How to Add Enter & Exit Effect to a Character
Click on the effect in the timeline
To add enter and exit effect animations to a character using Visual Paradigm Online, follow these simple steps. Firstly, when you add a character to your project, it automatically comes with default entry and exit animation effects. These effects are displayed on the timeline, indicating when they occur during the animation. To make changes to these effects, simply click on the effect in the timeline. This will open up the effect settings panel, where you can modify various parameters and properties.
A live preview of effects
As you adjust the effects, Visual Paradigm Online provides a live preview, allowing you to see how the animation will look in real-time. This helps you fine-tune the effect to achieve the desired visual impact. Once you are satisfied with the adjustments, select and apply the effect to the character.
Adjust the duration of the effects
Furthermore, you have the flexibility to adjust the duration of the effects to control their timing and intensity. This allows you to create smooth and seamless transitions for your character’s entry and exit animations.
Activates a preview mode
To get a comprehensive view of the entire scene, you can press the “Preview” button. This activates a preview mode where you can watch the animation play out, including the character’s enter and exit effects, giving you a clear understanding of how the entire scene flows and ensuring everything looks just right.
By leveraging the enter and exit effect capabilities in Visual Paradigm Online, you can enhance the visual storytelling of your animated projects, adding an extra layer of engagement and professionalism.
