuitive online tool designed to help you create, organize, and visualize ideas with ease. Whether you are brainstorming alone or collaborating with a team, Smartboard makes mind mapping simple and enjoyable. Its drag-and-drop interface, customizable content and style, and seamless sharing options make it the perfect platform for turning thoughts into structured visuals. Best of all, you do not need to install any software—everything works right from your browser.
What Is a Mind Map and Why Use It?
A mind map is a visual representation of ideas and concepts, usually starting with a central idea and branching out into related topics. It helps you structure information in a way that mirrors how your brain naturally works—through association and connection.
Mind maps are commonly used for:
  • Brainstorming sessions
  • Planning projects or events
  • Organizing study notes
  • Visualizing business strategies
  • Mapping out creative ideas
Steps to Share Your Mind Map on Facebook
Once you have finished designing your mind map in Smartboard, sharing it to Facebook is quick and easy.
  1. Click the “Share” button on the top-right of the Smartboard workspace.
  2. Edit the title and description of your mind map to make it more presentable and engaging.
  3. Press “Enable Publish” to make your mind map publicly accessible.
  4. Click the Facebook icon located just below the publishing options.
  5. Post the shared URL to Facebook as part of your update, story, or group post.
Your mind map will now be available for others to view directly through the link you posted, which is perfect for sharing ideas, getting feedback, or sparking discussions.
Why Share Mind Maps on Social Media?
Sharing your mind map on platforms like Facebook allows you to:
  • Present your thoughts visually to your community or team
  • Get feedback or suggestions on a brainstorming idea
  • Inspire others with your planning process or learning structure
  • Showcase your creativity in an engaging, interactive way
Social media makes it easy to expand collaboration beyond your immediate team and invite a wider audience into the conversation.
Speed Up Your Process with the AI Mind Map Generator
If you are looking to save time and organize your thoughts faster, the AI-powered mind map generator in VP Online is the perfect assistant. With just a few clicks, you can turn a single topic into a complete, well-organized mind map. Simply input your main idea, and the AI will automatically generate related subtopics and structure them into a clean, easy-to-read format.
The AI does not just generate content, it also arranges ideas in a logical way that helps you see connections more clearly. From there, you can fully customize your mind map: edit the content, expand branches, change styles, and tailor the structure to fit your needs.
This AI feature is ideal for anyone who wants to focus on refining ideas instead of manually setting up the framework. Whether you are brainstorming, planning a strategy, or summarizing complex information, the AI mind map generator helps boost productivity and creativity.
