Beyond Static Images: Unlocking the Power of Diagram-as-Code with Mermaid and AI Tooling
The Documentation Crisis
Every engineering team knows the pain. You spend weeks designing a beautiful microservices architecture, meticulously crafting Visio diagrams that impress stakeholders. Six months later, the system has evolved—new services added, databases migrated, API endpoints deprecated—but the diagram is frozen in time. It’s a relic. A lie, even.
This is “doc-rot,” and it’s the silent killer of engineering productivity. When diagrams lie, developers ignore them. When developers ignore documentation, tribal knowledge takes over. When the one person who knows the system leaves, you’re left with a complex codebase and no map.
Diagram as Code (DaC) is the solution. And at its heart is Mermaid, the JavaScript-based diagramming tool that turns plain text into beautiful visuals.
The Core Philosophy: Treat Diagrams Like Software
The fundamental shift with Diagram as Code is treating your diagrams with the same rigor as your application code. This means:
1. Version Control is Standard
When your diagram is a .mermaid file, it lives in your Git repository alongside your source code. Every change is tracked. You can git blame to see who added that new service, git diff to review changes before merging, and roll back to any previous state.
gitGraph
commit id: "Initial architecture"
commit id: "Add user service"
branch feature/order-service
commit id: "Order service v1"
commit id: "Add payment gateway"
checkout main
merge feature/order-service
commit id: "Update API gateway"
Example: Visualizing your diagram’s own Git history using Mermaid’s Git Graph syntax
2. Code Reviews for Diagrams
Pull requests aren’t just for code anymore. When a developer proposes a new service or changes a data flow, that change appears as a readable diff in the PR. Reviewers can comment on the diagram itself, ensuring architectural decisions are discussed and approved before they’re merged.
3. CI/CD Pipeline Integration
Your diagrams can be automatically generated and validated in your pipeline. Imagine a GitHub Action that:
Renders all Mermaid diagrams as PNG/SVG
Uploads them to your documentation site
Fails the build if invalid Mermaid syntax is detected
flowchart LR
A[Developer Pushes Code] --> B[CI Pipeline Runs]
B --> C[Run Tests]
B --> D[Render Mermaid Diagrams]
D --> E{Valid Syntax?}
E -->|Yes| F[Upload to Documentation]
E -->|No| G[Fail Build & Alert Team]
F --> H[Deploy Application]
G --> I[Developer Fixes Syntax]
I --> A
Example: A CI/CD workflow for diagram validation and deployment
Mermaid in Action: Real-World Examples
Let’s explore the types of diagrams Mermaid supports with practical, real-world examples.
Example 1: Microservices Architecture (Flowchart)
This is the most common use case—visualizing how your services communicate.
flowchart TB
subgraph "Client Layer"
MobileApp[Mobile App]
WebApp[Web Application]
end
subgraph "API Gateway"
Gateway[API Gateway]
end
subgraph "Microservices"
UserSvc[User Service]
OrderSvc[Order Service]
ProductSvc[Product Service]
PaymentSvc[Payment Service]
end
subgraph "Data Layer"
UserDB[(User Database)]
OrderDB[(Order Database)]
ProductDB[(Product Database)]
Redis[(Redis Cache)]
end
subgraph "External Services"
Stripe[Stripe Payment]
EmailAPI[Email API]
end
MobileApp --> Gateway
WebApp --> Gateway
Gateway --> UserSvc
Gateway --> OrderSvc
Gateway --> ProductSvc
Gateway --> PaymentSvc
UserSvc --> UserDB
UserSvc --> Redis
OrderSvc --> OrderDB
OrderSvc --> Redis
ProductSvc --> ProductDB
ProductSvc --> Redis
PaymentSvc --> Stripe
OrderSvc --> EmailAPI
PaymentSvc --> EmailAPI
Example: A complete microservices architecture with caching, databases, and external dependencies
Example 2: User Authentication Flow (Sequence Diagram)
Sequence diagrams are perfect for documenting complex interactions between services.
sequenceDiagram
autonumber
participant User
participant Frontend
participant AuthSvc as Auth Service
participant UserDB as User Database
participant Cache as Redis Cache
participant EmailSvc as Email Service
User->>Frontend: Enter credentials
Frontend->>AuthSvc: POST /login (email, password)
AuthSvc->>UserDB: Query user by email
UserDB-->>AuthSvc: Return hashed password & user data
AuthSvc->>AuthSvc: Verify password with bcrypt
alt Valid Credentials
AuthSvc->>AuthSvc: Generate JWT token
AuthSvc->>Cache: Store session (key: user_id, ttl: 1hr)
AuthSvc-->>Frontend: 200 OK + JWT token
Frontend-->>User: Redirect to dashboard
else Invalid Credentials
AuthSvc->>EmailSvc: Trigger failed login alert
AuthSvc-->>Frontend: 401 Unauthorized
Frontend-->>User: Show error message
end
Note over AuthSvc,EmailSvc: After 5 failed attempts, lock account for 15 min
Example: A detailed authentication flow showing success and failure paths, including side effects like caching and alerts
Example 3: Cloud Infrastructure on AWS (Class Diagram)
Class diagrams aren’t just for code—they can model cloud resources and their relationships.
classDiagram
class VPC {
+string cidr_block
+string region
+createSubnet()
+deleteSubnet()
class Subnet {
+string availability_zone
+string cidr_block
+boolean is_public
+attachRouteTable()
class EC2Instance {
+string instance_type
+string ami_id
+int storage_gb
+start()
+stop()
+reboot()
class RDSDatabase {
+string engine
+string version
+int storage_gb
+boolean multi_az
+takeSnapshot()
+restoreFromSnapshot()
class S3Bucket {
+string bucket_name
+string region
+boolean versioning_enabled
+uploadFile()
+downloadFile()
class IAMRole {
+string role_name
+string policy_document
+attachPolicy()
+detachPolicy()
VPC "1" --> "*" Subnet
Subnet "1" --> "*" EC2Instance
Subnet "1" --> "0..1" RDSDatabase
VPC "1" --> "0..*" S3Bucket
EC2Instance --> IAMRole
RDSDatabase --> IAMRole
Example: Modeling AWS infrastructure as classes with properties and methods, useful for documentation and Infrastructure-as-Code planning
Example 4: E-Commerce Order Processing (State Diagram)
State diagrams excel at showing how entities transition through different statuses.
stateDiagram-v2
[*] --> Cart: User adds items
Cart --> Checkout: User proceeds to checkout
Checkout --> PaymentPending: User submits order
PaymentPending --> PaymentProcessing: Initiate payment gateway
PaymentProcessing --> Paid: Payment successful
PaymentProcessing --> PaymentFailed: Payment declined
PaymentFailed --> Checkout: User retries payment
PaymentFailed --> [*]: User abandons cart
Paid --> OrderConfirmed: Send confirmation email
OrderConfirmed --> Preparing: Assign to warehouse
Preparing --> Shipped: Handover to carrier
Shipped --> InTransit: Carrier picks up
InTransit --> Delivered: Delivery confirmed
Delivered --> ReviewPrompted: Request user review
ReviewPrompted --> [*]: User submits review
Delivered --> RefundRequested: User initiates refund
RefundRequested --> RefundApproved: Support approves
RefundApproved --> RefundProcessed: Money returned
RefundProcessed --> [*]: Order closed
state "High-Risk Fraud Check" as FraudCheck {
[*] --> CheckScore
CheckScore --> LowRisk: Score < 50
CheckScore --> HighRisk: Score >= 50
HighRisk --> ManualReview: Flag for team
ManualReview --> LowRisk: Approved
ManualReview --> PaymentFailed: Rejected
PaymentPending --> FraudCheck: Risk assessment triggered
FraudCheck --> PaymentProcessing: LowRisk
Example: Complete e-commerce order state machine with fraud detection nested state
Example 5: Sprint Planning with GitHub Issues (Git Graph)
Git graphs can represent workflows beyond Git itself.
gitGraph
commit id: "Sprint Planning" type: HIGHLIGHT
branch sprint-1
commit id: "User Story #101: Login Page"
commit id: "User Story #102: User Registration"
branch bugfix/hotfix
commit id: "Hotfix: Auth Token Expiry"
checkout sprint-1
merge bugfix/hotfix
commit id: "User Story #103: Password Reset"
checkout main
merge sprint-1 tag: "v1.0.0"
branch sprint-2
commit id: "Feature #201: Shopping Cart"
commit id: "Feature #202: Checkout Flow"
branch experiment/ai-recommendations
commit id: "POC: ML Recommendation Engine"
checkout sprint-2
commit id: "Feature #203: Order History"
checkout main
merge sprint-2 tag: "v2.0.0"
commit id: "Release Notes: Sprint 1 & 2 Complete"
Example: Visualizing project management, sprints, and feature branches as a Git graph
The AI Revolution in Diagramming
Despite Mermaid’s elegance, the syntax can be a barrier. Who wants to debug a misaligned arrow or a missing bracket when you’re trying to document a system?
This is where AI-powered tools change everything.
AI Auto-Fix
Tools like VPasCode (Visual Paradigm’s Diagram as Code platform) and Mermaid Chart have integrated AI models (like Google Gemini and OpenAI) that can:
Auto-detect syntax errors
Fix broken diagrams with a single click
Suggest improvements to diagram structure
Let’s see this in action:
Broken Mermaid Code:
flowchart LR
A[Frontend] --> B(API Gateway
B --> C[User Service]
C --> D[(Database
D --> E[Cache]
AI-Fixed Code:
flowchart LR
A[Frontend] --> B(API Gateway)
C --> D[(Database)]
D --> E[Cache]
The AI recognizes missing closing parentheses and brackets, fixing them instantly.
Natural Language to Diagram
Perhaps the most powerful feature is generating diagrams from natural language descriptions. With tools like OpenDocs (VP’s documentation platform), you can simply describe what you want:
“Create a flowchart showing a user logging in. If the credentials are valid, redirect to the dashboard. If invalid, show an error and allow 3 attempts. After 3 failures, lock the account.”
AI-Generated Mermaid:
flowchart TD
Start([User Attempts Login]) --> EnterCreds[Enter Email & Password]
EnterCreds --> Validate{Validate Credentials}
Validate -->|Valid| Dashboard[Redirect to Dashboard]
Validate -->|Invalid| CheckAttempts{Attempts < 3}
CheckAttempts -->|Yes| Increment[Increment Attempt Counter]
Increment --> ShowError[Show Error Message]
ShowError --> EnterCreds
CheckAttempts -->|No| LockAccount[Lock Account for 15 min]
LockAccount --> SendAlert[Send Security Alert Email]
SendAlert --> End([Process Ends])
Dashboard --> End
Translation Between Diagram Types
AI can also translate between different diagram formats. Need a PlantUML diagram converted to Mermaid? AI tools can handle that:
PlantUML Input:
@startuml
actor User
participant "Frontend" as FE
participant "Backend" as BE
database "DB" as DB
User -> FE: Click Login
FE -> BE: POST /login
BE -> DB: SELECT user
DB --> BE: user data
BE --> FE: JWT token
FE --> User: Show Dashboard
@enduml
AI-Converted Mermaid:
sequenceDiagram
actor User
participant Backend
participant Database
User->>Frontend: Click Login
Frontend->>Backend: POST /login
Backend->>Database: SELECT user
Database-->>Backend: user data
Backend-->>Frontend: JWT token
Frontend-->>User: Show Dashboard
Interactive Chatbot Integration
Some platforms now offer chatbot interfaces for diagram creation. You can have a conversation:
User: “Add a new service called ‘Inventory Service’ to my architecture diagram.”
AI: “I’ll add an Inventory Service connected to your existing Product and Order services.”
Diagram updates automatically
User: “Actually, make it also connect to a new database called ‘InventoryDB’.”
AI: “Done. Inventory Service now connects to Product Service, Order Service, and the new InventoryDB.”
Integrating Diagram as Code into Your Workflow
Step 1: Start Small
Don’t try to diagram your entire system at once. Start with a single component—perhaps your authentication flow or a new feature you’re building.
Step 2: Embed in Documentation
Keep your .mermaid files alongside your documentation (e.g., in a /docs folder). Use tools like mermaid-cli to render them during the build process.
Step 3: Leverage VPasCode’s Unified Engine
If you’re working in a team with diverse preferences, VPasCode is invaluable. It supports multiple diagram-as-code languages in one place:
# In VPasCode, you can mix and match:
diagrams/
├── architecture.mermaid
├── deployment.puml # PlantUML
├── database-erd.mermaid
└── workflow.d2 # D2 language
Step 4: Automate with CI/CD
Add a step to your GitHub Actions or GitLab CI:
- name: Render Mermaid Diagrams
run: |
for file in $(find docs -name "*.mermaid"); do
npx @mermaid-js/mermaid-cli -i $file -o ${file%.mermaid}.png
done
- name: Upload to Documentation Site
run: |
aws s3 sync docs/ s3://your-docs-bucket/
Step 5: Review in Pull Requests
Make it a policy that all architecture changes require diagram updates. Use PR comments to discuss visual changes:
Reviewer: “Shouldn’t the cache sit between the Order Service and the Database? Currently it’s only attached to User Service.”
Author: “Good catch. I’ll update the diagram.”
Real-World Impact: A Case Study
Consider a fintech startup that adopted Diagram as Code with Mermaid and VPasCode:
Before: 47 static Visio files, most over 6 months old. New hires spent 3 weeks understanding the architecture.
After: 12 Mermaid diagrams, all stored in Git, updated with every feature. New hires were productive in week 1.
The team’s CTO noted: “We went from diagrams being a compliance checkbox to being a living part of our development process. When we debate a new architecture, we open the Mermaid editor and literally sketch it out in code. It’s a game-changer.”
The Future: Continuous Documentation
The ultimate goal is “continuous documentation,” where diagrams are generated automatically from your infrastructure or code. Tools are already emerging that can:
Scan your Kubernetes manifests and generate service topology diagrams
Parse OpenAPI/Swagger files and create API flow diagrams
Monitor your cloud resources and auto-update architecture diagrams
Mermaid is at the center of this movement, providing a simple, text-based format that machines can generate and humans can understand.
Getting Started Today
Ready to move beyond static images? Here’s your action plan:
Install the Mermaid extension in your favorite IDE (VS Code, IntelliJ)
Create your first diagram in a
.mdfile using Mermaid’s syntax -
Explore VPasCode’s free tier to experience AI-powered diagramming
Start a living documentation repository alongside your codebase
Share this article with your team and start the conversation
Your architecture deserves better than a dusty diagram in a forgotten folder. It’s time to treat your diagrams like the critical assets they are.
